ushermittwoch
Connecting In BTV
Sat Aug 14, 2004 10:45 am
Hi!
Is it possible to make a connection in 21 minutes at BTV?
Sorry that I don't have much more to say...
 Smile
Coming from CVG going to BOS.
[Edited 2004-08-14 03:46:05]
Where have all the tri-jets gone...
deltairlines
RE: Connecting In BTV
Sat Aug 14, 2004 10:56 am
I am assuming you're on Delta, arriving at about 1744 and departing for BOS at 1805. This plane is actually on a CVG-BTV-BOS routing, so unless you miss the plane in CVG, then you're with it all the way to Boston.
Jeff
ushermittwoch
Sat Aug 14, 2004 10:59 am
Actually it's flights 5752 and 5723.
But it's absolutely no problem, right?
Will I be able to get out for a minute or two?
[Edited 2004-08-14 04:01:14]
MHTOH
Sat Aug 14, 2004 11:44 pm
Having worked up there, on those flights as well, the above is correct. That is your plane the whole way, so when can deplane, stretch your legs, and about 5 mins later, you can reboard! You might not want to check your bags though, small cities like BTV don't always know to look for connecting bags...
mhtoh
mmm...jet fuel...
