Olympus69
NW Airlink CRJ Registration Help Needed
Wed Aug 25, 2004 7:57 am
I took a photo of a NW Airlink CRJ 200 or 440 in the new c/s and part of the registration was cut off by the winglet. Unfortunately NW does not put the fleet number on planes in the new colors. I need to know where I can find a current list of these registrations or if anyone knows what it might be. The registration ends in either 14E or 24E. Nothing in my 2004 Airlines book matches that. I've tried searching with Google without success. I also had no luck with A.net photos.
SafetyDude
RE: NW Airlink CRJ Registration Help Needed
Wed Aug 25, 2004 8:06 am
You could try this site: http://www.airfleets.net/home/index.php
 Smile
-Will
"She Flew For What We Stand For"
CRJmx
Wed Aug 25, 2004 1:06 pm
There are no CRJ's in Pinnacle's fleet that end in either 14E or 24E. Perhaps its ends in B? There is N8924B. That's the closest reg. to what you describe in the new colors.
Hope that helps.  Smile
When it hits your lips, it's so good!!
Olympus69
Thu Aug 26, 2004 3:33 am
The "4E" part is perfectly clear. However. the trailing edge of the wing is just ahead of that and only the bottom RH corner of the preceding digit is visible and I can't think what digit it could be other than a 1 or 2.
The airfleets site was no help as it does not include regional jets.
I guess I'll upload the photo, and if it's accepted I'll hope that the registration will be found later. If it's rejected The registration won't matter.
Olympus69
Thu Aug 26, 2004 3:41 am
CRJmx. I just figured out that the mystery digit could be an '8'. Do you know if N8884E is in the new colors?
