Btblue
Airbus/Boeing Future Of Gas Powered Aircraft.....
Thu Aug 12, 2004 6:22 am
Fossil fuels are running out and petrol (certainly here in the UK) is becoming more and more expensive which makes me wonder...
Airbus and Boeing are bringing out more fuel efficient airliners, 20% better than the previous (in some cases) etc but what about in 20 years from now?
What do you think an airliner will be powered by? There is no infinite supply of oil so one day there is going to have to be a change over to a different propellant.
I read about the 7E7 and the A380 sales targets/forecasts but surely even in 15 years from now a new airliner will have to be developed that is powered on a different fuel source.
[Edited 2004-08-11 23:25:02]
DfwRevolution
RE: Airbus/Boeing Future Of Gas Powered Aircraft..
Thu Aug 12, 2004 6:27 am
I'd like to start off by pushing this debate away from when oil will run out (if ever according to some ppl) but toward to aircraft design. If there is anything we a.netters no less about aircraft its oil exploration, so just stick to aviation  Big grin
DfwRevolution
Thu Aug 12, 2004 6:28 am
I think an ethanol-based fuel might work. Its renuable and wouldn;t be as tough as hydrogen to work around.
radelow
RE: Airbus/Boeing Future Of Gas Powered Aircraft.....
Thu Aug 12, 2004 6:34 am
I too don't put much weight in the theory we will run out of oil anytime soon. Take the Athabasca Oil Sands in Canada for instance. They have between 1.75 and 2.5 TRILLION barrels of oils. For comparison, Saudi Arabia has about 265 billion barrels in proven reserves.
New technologies will be needed to get much of this oil but we move forward everyday technology-wise.
[Edited 2004-08-11 23:41:02]
Thu Aug 12, 2004 7:19 am
Gases have the problem of being very bulky for the impulse the provide (low specific impulse per volume). Unless you want your shiny new 797 to tow along a trailer full off propellant...
BandA
Thu Aug 12, 2004 7:26 am
Maybe THIS will make a return?
http://www.cowtown.net/proweb/nb36h_jde.htm
Scary!
"They [Terrorists] never stop thinking about new ways to harm our country and our people, and neither do we." - GWB
gigneil
Thu Aug 12, 2004 7:38 am
Kerosene has an extremely, extremely low generative energy. Only 20 to 30% of the chemical capacity of kerosene can be converted to actual energy. Gasoline is much the same way.
Ethanol fuels are much higher energy fuels, but I still don't know if that's the right thing for a jet.
The potential for the future will surely be all-electric aircraft, when fuel cell technology improves.
N
ltbewr
Thu Aug 12, 2004 8:34 am
First of all jet aircraft do not use 'gas' or gasoline, they use a form of kerosine. Perhaps over the years a switch to bio-fuel blend, like biodiesel blends now being expirmented with. Essentially, it is vegetable oils, blended with some alcohol based chemicals to keep it fluid for use in motor vehicles. Ther are plenty of websites you can search for for more info on biodiesel. Since 'jet fuel' is similar to diesel fuel and kerosine, it could easily be the fuel of the future, replacing petrolium based fuels. Newer jets could be specifically built for use of it, and older aircraft and engines could be modified at a reasonable cost for many more years of use.
Thu Aug 12, 2004 9:17 am
Gigneil, kerosene is not a gas. I assumed that we were talking about gases, not gasoline.
bill142
Thu Aug 12, 2004 12:56 pm
like biodiesel blends now being experimented with
Biodiesel won't work in aircraft because like diesel it can not be ignigted by a flame or a spark. It relies on heat from friction or needs to be mixed with petrol to ignite. Ethanol fuels however could be an option as they are extremely environmentally friendly. After being burnt the gas given on if Carbon Dioxide which is what we humans breath out, unlike carbon monoxide which is generally the gas released after burning traditional fuels.
Another option is to look at fuels similar to what are used in racing cars which have a higher content of chemicals then it does of petrol. how compatible this would be with a jet engine I couldn't tell you
DragonRapide
Thu Aug 12, 2004 4:18 pm
I'ld like to refer to some comments I made in another topic (What should Airbus do?).
Working for a car company and being involved in amongst others these discussions I can asure you that if the "oil" problem was so easily solved as suggested by some of the above, the world would be completely different.
And I am not alluding only to technology but also world economy, politics, basically the whole of the society.
