netdhaka
Cheapest Flight From MSP-DAC
Wed Aug 18, 2004 6:48 am
Can anybody please tell me the cheapest flight from MSP-DAC? Departing Dec. 18,2004 and coming back on Jan 16.2005.
The figure I am getting is very high and looking for a reasonable price.
Thanks (if you choose to read or respond.)
ushermittwoch
Wed Aug 18, 2004 6:54 am
Have you tried Biman from JFK via BRU to DAC and a cheap flight from MSP to JFK?
Where have all the tri-jets gone...
NWAFA
RE: Cheapest Flight From MSP-DAC
Wed Aug 18, 2004 6:55 am
How about in/out of AMS??
THANK YOU FOR FLYING NORTHWEST AIRLINES, WE TRULY APPRECIATE YOUR BUSINESS!
JBLUA320
Wed Aug 18, 2004 7:04 am
I couldn't price it for you, but Biman flies from JFK-DAC on Tuesdays and Saturdays. You could take Sun Country to JFK and then connect to Biman.
On the outbound, you can fly on 12/18, but due to availability and Biman connectivity, youd have to fly back to get your Sun Country flight on 1/18.
The Sun Country ticket for those dates is $250. I dont know how much the Biman tickets are (Cant figure out where to get a price), but presumably, the entire thing would be cheaper then the 3700 ticket I'm finding from Expedia.
Hope this helps a little
JBLU
cvgbear
Wed Aug 18, 2004 7:18 am
Netdhaka...good luck...this is the best I could find on our system.
Showing: lowest priced flights (45 flights out of 160 total) See all 160 flights
$2508
per person
Choose this flight
Leave
Thu, Dec 16 United Airlines 612
Depart: 10:00am
Arrive: 11:11am
3 stops Minneapolis, MN (MSP)
Chicago, IL (ORD)
Economy | 1hr 11min | Boeing 737 | View seats
Change planes. Time between flights: 0hr 59min
United Airlines 881
Depart: 12:10pm
Arrive: 4:25pm
Chicago, IL (ORD)
Tokyo, Japan (NRT)
Economy | 13hr 15min | Boeing 747 | View seats
No plane change. Time between flights: 2hr 5min
Fri, Dec 17 United Airlines 881
Depart: 6:30pm
Arrive: 11:25pm
Tokyo, Japan (NRT)
Bangkok, Thailand (BKK)
Economy | 6hr 55min | Boeing 747
Change Airline. Time between flights: 11hr 5min
Sat, Dec 18 Thai Airways 321
Depart: 10:30am
Arrive: 11:55am
Dhaka, Bangladesh (DAC)
Economy | 2hr 25min | Boeing Douglas MD-11
Total duration: 37hr 55min
This trip arrives two days later.
Choose this flight
Return
Sun, Jan 16 Hong Kong Dragon 111
Depart: 2:55am
Arrive: 8:15am
3 stops Dhaka, Bangladesh (DAC)
Hong Kong, Hong Kong (HKG)
Economy | 3hr 20min | Airbus A330
Change Airline. Time between flights: 1hr 10min
United Airlines 890
Depart: 9:25am
Arrive: 2:10pm
Tokyo, Japan (NRT)
Economy | 3hr 45min | Boeing 747 | View seats
United Airlines 890
Depart: 4:15pm
Arrive: 8:45am
Tokyo, Japan (NRT)
Los Angeles, CA (LAX)
Economy | 9hr 30min | Boeing 747
Change Airline. Time between flights: 3hr 5min
Northwest Airlines 312
Depart: 11:50am
Arrive: 5:37pm
Economy | 3hr 47min | Boeing 757
Total duration: 26hr 42min
travellin'man
Wed Aug 18, 2004 7:30 am
I have an unorthodox, slightly risky solution.
What I would recommend is making two interlocking separate tickets, one round trip between MSP and whichever port, be it LAX or JFK, that you will fly to DAC, and then that port to DAC; so one, let's say MSP-LAX (should cost about 300), and another LAX-DAC (should be as little as 1200). So you could get away with about 1500, which seems reasonable. Your luggage can be checked all the way through on the interline.
You run the risk of missing a connection between the two tickets. Let's say that you end up back in LAX late, and miss your onward connection to MSP; the airline on that second ticket is not obliged to rebook you, and you may be subject to fees, because as far as they are concerned, you simply showed up late and missed your flight. So what I do is schedule a lot of breathing room between the two tickets to make sure I don't miss my onwards flight on the second ticket. It is also a pain if you need to change your travel plans, because now you have two tickets to deal with.
If you can afford and plan for this risk, then go for it. I have done it several times internationally, and saved 50%. One time I went LAX to Dakar (which is generally routed via Paris). The whole ticket on Air France was 2200. The two separate tickets were 1100 for the same flight numbers! I got it even cheaper by flying United to Paris.
Bondhu, Ami Chittagong November 7 jabo! Khuda Hafeez!
It is not enough to be rude; one must also be incorrect.
iowaman
Wed Aug 18, 2004 7:44 am
Netdhaka,
Not sure of the prices your getting, I got $3,702.60 on those dates, with connections in BOS and LHR on the way and BKK and NRT on the way back. I got $1,940.25 leaving Dec. 18th and returning the 15th of Jan. with connections in IAD and LHR on the way and LHR and ORD on the way back, so if you could leave one day sooner from DAC you are looking at around $1700 savings.
