Flying-Tiger
Beriev Be-200 Info
Tue Sep 14, 2004 12:14 am
Anyone able to provide some info about the Beriev Be-200? Technical data, current and expected customers, performance, assembly, missions, price...
Thanks in advance
Flying-Tiger
Flown: A319/320/321,A332/3,A380,AT4,AT7,B732/3/4/5/7/8,B742/4,B762/763,B772,CR2,CR7,ER4,E70,E75,F50/70,M11,L15,S20
9A-CRO
Crew
RE: Beriev Be-200 Info
Tue Sep 14, 2004 1:34 am
There were some talks that Croatia will get 2 BE-200 firefighters from Russia as a debt repayment but as of latest it seems that this was cancelled.
Although announcment of aquiring was made by goverment and cancellation is just rumor.
When once you have tasted flight, you will forever walk the earth with your eyes turned skyward...
Spacepope
As for current customers, Hawkins and Powers has an order for 8 of them, to be used for fighting forest fires. this is the same company that has lost a Herk and 2 Privateers in recent years.
Vimanav
Tue Sep 14, 2004 1:52 am
The Beriev-200 is a twin-turbojet plane, based on the military Albatros. It has a high-mounted swept wing with engines mounted above the center wing section. T-tail and pressurized 2-step boat hull with conventional airliner-style pilot cabin conclude aircraft appearance. Hull is divided into separate watertight compartments, keeping it afloat even if any two adjacent compartments are flooded. Unlike existing competitors, Be-200 fuselage is fully watertight.
Retractable tricycle landing gear allows Be-200 to operate from class B airfields. In its amphibian form it can operate from water surface deeper than 2m and wave height 1.2m (sea state 3). Water taxi speed is up to 50km/h, controlled by the stern water rudder and/or engines trust variation. The standard Be-200 uses Ukranian built 73.6kN ZMKB Progress D-436Tengines. Location of engines and mounts design allows to accommodate almost any turbojet (or turboprop) powerplant of sufficient power. BMW-Rolls-Royce BR-715-53 turbofan or Allison GMA-2100 turbofan are also considered as a custom option for production aircraft.
The aircraft has been designed and will be tested in conformity with FAR-25 airworthiness standards which will ease its certification under the U.S. Federal Air Register and European Air Register. Aircraft is equipped by all-weather navigation system developed specifically for this airplane by Allied Signal and the Russian Institute of Navigation Equipment.
Be-200 is built at Irkutsk. This production complex built aircraft from almost every design bureau (mostly military). The first static specimen was delivered in March 1995. The second Be-200 for flight tests passed live tests of its electrical equipment and hydraulic and control systems. Be-200 differs from other amphibian aircraft by its multi-functionality (without negative impact on performance in any role).
Russia's Ministry of Emergency Situations will be the main customer for Be-200. The Ministry is planning to buy 8 such aircraft by 2005. The aircraft will be used for search & rescue operations. The company is also in talks with companies in France, Greece, Algeria, Japan, China, South Korea, Malaysia, Australiaand other Pacific Rim states to mainly supply the fire-fighting versions of the Beriev-200.
Following roles may be performed:
Firefighting
Patrol Be-200P
Cargo-Passenger
Transport
Passenger
S.A.R.
Ambulance
Ecology control
Executive transport
Be-200ChS for Emergency Situations Ministry
Specifications / Basic Characteristics
Takeoff weight - 37200kg
Engine type D-436TP @ 2 X 7,500kgs thrust, kg
Maximum cruise speed - 710km/h
Economic speed - 600 km/h
Maximum range - 3600 km
Range with 6,500 kg load, 1850 km
Takeoff run (land/water), 640/820 m
Landing roll (land/water), 700/960 m
Crew - 2
Passengers/Attendant accommodation - 72/2
Hope this helps
rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
whitehatter
Tue Sep 14, 2004 2:00 am
I'm pretty sure I recall discussions going on with Airbus to provide marketing and support outside Russia for the Beriev.
That would be great as Beriev are the world's leader in flying boats, and should be doing much better on export sales.
Lead me not into temptation, I can find my own way there...
Alessandro
Tue Sep 14, 2004 4:05 am
Check out their homepage www.beriev.com
MAS747
Tue Sep 14, 2004 11:03 pm
malaysia airlines could perhaps use a couple of these as the Fokker 50 replacements, or the Dash-60 replacements
vfw614
Wed Sep 15, 2004 4:58 pm
In the recent edition of Airliner World there is a news item that says that a small Italian airline is looking into ordering 4 Beriev 200 for flights from places like Lipari island. Allegedly, they are also interested in taking as many as 15 2nd hand Twotter floatplanes (wherever one can source them...) for seaplane services around Italy. I seriously doubt that this is more than just a dream on paper, particularly as I really don't see a market for such an operation given the relatively good airport infrastructure in Italy.
9A-CRO
Crew
Wed Sep 15, 2004 10:55 pm
There is one Be-200 in Croatia now (russian colors).
tommorow it will give demonstrate water landings on sea.
maugie
Thu Sep 16, 2004 12:25 am
look for info at
http://www.irkut.ru
StearmanNut
Thu Sep 16, 2004 4:51 am
The Beriev 200 may bring back an era of viable medium range seaplane airline service.
If wishes were horses, a Tail Dragger I would fly...
