Panther
ACA Dojets To Skyways
Thu Aug 12, 2004 4:22 am
When or I should say "if" Skyways picks up all of ACA's Do328Jets will they become a Delta Connection carrier as well? It seems to be a lot of Dojets just for Midwest airlines to handle.
hawaiian717
RE: ACA Dojets To Skyways
Thu Aug 12, 2004 4:34 am
Yes. From what I hear, Delta will assume the leases on the DoJets, and provide them to Skyway to operate Delta Connection service.
David / MRY
TechRep
Thu Aug 12, 2004 4:40 am
I predicted this 4 months ago.
Techrep
airtran737
Thu Aug 12, 2004 7:17 am
actually of the thirty 328 jets tha Delta has, look for YX to use 10 of them for themselves, and 20 for DL operations
Nice Trip Report!!! Great Pics, thanks for posting!!!! B747Forever
papatango
Thu Aug 12, 2004 7:21 am
If Delta is paying the leases I doubt they will let YX use them for themselves. I am sure they all will continue flying for Delta.
FlyPNS1
Thu Aug 12, 2004 7:35 am
Actually, I think DL will sell some of them to SkyWay, so that SkyWay can use them for the Midwest Connection.
B4REAL
Thu Aug 12, 2004 7:57 am
I would not be surprised if DL inherited the leases, then sub-leased the 10 to SkyWay and make a buck on it  Smile
ngr
Thu Aug 12, 2004 8:03 am
There has be an "328Jet" Here in Columbia (KCAE) for at least a month in Delta's NNC....does anybody know if it still belongs to DL, or if it is broken, etc?
-ngr
syncmaster
Thu Aug 12, 2004 8:29 am
B4real,
According to many here, if DL breaks the contract with ACA which they are doing because of the pilot union and Independence Air being considered whatever the contract considers it DL has to assume the leases on the FRJ's.
Skyway1
Thu Aug 12, 2004 8:35 am
Yep this has been known for some time now. Last I heard Skyway was supposed to take over operations as of November 1st. Frankly, Skyway can barely handle their Beech/328Jet flying right now.....so I'm not sure how this will work out in the future. Anybody want a job at CVG??? No thanks I'll pass.
EDIT: Delta did break the contract....hence Skyway assuming the DoJet operation out of CVG. BTW....good to see you again TechRep!!!
Chris
[Edited 2004-08-12 01:37:55]
KNUK, KNUK, KNUK woowoowoo
B4REAL
Thu Aug 12, 2004 8:40 am
Snyc: I agree, the scope clause for DL pilots, I believe limits affiliated carriers for such situations to not operate aircraft with 71 or more seats. Codesharing w/ CO, NW, AF,... is special.
But once DH (indy) operates the A319, the company would be inviolation of the scope clause.
So, getting SkyWay on board as a DL Connection carrier makes sense. But, who is to say DL can't make a buck on the DoJos - especially if they don't need all 32.
ushermittwoch
Thu Aug 12, 2004 8:42 am
Are they going to cut any routes or will everything stay as it is?
Where have all the tri-jets gone...
syncmaster
Thu Aug 12, 2004 8:48 am
B4real, I agree.
Ushermittwoch, I've noticed that the FRJ has been slowly taken out of the SBN (South Bend, IN) schedules to be completely removed by Oct/Nov replaced by Comair, they've also added 2 daily CR7's on top of the CRJ's that will replace the FRJ's, I'm not sure about other routes. I believe they've also added another flight or two from ATL to add the the 3 already.
OzarkD9S
Thu Aug 12, 2004 8:50 am
Wasn't DL management quoted as saying they were not impressed with the 328Jet's reliability problems? Why would they be interested in SkyWay operating them as DLX?
Also, why would YX do DL any favors with DL's partner NW busting their hump in MKE? Could something bigger be afoot?
A lot of questions to be sure regarding this development....
Next Up: STL-MIA-GCM-MIA-STL. Fun in the December sun! :santahat:
syncmaster
Thu Aug 12, 2004 9:55 am
They probably can't get rid of the leases on the aircraft without very high costs, the termination fees alone probably make it worth it, plus they need the aircraft right now.
