JCS
KLM Fokker 100 PH-KLG
Wed Aug 25, 2004 12:12 am
Here a mistake in our photo-collection, or did KLM use this livery also? (don't think so).
It deals about an ex-Air Littoral Fokker-100 which is still used by KLM: PH-KLG.
Here it is in "1993" or "early 1990's" with Air Littoral livery:
Photo © Frank C. Duarte Jr.
Photo © Frank Schaefer
Here it is in 1995 with KLM livery:
Photo © Jörg Tegen
Photo © Alastair T. Gardiner
However, in the pictures of this incident is mentioned this happened in 1997:
Photo © Chris Longhurst
Here another photo of the same year with KLM livery(8th July 1997):
Photo © Gábor Varga
Here two photos in 2004:
Photo © Gerry Hill
Photo © Tony Marlow
Google helps a little: http://aviation-safety.net/database/1994/940128-0.htm: the incident was not in 1997 but it was 28th January 1994.
Since Airliners.net is proud on the quality of their photo-collection I like to suggest to adjust this. Or am I wrong?
Sabena 690
RE: KLM Fokker 100 PH-KLG
Wed Aug 25, 2004 12:20 am
Don't know about the incident, but PH-KLG is indeed actif again, after being registered as G-UKFO (KLM UK). The aircraft got back its previous registration several weeks ago (just like all other G-registered aircraft).
Frederic
ua777222
Wed Aug 25, 2004 12:36 am
I'm looking at any database that I can find and nothing is coming up for KLM under PH-KLG or G-UKFO at all. Not even as the Reg. alone. KLM Cityhopper has only a Shorts 340 that had an issue is all that I can seem to find. NOTHING whatsoever under 94' or 97' or any year for that matter. And I would fine it quite hard for this incident to go unreported due to the nature of the accident. It's not like it hit a bird and taxied to the gate and then off to the hanger to get fixed. This probably closed the runway/airport for some time.
If anyone has any luck please post links.
Thanks and I'll keep looking.
UA777222
"It wasn't raining when Noah built the ark."
Titch
Wed Aug 25, 2004 12:44 am
Guys,
For details of PH-KLG's incident, go to http://aviation-safety.net/database/1994/940128-0.htm. It happened on January 28th, 1994.
Titch
I'll make weapons out of my imperfections
Crosswind
Wed Aug 25, 2004 12:45 am
The caption on the accident photos are wrong - the incident occured in January 1994, not 1997. The ASN reference is here This would tie in with the livery changes correctly - the aircraft most likely being repainted before returning to service after it had been repaired.
CROSSWIND
JCS
Wed Aug 25, 2004 4:33 pm
@UA777222
My search with "PH-KLG" (without use of other fields) resulted in many photos. Did you search for "KLM Cityhopper" or what?
Whatever, the year of these photos needs to be changed. That is it.
