SA7700
JFK Arrivals And Connections
Wed Aug 11, 2004 6:23 pm
Hello there
I need some urgent help and advice please!?
I'm due to fly out to JFK, arriving on SA203 at 07h25. I then need to connect to a SFO bound flight.
In your opinion, what would the most sensible timeframe be to consider? Going through US customs in Terminal 3, picking up my bags, transferring to another terminal (AA or UA). Checking in and going through security again.
US Airline recommendations?
I would greatly appreciate your help.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
robcol99
RE: JFK Arrivals And Connections
Wed Aug 11, 2004 8:33 pm
JFK in the mornings are not bad. Especially at that hour, I don't think there are that many Delta flights coming in at that hour.
AA 179 leaves around 9 20.
Two hours connection, eh- should be enough.
But if you want to be on the safe side, you can take UA 7 or AA15, which should both leave around 11 30 am.
AA terminal is under construction, so its kind of messy.
UA uses BA terminal 7, a compact terminal.
Enjoy San Francisco.
modesto2
Wed Aug 11, 2004 9:14 pm
I'd try to give it closer to 3 hours. After you clear customs and take the Airtrain to another terminal (UA is 7, AA is 8/9) and check in again, you'll need a few extra minutes.
JGPH1A
Wed Aug 11, 2004 9:23 pm
Connect onto the DL329 - departs JFK T3 at 0820. You should be able to get through-checked by SAA and have your bp's/bagtags all the way through to SFO from JNB, you'd still need to clear you're luggage and reclear security (stupid system !) but you wouldn't have to recheck in, just drop your bags off with SA)">DL.
The MCT for JFK for SA onto SA)">DL is 1 hour - this connection gives you 1 hour and 10 minutes.
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
SafetyDude
Wed Aug 11, 2004 9:52 pm
I would strongly urge you not to take that flight, or any flight that departs prior to 10:00 due to that SA could have a late arrival (which is common). It is better to be safe than sorry.
For airlines recommended, I would try either AA or UA, and choose the airline that works best for you.
Stupid? Not at all. Passengers are in contact with their luggage and thus need to re-clear security.
 Smile
-Will
"She Flew For What We Stand For"
SA7700
Wed Aug 11, 2004 10:10 pm
Thanks for all the replies. I really appreciate the input and ideas.
It would have been much easier taking SA209 to ATL and connect onto DL from there, but the flight leaves JNB at 16h50, which I won't make.
