silverfox
SAA Blocked Windows
Sun Sep 05, 2004 6:14 pm
I drove past one of the SAA 747 t LHR the other day (didnt note which one) and noticed that there were several windows blanked out in the section between '1st class and the wing) ie the forwsrd BA Club world bit.
Any reason for this? I would saay there werer at least 7/8 so done
777ER
Crew
RE: SAA Blocked Windows
Sun Sep 05, 2004 6:29 pm
Most likly is where the galley is or it could be a toilet
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ
LHR27C
Sun Sep 05, 2004 10:56 pm
Like this?
Photo © Christopher Hammarborg
If it is the normal SAA configuration, then probably as 777ER says the central galley/toilet area. If you are curious have a look at the seat plans on SAA's website for the 744s.
Once you have tasted flight, you will walk the earth with your eyes turned forever skyward
SA7700
Sun Sep 05, 2004 11:04 pm
777ER is correct. The galley/cart lift section is on the right and towards the middle of the plane. On the left side there are toilets and the purser workstation. The stairs for the UD are also located here.
SA7700
When you are doing stuff that nobody has done before, there is no manual – Kevin McCloud (Grand Designs)
silverfox
Mon Sep 06, 2004 2:15 am
Thanks for the replies, and i apologise for the very bad spelling!!!! in the question
