wilco
DCA Approach Question
Mon Aug 16, 2004 3:51 am
I'll be flying into DCA for the first since pre-9/11. I vaguely remember a spectacular view during final approach.
Does this view still exist AND which side of the plane is it on (assuming regular weather)?
WILCO
"Ever seen a grown man naked?"
OPNLguy
RE: DCA Approach Question
Mon Aug 16, 2004 3:56 am
This is what you're referring to:
http://204.108.4.16/d-tpp/0408/00443RIVER_VIS19.PDF
If you want to be able to look at DC and the monuments, etc., sit on the LEFT side of the aircraft, i.e. the captain's side. If you want to see the Virginia side, the Pentagon, and DCA itself (just before you turn short final), sit on the right (F/O's) side. They'll use this approach when the winds are out of the south. If the winds are out of the north, they'll be on a different approach, and DC will then be on the right side, and the other items on the left.
And, most importantly, if you're inbound to DCA and suddenly realize that you're seated on the wrong side of the aircraft relative to what approach/runway is in use and what you'd like to see, DO NOT arbitrarily get up and change seats. If you do so within the last :30 of the flight, post-9/11 regs dictate that everyone must remain seated during this time. If anybody gets up during the last :30, the flight diverts to IAD, and the security folks do their thing.
One thing that you might do is to, upon boarding, ask the flight crew which arrival is (or is likely to be) in use at your ETA. That way, you can change seats (assuming empties on the proper side are available) while enroute, and well before the :30 cut-off.
[Edited 2004-08-15 21:35:16]
pilotpip
Mon Aug 16, 2004 6:39 am
I was in the DC area in January, during a time of a code Orange security level and they were doing the river visual. Looks spectacular from the ground on the National Mall. I bet it's just as much fun from the air!
DMI
September11
Mon Aug 16, 2004 7:52 am
I went to Gallaudet University in Washington, DC. Landed and took off at DCA many times.
I can tell which DCA approach my plane will use about 20 minutes before landing. Air pattern is huge out there.
Airliners.net of the Future
