klmcedric
B777-223 , 212 , What's The Difference?
Wed Aug 25, 2004 7:16 pm
Can anyone explane to me what are these differences in the exact
same aircraft types?
e.g. for airbus: A330-223, 330-243, 330-201 etc.
for boeing: 777-223, 777-21H, 777-212, 777-228 etc
This might be a stupid question, but I'd like to think I'm here to learn!!!
CV990
RE: B777-223 , 212 , What's The Difference?
Wed Aug 25, 2004 7:24 pm
Hi!
The numbers in the Airbus hare related with the type of engines and maybe other particular issues, in the Boeing the numbers are a way to classify their clients, for example:
21 used to be for PAN AM
31 used to be for TWA
82 is for TAP
41 is for VARIG
So this means that for example VARIG buys a brand new 777-300ER it will be a 777-341ER, got it?
CV990, the Maserati of the skies!
7LBAC111
Wed Aug 25, 2004 7:25 pm
I thought it had something to do with the Engine designation?
Debate is what you put on de hook when you want to catch de fish.
ZKSUJ
Wed Aug 25, 2004 7:31 pm
I have always wondered but never thought much about it, but thanks for clearing it up for me.
DeltaWings
Wed Aug 25, 2004 7:38 pm
Try this link. It lists all the boeing customer number
http://www.plane-spotter.com/Aircraft/Boeing/Customer_numbers.htm#N
Enjoy
DeltaWings
Homer: Marge, it takes two to lie. One to lie and one to listen.
CV990
Wed Aug 25, 2004 7:39 pm
Hi.
In the Airbus I think it is, for example TAP they have their A319/320/321 with CFM engines so the models are A319-111, A320-214 and A321-211. If you see for example BA they have IAE engines and their models are A319-131, A320-232 and A321-231.
yokohama1970
Wed Aug 25, 2004 8:31 pm
Thank You Derek! Good Luck with the LA Dodgers
DeltaWings
Wed Aug 25, 2004 8:35 pm
thanks yokohama1970.
I dont know why my link didnt work
DeltaWings
ConcordeBoy
Thu Aug 26, 2004 3:16 am
With Airbuses it [partially] does.... it doesn't with Boeings.
For example, G-VIIO and G-YMMA are both 777-223ERs, even though the former is GE90-powered and the latter uses Trent800s.
Photo © Dinesh Maharajh
Photo © Tony Zeljeznjak
ZK-NBT
Thu Aug 26, 2004 7:17 pm
Think you will find they are both 777-236ERs!  Smile
Scorpio
Thu Aug 26, 2004 7:34 pm
For Airbus: the three numbers, in e.g. the -211 in A320-211 have the following meaning:
-first number is the sub-model of the aircraft: in the above example an A320-200
-second number is the engine manufacturer: 0 is GE, 1 is CFM, 2 is P&W, 3 is IAE, 4 is RR. I believe 5 will be the Engine Alliance (A380)
-third number indicates the versions of the model, after minor technical changes, or newer engine versions, higher MTOW, etc...
solnabo
Thu Aug 26, 2004 8:36 pm
SAS former B763 "Boeingnumber" is 83 IIRC (SK 767-383ER for example)...
Correct me if I´m wrong Big grin
Micke/SE
Airbus SAS - Love them both
Thu Aug 26, 2004 9:19 pm
Boeing and Airbus Codes can be found here, as well as other useful stuff:
http://www.rosboch.net/aviation#Codes (Shameless self promotion.  Big grin)
Solnabo, you are correct. SAS customer number at Boeing is 83.
FRALIM
Thu Aug 26, 2004 9:48 pm
So does that mean that the number changes when a Boeing Aircraft is sold to another airline? Or will it always keep the client-number of the first customer?
Thu Aug 26, 2004 9:56 pm
The plane will keep the client number of the first customer.
It can also be more complicated. The number designates to which airline's specs the plane was built. So if airline A ordered it but for some reason the aircraft, while being produced, gets taken up by airline B (merger, decision on part of A to not purchase the planes) the version number may be that of airline A even though airline B takes delivery from Boeing.
Hope that was confusing enough  Big grin
ConcordeBoy
Fri Aug 27, 2004 12:46 am
Yeah that, my bad Big grin
mindscape
Tue Aug 31, 2004 5:48 pm
Thanks guys for all your explanations !
But I have one question left regarding Airbus codification on A320.
Indeed, as Scorpio has explained, the first number is the sub-model of the aircraft; but what is the difference between A320-100 and A320-200 models ?
For the other Airbus family (e.g A330-A340), main difference between -200/300/500/600 concerns the capacity and therefore also the length of the aircraft. But what about the A320 family as the length are declining in 318/319/320/321 ?
777ER
Crew
Tue Aug 31, 2004 6:06 pm
Air NZs Boeing customer number is 19. When the new B777 and B7E7s arrive then it will be B777-219ER and B7E7-819.
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
ConcordeBoy
Tue Aug 31, 2004 11:05 pm
and B7E7-819.
Maybe not.
There's a general sentiment that Boeing will abandon the custom-model system (and therefore, the customer numbering system) with the 7E7.
SASBraathens
Wed Sep 01, 2004 1:50 am
A320-100 doesn't have winglets, -200 does...