SkyWay is the only other North American operator of the FRJ, so they are an obvious choice, and no matter who it is as long as it brings in money what do/should they care?
RJNUT
Thu Aug 12, 2004 8:30 pm
I looked at CVG skeds into NOvermber and many of the DO328 routes have been changed to ERJ from Chautauqua...So the rumor of YXConnect using some of them could be true.
If DL goes into bankruptcy, will that no change the scope of this entire transaction.. READ -"go to hell ACA! (and your silly little leases ,too!)
garnetpalmetto
Thu Aug 12, 2004 11:03 pm
NGR - I believe the one you're talking about (the one visible from the Airport Boulevard entrance) is busted. When I drove by yesterday, both engines had been removed.
South Carolina - too small to be its own country, too big to be a mental asylum.
FutureFO
Fri Aug 13, 2004 7:24 am
We are getting 10 of them on 01Nov when we take over for ACA out of CVG. With further arrivals as the contract and routes grow. We will take over the majority of the routes at the end of the ACA contract. But as of right now there are no plans by DL to operate them to other DLC partners. Considering there would be a greater expense to train the crews on an additional a/c type than to all ready provide them to a carrier that is currently operating the type and has the staffing to handle the a/c.
Sean from MCO and CVG
I Don't know where I am anymore
Skyway1
Sat Aug 14, 2004 9:18 pm
Yep....it seems AirTran737 has some correct info on Skyway operating 10 DoJets for ther own ops. Not sure yet whether they will open up new stations or eliminate some Beech flying. There's also speculation they might 'wet lease' crews to operate the Delta Connection flying. We'll see.....
Chris
[Edited 2004-08-14 14:30:08]
kcrwflyer
Sat Aug 14, 2004 10:48 pm
where can i see the CVG november scheduel?
kcrwflyer
Sat Aug 14, 2004 10:58 pm
sorry about a double post, But what do they plan to do with the 328 jets on the CRW-CVG route? It seems too short to be economical for an embraer, Though it did used to be a CRJ-100.
They cut way back on CVG service in CRW, And loads were fine. went from daily 4 328j's and 1 crj to 4 328j's mon.tue.wed. and 3 on thurs, and i think 2 on fri and sat.
airtran737
Sun Aug 15, 2004 1:15 am
I was out with the new CVG chief pilot from Skyway, and the ALPA MEC Chairman the other night for some dinner. Bill Huffman who is the new chief pilot started his career with Skyway, then went to DL as a flight engineer on the 727. He then move to being an FO on the MD-80. After 9-11 he was furloughed, and went to Sunking on the 727. Now he's back at Skyway, and was taking his oral for the 328 Jet yesterday morning. He seems to have a very straight forward way of thinking, which will be good for the pilots that he is overseeing.
ouboy79
Sun Aug 15, 2004 2:06 am
Here is how things will play out in TOL...
CVG currently is:
530 FRJ
640 FRJ (CRJ on Sundays)
1005 FRJ
1054 CRJ
1305 CRJ
1410 FRJ
1605 FRJ
1900 CRJ
2015 FRJ
Sept 1
530 FRJ
640 FRJ
1005 FRJ
1054 CRJ
1305 CRJ
1410 FRJ
1605 ERJ
1900 CRJ
2015 FRJ
Nov 1
530 FRJ
640 CRJ
1005 CRJ
1054 CRJ
1300 CRJ
1400 CRJ
1605 ERJ
1900 CRJ
2015 FRJ
kcrwflyer
Sun Aug 15, 2004 2:43 am
ouboy79, can you get me some stats like that for KCRW?
ouboy79
Sun Aug 15, 2004 4:25 am
I think you would be more than capable of pulling it up online yourself...just like I did. Here...I'll even help you out a bit...
http://www.amadeus.net/pl/availabilityonly/en/avail_only.htm
Amadeus is pretty easy to use when you go under the Timetable section.
kcrwflyer
Sun Aug 15, 2004 4:40 am
thanks a lot man. I never knew about this site.
Skyway1
Sun Aug 15, 2004 8:38 am
AirTran737.....
What happened to Auggie Fjordholm???? Man I've been away from this company for too long....
Chris
