JOSS21
732 What's With The Wire?
Sun Sep 26, 2004 3:01 pm
Why do some 732's have the wire connecting to the tail? What's it purpose and why don't any other 737 Classic's have this feature? Thanks for the replies.
Photo © Fergal Goodman
Photo © Frank C. Duarte Jr.
lnglive1011yyz
RE: 732 What's With The Wire?
Sun Sep 26, 2004 3:13 pm
Okay, not knowing MUCH about maintenance/ etc, I BELIEVE it is some kind of communications antenna..
I could be wrong......
1011yyz
Pack your bags, we're going on a sympathy trip!
wilcharl
looks like an HF antenna to me
wjv04
Sun Sep 26, 2004 3:58 pm
Is indeed the HF antenna
L-188
Sun Sep 26, 2004 4:03 pm
Yup, looks like every other HF antenna wire I ever put up in the Signal Corps.
trickijedi
Sun Sep 26, 2004 5:14 pm
Yes, the wire you see is an HF (high-frequency) radio antenna used in the 737 classics as well as some light aircraft.
I believe some Fokkers use them as well.
Its better to be on the ground wishing you were in the air than be in the air wishing you were on the ground. Fly safe!
L-188
Sun Sep 26, 2004 5:15 pm
Actually those wires would be a typical installation on HF radio aircraft made through say the 1970's when sombody figured out how to seal an HF antenna into a fiberglass fairing.
Sun Sep 26, 2004 5:43 pm
HF Antenna.The later versions its located in the Lower Leading edge of the Vertical stablizer.
regds
HAWK
