ktachiya
Downsizing, A Fad At YVR?
Fri Oct 01, 2004 11:33 am
Downsizing and revivials. I am sorry to talk too much about YVR but I just think its a wonderful airport (I can spot it now but I will sure miss it when I go back to Japan) But there are a few comments I would like to pose and I would like to get your feedback.
First of all, the SQ down-sizing. When did this route start as a 777-200ER? It was on many videos operated using a 747, but was there not enough demand? The same goes with Korean Air 071. When was this plane also changed to an 777 from a 744?
Revival of Malaysian airlines, will this be a likely case or no? With traffic increasing, YVR seems to be booming so I thought this could be a case? And also the Philippine 106, when was the shift of this aircraft to an A340 from a 744? Well I know that the company is in bad situation right now and can't blame them.
Dash-8, I have read in past posts of Air Canada getting the CRJ instead. Is this for spacing or approach speed regulations? I know the dash-8's are really slow compared to the CRJ's.
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
CO737800
RE: Downsizing, A Fad At YVR?
Fri Oct 01, 2004 11:43 am
SQ went from a 747 to a A340 then to the 777. I think it a few more years you wont see many SQ 747's anyplace. As for Philippines they went for a 747 to the MD-11 then to the A340. I think the A340 is a good fit for that route, I don't think it has enough demand for a 747. JAL is going from a 747-300 to a 747-400 and KLM went from a 767 to a MD-11.
Fri Oct 01, 2004 11:56 am
When SIA started flying to Vancouver, the only aircraft they had capable of flying trans-pacific were the 747s. But the loads were too little to make that route profitable.
Before the 777s came along, the next step down from the Jumbos were the A310s (SQ's weren't configured to fly that far). Now u know the route does not justify 747s so when they ordered the A340s for long haul low-density routes, the aircraft was perfect for it... but we all know what happened to the A340s!
And so voila! They were replaced by the 777s!
DYK
Fri Oct 01, 2004 12:37 pm
Ktachiya
As far as Korean is concerned, the bilateral between Canada and Korea is based on pre determined capacity. Korean and Air Canada agree on capacity or nbr of seats not frequency. I believe Korean downgraded to a 777 from a 747 as it allowed them to increase frequency into YVR as a 777 is a smaller aircraft allowing them to spread there allocated seats over more flights. The Korean ex YYZ & YVR flights should match the Air Canada flights ex YVR in terms of seats. Korean applied to the CTA for additional flights during the 2004 summer season and it was granted, they have also applied for additional capacity from YVR/YYZ for the winter months and I believe it is still pending. SQ is in different situation as they are restricted by the CTA on flights per week, My understanding is SQ would like to add an additional flight but under the current one year agreement but they can not. SQ must apply on a year by year basis to serve YVR via ICN.
Wish the Canadian Government will some day Change the Canadian Transportation ACt alowing for easier access into other airports outside of YUL/YYZ. Doubt it will happen anytime soon as I am also new to Vancouver and really like the airport. Has a great deal of potential but may never reach it due to the heavy retrictions placed on foreign carriers interested in YVR.
AC,CP,PW,WD,ND,UA,AA,NW,CO,DL,WA,AS,QX,PR,SQ,AI,TG,MH,JL,9W,IC,UL,PG,BW,NZ,QF,DJ,BA,LH,KL,OA,OS,ME,RJ,HA,AQ
as739x
Sat Oct 02, 2004 12:32 am
PR is a A340 cause the flight continues on to LAS3 or 4 days a week. YVR doesn't seem to have the filipino pop. to fill a 747. Even SFO get a lot of A340, and we have a filipino pop. 3 times the size of YVR. Downsizing a city is when you lose more flights. Airlines are being smart by using more efficiant plane, not that they have them
ASSFO
DYK
Sat Oct 02, 2004 1:15 am
As739x
"PR is a A340 cause the flight continues on to LAS3 or 4 days a week. YVR doesn't seem to have the filipino pop. to fill a 747. Even SFO get a lot of A340, and we have a filipino pop. 3 times the size of YVR. Downsizing a city is when you lose more flights. Airlines are being smart by using more efficiant plane, not that they have them"
No exactly correct. The Vancouver Philipino community is certainly not the largest in NA but it is one of the fastest growing Philipino communities. Keep in mind there are several Philipino communities accross Canada and the flights from YVR to Manila collects passengers connecting from domestic flights arriving from such large Canadian-Philipino communities in Winnipeg and Toronto. There are also a lot of Seattle passengers connecting to this flight as well. Phillipines Airlines has been very happy with the loads ex YVr and we are looking at a posiibilty of a YVR turn around flight summer 2005.
warren747sp
Sat Oct 02, 2004 6:54 am
CI and BR still flys 744s. But I don't see it lasting much longer as CI will replace JFK service with 744 instead of the dreaded 343. I think they will switch to A343 service to YVR next year as well.
747SP
ktachiya
Sat Oct 02, 2004 6:58 am
But with the large amount of business men flying on this route, don't you think CI should be happy with it? I heard that their routes are pretty packed along with BR. Well eitherway, I know JL is going to keep their newly brought in 747-400
Airbus Lover
Sat Oct 02, 2004 9:14 am
No Ktachiya, you won't see any MH in the near future.
KE used to fly into YVR with a B744 but when their code share with AC expired they increased frequency and changed to flying the B772. Summer 2004 they operated an extra flight as per granted by Transport Canada.
CI and BR's flights are always packed indeed and BR is seeking to increase frequency. During peak seasons you have to book in advance of up to 1/2 a year and often times even so you are on waitlist (for Y and Deluxe Y). Their front cabins are often fully occupied as well but their F is less so. C is doing good for BR.
However I noticed on NRT/TPE/ICN to YVR flights in C class, that mainly it is not business travellers. It's those that visit family or fly between work/home and family (most normally their children studying in YVR and wives accompany children). So I'd think the traffic would mostly consist of those flying for social reasons, ie. the ties.
b-hox
Sat Oct 02, 2004 11:10 am
Loads on TPE-YVR on CI are strong year round.....i doubt it will be degraded to an Airbus A340 service........
Luthansa used to send 747 classics to YVR....then it had a mix of B744/A343 and now the A346... they will go back to an A343 in the winter...
Over the years there a lot of new international airlines that have begun new services into YVR... (this summer China Eastern ) as well on the flip side that there were airlines the withdrew... (Qantas, MH to name a couple)
In my opinion I think YVR has room to expand to more connecting European cities such as Paris, Zurich...and strength their name as a gateway to Asia...There are currently no aircraft to fly to SYD from YVR direct except for AC's A345 however there is on 2 of them in the fleet rite now... I also think there is potential to expand into Southeast Asia...BKK, SIN... so yes YVR has so much potential to grow especially with the 2010 Olympics
