boeingpride800
What Is The Difference Between ER And LR?
Wed Aug 04, 2004 5:58 am
What is the difference between ER (Extended Range) and LR (Long(er) Range)? Only Boeing uses these terms.
gigneil
RE: What Is The Difference Between ER And LR?
Wed Aug 04, 2004 6:01 am
There is only one LR Boeing model, which is longer range than the ER, which is longer range than the normal model.
Pretty straightforward. The capabilities for each model differ per platform.
N
ual747den
Wed Aug 04, 2004 6:05 am
I believe that the ER is achieved by doing very little changes, and mostly just within the computer and in certification. The LR represents major changes to an aircraft and actual engineering changes being made so that the aircraft has an entirely different use.... Hope I was able to explained it somewhat understandable, and I could be completely wrong Who Knows!!!
/// UNITED AIRLINES
ConcordeBoy
Wed Aug 04, 2004 6:08 am
I'll take option 2 for 5 dollars please Alex.
tbanger
Wed Aug 04, 2004 6:12 am
I believe that Bombardier also use these terms. Follow this link and read the "HISTORY" section.
http://www.airliners.net/info/stats.main?id=125
