akjetBlue
What Happened To This Engine?
Thu Sep 16, 2004 7:32 am
I was wondering if anyone could shed some light on what happened to the idea of using this engine on civil comerical aircraft? The few people who I talked to and even knew about it said that it was very efficent and quiet. Even Embraer had an aircraft design using an EMB-120 with an extended hull with similar (but smaller) engines on the back positioned in the same manner...
Photo © Malcolm Clarke
Anyone rememeber this? Any info would be apperciated...
-Philzy
Save a horse! Ride a Cowboy!
Klaus
RE: What Happened To This Engine?
Thu Sep 16, 2004 7:40 am
According to many previous threads on the matter, the UDF program got cancelled due to the end of the oil crisis and due to several technical problems. Safety in case of blade separation and generally excessive vibration and noise seemed to be among those...
The question is if the UDF could even compete against modern high-bypass turbofan engines any more...
yyz717
Thu Sep 16, 2004 7:45 am
The UDF engine was test flown on a 721 and the above M80. I also recall reading about some resistance from airlines due to the "propellor look" of the UDF.
I dumped at the gybe mark in strong winds when I looked up at a Porter Q400 on finals. Can't stop spotting.
CcrlR
Thu Sep 16, 2004 7:48 am
It's a unducted fan engine. it's like the same thing as putting the blades inside, but they are out too and they counterrotate. Embraer did the same thing too.
here is the same thing with Boeing
Photo © AirNikon
"He was right, it is a screaming metal deathtrap!"-Cosmo (from the Fairly Oddparents)
whitehatter
Thu Sep 16, 2004 7:49 am
Efficient it was not.
The program was abandoned due to the early test data indicating a lot of design work and testing would be needed before anything viable could come of it. Ducted fans are much more efficient at higher speeds.
Boeing (or a related company) also fitted a 727 with a similar engine.
Lead me not into temptation, I can find my own way there...
FriendlySkies
Thu Sep 16, 2004 9:43 pm
The program proved to be too expensive, the engine was too loud (louder than a turbofan if you can believe it), and passengers get freaked when they see a prop...why, I don't know, but props have some magical ability to scare passengers.
Luxair
Thu Sep 16, 2004 10:34 pm
Just a question who came up in my mind, wasn't there
a Russian built Aircraft using such a kind of counterrotating
engines, I remember that I've seen it a few years ago but can't remember the details anymore, maybe somebody knows more about?
boeingnut
Thu Sep 16, 2004 10:45 pm
You're probably thinking of the Bear. Big Soviet turboprop bomber, used four engines, each with two counterrotating propellers. Thing was fast for a prop plane. It was meant to be the Soviet equivilent to the B-52
Excuse me, but what does God need with a starship?
Luxair
Thu Sep 16, 2004 10:59 pm
Boeingnut, you're right regarding the "Bear" but it wasn't that plane. The one I mean is more recent must be in the 90's!!! It was a high wing design as the IL-76 but a lot smaller and if I'm remember correct than it was more like a regional jet let's say more the size of a RJ-100 but than with only 2 engines instead of 4. I will try on Google to find something and let you know.
Luxair
Thu Sep 16, 2004 11:25 pm
Ok, I found something about, the plane I mean, is an AN-70
with 4 counterrotating engines, thus I have to correct myself on the fact that it was a 4 engined AC and not a 2 engined one  Smile/happy/getting dizzy The AN-70 is a prop driven one and the above mentionned ones are Jet driven, is that correct?
rg828
Thu Sep 16, 2004 11:47 pm
Its actuall the CBA-123, jointly developed by Embraer and FMA of Argentina.
Its just a normal pair of Garret turboprops in pusher configuration, not a UDF.
RG
I dont know the key to success, but the key to failure is trying to please everyone
BR715-A1-30
Fri Sep 17, 2004 3:40 am
The Engine was called the GE-36 It was scrapped before it even had a chance to be ordered. Another project off the drawing board.
Puhdiddle
RareBear
Fri Sep 17, 2004 4:05 am
Lockheed flew a Gulfstream GII in 1987 with an unducted propfan engine mounted on the left wing, with a counterweight on the right. It was a test program to develop the 6-blade Dowty propellor for the C-130J program.
Illegitimus non carborundum
Areopagus
Fri Sep 17, 2004 4:13 am
Well, what distinguishes a turboprop from a UDF? The swept scimitarlike blades? New C-130s have them. Blades driven directly off the turbine without gearbox? The Pratt competitor to the GE-36 had a gearbox.
keesje
Fri Sep 17, 2004 4:16 am
Heavy construction behind hot combustor, hot air exhaust around the blade angle adjustment mechanisms ... complex
A fan in front of the hot section would provide compressed cool air around the combustor, even if the plane is on the ground, maybe not a bad place after all..
 Smile
