KAUST
What Is Wrong With This Picture?
Sun Aug 29, 2004 7:36 am
Please forgive my ignorance here, but what is wrong with the aicraft in this picture? (Also, as a newbie I might not be able to get the picture to show up correctly.)
See, I knew it wouldn't show up. I will just point to it then. It's the Air France CRJ in the "most popular" photos area. Says This "is what happens when you are taxiing behind and very close to an Iberia B747-400."
I cannot tell what is wrong.
KAUST
[Edited 2004-08-29 00:38:46]
"Houston, this is Apollo 8. We are now in Lunar orbit."
boeingpride800
RE: What Is Wrong With This Picture?
Sun Aug 29, 2004 7:38 am
I know whats wrong with it. It's invisible, I can't see it
KAUST
Sun Aug 29, 2004 7:40 am
Yeah yeah yeah....just don't say you haven't been warned haha.
hansieAMS
Sun Aug 29, 2004 7:42 am
The windscreen is damaged... not sure if that is something likely to happen when ur behind a 74
Horus
Sun Aug 29, 2004 7:43 am
Photo © José Ramón Valero - IBERIAN SPOTTERS
Horus
EGYPT: A 7,000 Year Old Civilisation
luv2fly
Sun Aug 29, 2004 7:47 am
Most likely stirred up lose gravel on the runway and onto this plane in question. Same thing as when you drive behind a dump truck on the freeway and it loses a rock or two onto your car and cracks the windshield.
leelaw
Sun Aug 29, 2004 7:50 am
You mean this one?
Lex Ancilla Justitiae
Espion007
Sun Aug 29, 2004 8:00 am
look at the Windows on the cockpit. Looks like some scratches on it from gravel
Snakes on a Plane!
Canarsie VOR
Sun Aug 29, 2004 10:20 am
I think the windshield is cracked into pieces yet stayed nicely intact.
EMBQA
Sun Aug 29, 2004 10:43 am
Well the pictures comment talks about taxing too close to a 747. My guess would be it cracked due to the heat from the exhaust.
skywestguy
Sun Aug 29, 2004 5:27 pm
Actually ive seen this happen before on one of skywest's Crj's, it was the windshield directly in front of the F/O. As I recall they said it just randomly started cracking inflight, I wonder how many times this has happened?
TupolevTu154
Sun Aug 29, 2004 5:31 pm
Probrably unlikely but...
Jetblast??
Please dont try to bite my head of if i am wrong  Innocent
TupolevTu154
EGGD
Sun Aug 29, 2004 8:35 pm
Just looks like its cracked in flight. I know this is not exactly a rare occurance, one of our resident pilots shared pictures from his recent experience of having the windshield shatter like this in flight. Apparently there is no real danger if it happens, and the aircraft can continue to fly normally until it has reached its destination where obviously it needs to be replaced.
Zortek
Sun Aug 29, 2004 10:05 pm
The windshield has started to delaminate. This can be caused by leaving the windshield heat on after landing but I have never heard of it happening while sitting behind a 747, but I guess that is possible.
L-188
Sun Aug 29, 2004 10:09 pm
It doesn't look like a rock hit from the outside, and I don't buy the explanation of engine heat from a 747....That CRJ would be airborne before the window would break.
Runaway window heat thermostat is my guess, not that I know a damm thing about CRJ's. But the local collage had a 747 window that was cracked for that reason.
cdfmxtech
Mon Aug 30, 2004 12:46 am
That isn't delamination. One of the panes is cracked. Could be impact damage amongst other things, such as the window heat problem.
baw716
Mon Aug 30, 2004 5:51 am
Looks like the side windscreen is shattered. It is possible that they hit a hailstorm at high speed (and crosswind at that), which can make the windscreen shatter. However, this would have happened at an altitude in which decompression would not be a factor.
I have seen this on another post on a.net...I just have to find the picture. It was front shot of an aircraft that had its forward windscreen shatter due to hail on the nose.
One never knows...
David L. Lamb, fmr Area Mgr Alitalia SFO 1998-2002, fmr Regional Analyst SFO-UAL 1992-1998
320tech
Mon Aug 30, 2004 7:49 am
The windscreen has cracked. Normally this happens in flight, I doubt it happened because of following a 747 (possible, though, I suppose). In the Dash-8 we had this happen a lot. It was due to an accumulation of water in the frame under the window, which would freeze at altitude and crack the windscreen. We put in drains in the frame, and the cracking stopped.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
242
Mon Aug 30, 2004 8:10 am
It's your average windshield heat damage, not exhaust heat from another aircraft.
Yawn..... Very common. When you work line maintenance, you'll see damage like this every few weeks.
I doubt it was caused by any sort of impact.
