777ER
Crew
Full On Emergency @ WLG, Possible Crash Landing?
Thu Sep 02, 2004 11:38 am
I have just got back from WLG and as I was leaving several Ambulances and Fire Engines were arriving under full lights and sirens. I stayed for a while and i asked an Aviation Security officer about whats happening and she told me a plane could be making a crash landing so the Emergency services and the airport rescue are all on full alert. Roads around the airport are being closed by the police.
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
dacman
Thu Sep 02, 2004 1:34 pm
Type of aircraft known? Airline?
Mike
lgbguy
"Airliner Photography is not a crime"
rongotai
Thu Sep 02, 2004 2:07 pm
Operations are normal at WLG. No current indications of any emergency in progress.
777ER
Crew
Thu Sep 02, 2004 7:19 pm
Dacman. Sorry I havr no idea on what airline or aircraft was involved.
Rongotai
I was at WLG at about 2pm because i was on my study break. I left to walk back to College at about 2.20pm when I was told of a possible crash landing. By 3.30pm all the emergency vehicles had gone.
ZKSUJ
Thu Sep 02, 2004 8:11 pm
So........Is everything alright? I haven't seen or listened to the news all day seeing as I have been at Tech.
ua777222
Fri Sep 03, 2004 12:19 am
Probably a hydraulic failure, in flight engine shut down, bird strike, you name it that would make this kind of response required. The a/c probably landed and then taxied off the active and into a stand or was towed into a hanger. Just a bit of over drama on the part of the security officer.
Just my 2¢
Thanks again.
UA777222
"It wasn't raining when Noah built the ark."
ultrapig
Fri Sep 03, 2004 1:38 am
Perhaps a sheep got loose ont he rumway and damaged a tire
JBirdAV8r
Fri Sep 03, 2004 3:02 am
Probably this thread is BOLLOCKS and should be closed....
Hearsay + Gossip = Mass Hysteria
777ER
Crew
RE: Full On Emergency @ WLG, Possible Crash Landing?
Fri Sep 03, 2004 6:33 am
Probably this thread is BOLLOCKS and should be closed.... JBirdAV8r... IF you can prove that this thread is bollocks then please do so. As you were not at WLG as the Emergency was unfolding then I don't think that you can.
NZ767
Fri Sep 03, 2004 7:34 am
Gee you're funny Ultrpig! Did you think of that yourself?
I've seen numerous emergencies here where the a/c has landed safely and then just taxied off to the terminal.
Better to be fully prepared than sorry afterwards.
Having said that though, a full emergency will be declared at WLG under circumstances that may not be justified at other airports due to:
* the short runway (1835 metres).
* no runway end safety areas (or whatever they're called).
* proximity of trolley bus wires, a major gas main and an arterial road at the northern end of the runway and a ring road at the southern end with a steep drop onto both.
* sea at both ends of the runway.
* high ground on the northern approach combined with often gusty conditions.
777ER, you must be at the same school as my son, Rongotai College.
Anything in this mornings Dominion?  Smile
Tristar100
Fri Sep 03, 2004 7:35 am
Re the last two replies, no wonder people are saying they will be leaving A-net!
Steve.
777ER
Crew
Fri Sep 03, 2004 9:04 am
Just read todays paper. The plane involved was the Wellington's Life Flight Trust Air Ambulance, a Metro Liner. The Air Ambulance was on a flight to Hastings with 2 patients and 9 passengers including the pilots. The plane on approach to Hastings when the landing gear would not fully extend. The pilot decided to return to WLG as WLG is better prepared for Emergency Landings. While en-route back to WLG the planes landing gear problem was fixed but all the emergency services remained @ WLG till the plane had landed safly. The plane landed without any problems. Once the landing gear was fixed the flight continued to Hastings
Photo © Frank Schaefer
NZ767
No I don't attend Rongotai College. I attend Scots College.
