COEWR2587
Question About 767-300ER
Fri Sep 03, 2004 11:08 am
To major airplane guru's this might seem dumb. But my question is, what are the differences between the 767-322 and the 767-336? I noticed it seems like only BA ans Qantas use the 767-336, as they are the only airlines in the system for it. Also, some 763's have 2 doors, while some have 4 doors. Is one longer than the other? Any help? Just wondering what the differences are in this model.
767-332
Photo © Gautam Changela
767-336
Photo © Peter Tsagaris
Newark Airport...My Home Away From Home
777ER
Crew
RE: Question About 767-300ER
Fri Sep 03, 2004 11:17 am
Boeing issues a customer code number. It is just the same model but with different last 3 digit numbers
Head Forum Moderator
moderators@airliners.net for all Moderator contact
DfwRevolution
Fri Sep 03, 2004 11:18 am
It's Boeing's customer code. You will notice that, abliet a few exceptions, no two customers share the last two digits of an aircraft's type...
Boeing 767-3XX (fill in customer code)
United Airlines is 767-322ER for example. Since different customers have different configurations, there are some slight differences
Alitalia744
Fri Sep 03, 2004 11:19 am
To answer your question, BA and Qantas operate the 767-336 aircraft. -36 is Boeing's customer code for British Airways. All Boeing aircraft have a two digit or combo number/letter code as part of Boeing's aircraft identificatioin system.
Qantas operates -336 aircraft as they leased/bought some of the B767's from BA after BA began reducing the type.
In terms of the door, the 767-300 is available with a number of configurations depending on airline preference. For example, the three configurations I know of:
X= Main/Large Entry Door
Y= Smaller emergency exit door
Z= Overwing emergency exit
1) XXYX
2) XXZX
3) XZZX
Hope that helps/makes sense.
Some see lines, others see between the lines.
COEWR2587
Fri Sep 03, 2004 11:33 am
Would more doors equal less room for seats, if the aircraft is the same length w/ four types of configuarations?
fanofjets
Fri Sep 03, 2004 11:39 am
Just to clarify, the customer code remains with the aircraft even if it changes hands, as in the example of the ex-BA planes that migrated to Qantas. One can, thereby, determine the original owner of the aircraft.
Type "Boeing customer codes" into a search engine; several enthusiasts have posted extensive lists online.
The aeroplane has unveiled for us the true face of the earth. -Antoine de Saint-Exupery
CKT523
Sat Sep 04, 2004 1:09 am
I have noticed that on say the 762, the overwing exits differ dependent on the number of pax it carries, ie AA762, one overwing, and BY have 2 overwing as they carry 290Y. The same goes for BY 763's they have 3 main pax entry doors and a 757 type emergency exit aft of the wing, which is permanently armed. The 3 main doors are all used for boarding/deplaning with BY and this speeds up the turnaround process. Carriers such as UA, who have only 2 main doors and 2 overwing exits instead, do not need this major time advantage as they carry fewer pax in a 2 or 3 class config and have a bigger time window for turnarounds on routes like JFK-LHR than say BY on a LGW-SFB route. Just a thought.
jfkaua
Sat Sep 04, 2004 5:00 am
If one carrier has two different versions of a plane ex. domestic vs trans-atlantic do they get different customer codes?
CALMSP
Sat Sep 04, 2004 5:04 am
can someone confirm CO's orders for the 763's are the ones that were delivered elsewhere, and are noticeable as to which ones by having the R2 & L2 doors?
Sat Sep 04, 2004 5:09 am
Nope, but in these cases differences tend to be minor (seat arrangement for example) since the carrier wants the option of switching planes between missions.
Here's a list (shameless plug): http://www.rosboch.net/aviation under "Airliner Version Codes"
Blake
Sat Sep 04, 2004 6:19 am
Ba is the only airline to have ordered 767-300 models with RR RB211 engines. Some of those were leased/sold to Qantas. They carry the -36 customer suffix. I also think Brittania and BA were the only airlines ordering the Collins autopilot with switches to engage the center, left or right channel, instead of the push-buttons. However, Qantas switched the controls to push buttons after receiving the A/C from BA.
Also, BA never switched the ADI's displays from original mode to the newer dispalys with speed scales...any ideas why?
Sat Sep 04, 2004 6:25 am
I would speculate that this is to allow pilots to fly other types at the same time. Maybe the L-1011.
IIRC, SAS disables the altitude tape on the MD-8X PFD (SAS only has glass cockpits) in order to ensure pilots could fly both the DC-9 and the MD-80. Or at least that's how a pilot explained it to me.
ConcordeBoy
Sat Sep 04, 2004 6:35 am
*buzz* wrong!
Try again  Big grin
N1120A
Sat Sep 04, 2004 6:41 am
The reason BA did not change them is probably the same as why WN had Boeing program their 73Gs to read out like the steam gauges on the 732s, 733s and 735s so that they could keep the pilots on an "any plane, any time" system. Keeping older style readouts makes it easier for pilots to switch
Sat Sep 04, 2004 6:42 am
ConcordeBoy, do you remember that thread which tried to figure out what members were like in real life.
EDIT: My, but the search took a while:
Pbb152
From United States, joined Feb 2000, 339 posts, RR: 1
Reply: 6
Posted Fri Feb 13 2004 03:37:46 UTC+1 and read 2315 times:
10)Concordeboy is the smartest poster on a.net and sits by his computer waiting for people to make mistakes so he can correct them.
http://www.airliners.net/discussions/general_aviation/read.main/1399074/4/
:D
[Edited 2004-09-03 23:47:32]
ConcordeBoy
Sat Sep 04, 2004 6:46 am
no
ConcordeBoy sits in a room monitoring the forums waiting for someone to make a mistake
...were that the case, as if I'd have to "wait"?  Laugh out loud
Sat Sep 04, 2004 6:48 am
See Edit above. All in good humor Mr. Boy.
EDIT: To those who have not read it, that thread was among the funniest ever.
[Edited 2004-09-03 23:51:20]
ConcordeBoy
Sat Sep 04, 2004 6:49 am
Hmmm... poor Blake, he's new--- just saw that.
Guess I'll go ahead and be a softy:
China Eastern (Yunnan) also ordered the RB211 on their 767s  Big grin
Sat Sep 04, 2004 6:54 am
Ok waaaay off topic now but I'm on reply 17 and I'm in tears. Toooo funny!
Blake
Sat Sep 04, 2004 5:16 pm
I stand corrected on BA being the only airline having ordered for RB211 powered 767-300's, thanks for the update.
Do Chinese airlines just like the more rare engine/airframe combinations? If I'm not wrong this time, China Airlines was one of the few airlines choosing P&W engines on their A300B's.
On the cockpit CRT displays: BA could have changed to the newer version for it's complete fleet of 767's, 757's en 737 Classics, keeping fleet commonality.
I rather think it has something to do with ergonomics. I know they insisted on classic engine instruments for their own 737-400's after the British Midland crash of a 737-400 equipped with solid state engine instruments...