Fact 1: The question is not only when we run out of oil. In fact that question may be totally irrelevant. More important today and in the foreseeable future is what the demand will do. Again as already pointed out, the demand has grown sharply within China and it will continue to do so. Also, the political situation not only in Arabian countries but in all major oil producing countries (Russia is a very recent example, Venezuela is another one). Also trying to estimate what will happen if the world shifts from a oil driven economy to another source (hydrogen, solar power, ...) is very difficult. The complete economical structure of the whole world will change, countries will disappear or change remarkably, ... In any case, such a shift will have to happen very very gradually and will still have enormous chocks and sudden changes.
Fact 2: Although hybrid cars are around (I work for a company that was the first to launch such a car) the technology is not usable for airplanes. Basically the electrical engine is used for starting and once at a certain speed the fuel engine kicks in. Add to that the stop-and-go systems (fuel engine stops running when you stop at for example a red light and electrical engine is used to start off again) and you have the hybrid cars of today and the future. The batteries for the engine are still heavy and are recharged by braking energy. The electrical engine is contributing 0% during cruise.
Fact 3: Hydrogen powered cars will take at least another 20 years. Yes, I know, there are some prototypes driving aroound even as we speak. However, the difference between a prototype technology demonstrator and a mass production car is very big. Many big problems still need to be solved. I will mention only one: reliability. That's still a long way off and be honest reliability is much more severe in aviation. Secondly, the energy necessary to produce hydrogen is enormous and thirdly where to fill up your tank with hydrogen??? Supply of hydrogen may turn out to be the biggest problem overall.
Fact 4: Some form of bioenergy. Probably will become a niche product, especially if the fuel price continues to rise, bioenergy (oil produced from seeds) could become competitive. But production (crops) are much too few to have an impact today. And as stated above, we are talking about diesel here which is nto eactly the kind of fuel airplanes need.
Fact 5: Fuel cells, only this year engineers have cracked the problems with fuel cell cars driving in temperaturs below zero (degrees Celcius) (before that, the cars only worked in positive temperatures). Slowly problems are being resolved but the hydrogen (see fact 3) is still the major problem. And the weight of the fuel cells of course.
Basically what I wanted to get across is that:
a/ the energy problem is difficult enough for car companies to crack let alone for airplanes
b/ car companies are today pursuing different directions which means one thing: no-one is sure and has the correct answer, everyone is trying to come up with a solution but THE solution has not been found yet (and may never be)
c/ it is all much more complex than what some members are suggesting. My small message only gives a very small insight of the problems and issues at stake
d/ don't ask me for a solution because there is no answer to that question yet. The only thing I could see happening is that fuel prices rise sharply (very likely to happen and today's oil prices will seem cheap in comparison) and priorities will be set: cars to use as much as possible hybrid or alternative fuel technologies. Houyseholds and industry to use alternative fuels (gas, electricity, solar power, ...) and aviation being one of the industries to use kerosene as long as possible. What very high fuel prices will do for the traffic levels is a completely different discussion.
Klaus
Bill142
Thu Aug 12, 2004 6:47 pm
Bill142: Biodiesel won't work in aircraft because like diesel it can not be ignigted by a flame or a spark.
Every fuel can be ignited that way. It´s just a question of the temperatures required.
Bill142: It relies on heat from friction
No. Diesel engines ignite through compression, not friction.
Klaus
Thu Aug 12, 2004 6:54 pm
By the way, I know I´m repeating myself, but this belongs into this discussion as well:
Clean air / climate change will become an increasingly limiting factor on all fuel-burning technologies. Fuel can be found or made, if probably at increasing cost. But clean air and a stable climate are much more problematic in the longer run.
leelaw
Thu Aug 12, 2004 7:33 pm
They've been wringing their hands about the exhaustion of petroleum supplies since John D. Rockefeller was just a twinkle in his Daddy's eye. I can remember the pundits in the early seventies saying the world would be pumped dry of oil by 1995. BTW, according to the same people we should be in the middle of an ice age as we speak!
Lex Ancilla Justitiae
captjetblast
Fri Aug 13, 2004 5:29 am
I guess aircraft builders (Boeing, Airbus, etc) have been secretly developing and testing new propulsion technologies based on anything different from fossile fuels. Maybe they have an agreement, no one will alter the market with a new solution for oil problem, all of the big companies will show their new products (engines) at a time.
Fossile oil is still the big bussiness.
gigneil
Fri Aug 13, 2004 5:38 am
I wasn't slanting your argument, I was adding to it. Kerosene is also extremely inefficient...
