JetJock
Why Is NW's A319 Reg's End With NB And Not NW
Fri Sep 03, 2004 5:43 am
Does anyone know why Northwest's A319's have the registrations of N***NB and NOT N***NW?? This is something that I cant understand why. If you know, please let me know. Thanks
azjubilee
RE: Why Is NW's A319 Reg's End With NB And Not NW
Fri Sep 03, 2004 5:58 am
Simple... if they used the NW suffix for the 319s they would end up with duplicating N numbers, which they can't have. To take that further, it stems also from the internal fleet numbering system NWA uses. For example... A320 ship #3201 has an N number of N301NW. If your logic was applied to the 319 fleet, ship #3101 would have the same N number of N301NW. So, NWA had to go with something different. Hope this helps.
AZJ
JetJock
Fri Sep 03, 2004 6:29 am
Thanks, yes that makes sense, and it helps alot! Thanks Azjubilee! Helps soo much.
CcrlR
Fri Sep 03, 2004 6:35 am
This is also true for ATA and AirTran. AirTran's is AT, but some of ATA's aircraft was in AT before they changed it. Now they are TZ as you can see on their 737's and 757-300s
"He was right, it is a screaming metal deathtrap!"-Cosmo (from the Fairly Oddparents)
SafetyDude
Fri Sep 03, 2004 7:03 am
I think the NW planes that end in "US" are even more awkward.
-Will
"She Flew For What We Stand For"
isitsafenow
Fri Sep 03, 2004 7:34 am
Try this....most of the A319's are leased from a company called
H N B corporation.....N B? hhmmmmm
I liked the Reg numbers ending in U S. It was a tradition by NW dating back to the Electra's of 1959. Northwest U S also included DC-8's, 707-320C, 320B, 720B, Electra's,
727-100's, 200's and equipment used today. I went to the prop book and so far have not found any NW props ending in U S.
safe
If two people agree on EVERYTHING, then one isn't necessary.
SafetyDude
Fri Sep 03, 2004 7:36 am
Perhaps tradition, but US Airways is better suited for "US" registrations, not to mention that the majority of US planes have "US" registrations.
-Will
PVD757
Fri Sep 03, 2004 9:50 am
I was once told it stood for the leasing company/bank that fronted the cash for the airplanes...Nations Bank, hence the NB?
FlyGuyClt
Fri Sep 03, 2004 10:02 am
There is no aircraft in the NWA fleet of N301NW. N301US is ship 3201 and was the first A320 to join the fleet in 1989. At the time. NWA Tail numbers all had US as the lettering (Original NWA that is). Needless to say when USAir at the time switched to this, NWA had to go with NW, NB, and even a 320 with an NA. (N350NA)
Safe Flying  Smile
Florida Express, Braniff II and ......
azjubilee
Fri Sep 03, 2004 10:15 am
There might be no N301NW, but it still illustrates the point I was trying to make.
AZJ
SATL382G
Fri Sep 03, 2004 10:42 am
When NW was using "US" there was no US Airways. US really wouldn't work for Allegheny or Piedmont, US Airways predecessors.
SATL382G
A330323X
Fri Sep 03, 2004 10:48 am
Just about half of US Airways aircraft have "US" registrations. (My count is just under half, 140/282, but I'm likely off.) About a quarter have "AU" registrations, about a quarter have "UW" registrations, and a lone 757 has a "VJ" registration.
Most of the instances where US has recently given planes "UW" registrations are where NW was already using the "US" registration.
I'm the expert on here on two things, neither of which I care about much anymore.
SafetyDude
Fri Sep 03, 2004 12:46 pm
Well, AU, UW, and VJ do not interfere with other US airlines or make things all that complicated compared to NWA with "US".
-Will
N1120A
Fri Sep 03, 2004 2:12 pm
Piedmont was not one of the first pieces of US. US bought Piedmont around the same era as PSA
FlyGuyClt
Sat Sep 04, 2004 4:29 am
Reply #9. You just hate it when a flight attendant knows more than you. A pilot! ! !
My point has now been made.
Safe Flying  Smile
You can always tell from the tail numbers at NWA when the aircraft were acquired.
NW-NB-NA All aircraft after about 1990.
US-All NWA purchased aircraft before 1990.
Whatever else, merger or acquired from EA. (ie) N8933E
Some merger numbers,
RW
NC
RC
N
L
And whatever else you can come up with.
NWFltAttendant
Sat Sep 04, 2004 5:40 pm
Ive always thought the NB stands for "New Bus", as in new airbus... just a little thought that rolled around in my head sitting on the jumpseat.
Go yakkin !!!!!!
FlyGuyClt
Sat Sep 04, 2004 10:13 pm
Some pilots have said that NB stands for one of the Checchi companies called "New Bridge." Could be true or could not be? Anyone know ?
Safe Flying  Smile
