777ER
Crew
Air New Zealand Flight NZ6315 On 3/9/04
Fri Sep 03, 2004 1:58 pm
Is NZ6315 a delivery flight for an A320 or a special flight? It arrives in AKL @ 5.15pm today
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/90,A319/20/21,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC
TG992
RE: Air New Zealand Flight NZ6315 On 3/9/04
Fri Sep 03, 2004 3:15 pm
Hmm.. I'm on a well-deserved holiday, but officially a flight numbered NZ6315 SHOULD be an International non revenue, positioning or planning service. Flight numbers 6000 to 6389 are set aside for that. International delivery flights have flight numbers 6390 to 6399 set aside for them.
Having said that, the Star A320 was supposed to be here around this time. So maybe it is.
777ER
Crew
Fri Sep 03, 2004 6:32 pm
Cool, thank you TG992 Smile
RobK
Mon Sep 06, 2004 3:57 pm
I have friends in NZ, one of whom is a pilot for Mount Cook on ATR's. A quick mail to him revealed that the aforementioned flight was B744 ZK-NBV performing a 'local' AKL-AKL then went on its way to SFO as ANZ8 shortly after.
Hope that helps you!
Rob K
Reporting live from downtown Dewsbury, West Yorks, UK.  Smile
NZ1
Crew
Wed Sep 08, 2004 8:13 pm
Hi RobK,
That is correct. NBV was performing a quick test flight after its scheduled C check, due to having the pylons removed etc. Just a routine test flight that happens regularly after heavy maintenenace.
NZ1
NZ1