N
kim777fan
Fri Aug 13, 2004 5:54 am
"I can remember the pundits in the early seventies saying the world would be pumped dry of oil by 1995."
I don't remember anything THAT optimistic. All I can remember hearing was 1990 at the latest.
Of course, it all started with the Yom Kippur War in 1973 when Syria, Lebanon, and Egypt attacked Israel. Secretary of State Henry Kissinger acted immediately and warned those nations to withdraw immediately. In protest for U.S. support of Israel, Arab oil-producing countries led by none other than Saudi Arabia then imposed an oil embargo on the United States.
Gasoline prices then skyrocketed to the unheard of price of 80 cents a gallon and higher. To this day, adjusted for inflation, it is the most expensive fuel has ever been in this country. People lined up for several blocks just to buy a tank of gas for their car.
It was at that time we heard we would run out of oil by 1990 at the latest and by 2000, everyone would be driving solar-powered cars.
gaut
Fri Aug 13, 2004 6:33 am
Take a look at this link, it's about the cryoplane:
http://www.h2hh.de/downloads/Westenberger.pdf
«Horum omnium fortissimi sunt Belgae.»
whitehatter
Fri Aug 13, 2004 6:45 am
In the short to medium term, what's needed are cleaner and ever more efficient engines. Fuel technologies also need to keep up and offer cleaner fuels which have less harmful byproducts.
Doing this leads into alternative fuels as well, as highly efficient and versatile powerplants will be much more adaptable to redesigning for a new fuel type such as biofuel derivatives.
Sooner or later the oil addiction will need to be broken, as it's never going to be a forever deal. There just isn't an infinite supply. But by constantly pushing jet technology and efficiency it makes it easier to eventually change designs or thinking. Cars and heavy vehicles have already gone that way. Years ago they ran on petrol exclusively, now a bus or car can run on petrol, diesel, biodiesel, kerosene, alcohol, gas or even hydrogen. All in a broadly similar engine configuration.
Lead me not into temptation, I can find my own way there...
justloveplanes
Fri Aug 13, 2004 7:12 am
I think the one fossil fuel application that will outlast all others is aviation and automobiles. Hybrids I believe will dominate the market in a very short time for cars, keeping them in synch with current patterns a bit longer than airplanes. Planes might take a hit.
For the open road, it is almost silly to build anything other than a hybrid for a car, except for pure performance (Porsche, Ferrari, etc.). Hybrids basically recover the heat from braking (otherwise completely and needlessly wasted) and put it to good use for a very modest weight penalty. Look for your hybrid caddy at a dealer near you soon.
Airplanes don't brake and require dense concentrated fuel. Right now LCC's like Southwest compete with the automobile, so aviation will lose ground relative to hybrid technology if petro costs soar. The economy will adjust. I am interested to see if Boeing's forecast took any of this into account.
Great thread.
brons2
Fri Aug 13, 2004 8:22 am
There are some diesel powered recips out there for use in GA aircraft. I'm sure they could be modifed to run on biodiesel fairly easily.
Perhaps we could see a return to large recips running on bio fuels??
(...nah...)
Firings, if well done, are good for employee morale.
charlib52
Fri Aug 13, 2004 8:48 am
Off subject, but an interesting-factoid-I-know-has-probably-been-stated-in-the-forums-before-but-would-add-to-this-discussion-here-and-now:
Anyone know what is the per mile consumption of fuel of the different modes of transportation per passenger? I'm thinking I know aviation is the lowest, but I'm just not sure...
Klaus
Charlib52
Fri Aug 13, 2004 9:08 am
The more efficient long-haul jets reach about the consumption of a very economical car per person.
So if you´re driving alone in a small car to Australia, that´s about it.  Wink/being sarcastic If you´re driving in the same car with a few other people, the car is more economical. And trains are still better than that.
Short-haul jets are worse because of the larger effect of climb to altitude compared to the cruise portion.
[Edited 2004-08-13 02:10:00]
fanofjets
Fri Aug 13, 2004 11:17 pm
In an encyclopedia of civil aviation dated 1980 (which is still on my shelf), Lockheed were said to be developing hydrodgen-powered airliners. There are two pictures, one showing a stretched L-1011 H2-powered freighter and another showing a double-deck 4-engined turboprop with contra-rotating props. It is always interesting to look back to the future....
The aeroplane has unveiled for us the true face of the earth. -Antoine de Saint-Exupery
