changyou
SQ's A340-500.
Wed Oct 06, 2004 1:36 pm
Just spoken to the cabin crew management this morning. Here is something might interest you guys...SQ is considering dropping the A340-500 for B777-200LR when it comes in service. According to SQ that the A340-500 is not very fuel efficient as what airbus industrie claimed. So I guess the history of Boeing buying SQ's Airbus' might repeat.
bill142
RE: SQ's A340-500.
Wed Oct 06, 2004 1:58 pm
well my sisters, best friends, boyfriends brother's, mate told his mate, who told his brother who told my sisters best friend who told my sister who told me that SQ were happy with the A345.
I would like a more reliable source then that. Rumors on this forum have said that SQ wants to ditch them and there are rumors floating on this forum that suggest SQ is happy with the airbus.
I won't believe any of it untill SQ orders 772LR's and uses them to replace the A345.
And yes I was taking the piss...
ktachiya
RE: SQ's A340-500.
Wed Oct 06, 2004 2:19 pm
Changyou
Is the 777-200LR capable of the EWR route though? I know that with the range, they can do it but is there any limitations with the E-TOPS? I agree that the 777-200LR is more fuel efficient.
But I also have reliable sources telling me that when Airbus designed the A340, 330 series, they thought that four engines instead of two will assure the passengers along with a pilot that its safe. I know that three engines can go down, but the risk should be better than a twin engine.
I reckon that even if there is E-TOPS on the 777-200LR, if one engine goes out, the pilots would get very nervous about it. Plus, they are brand new planes......... But as Bill142 states, we have to wait and see what happens.
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
baw716
RE: SQ's A340-500.
Wed Oct 06, 2004 2:33 pm
Two points:
I have not heard fuel efficiency comments about the A345. I HAVE heard them about the 346 (specifically CX whining that they are not getting the range performance they wanted and are having to weight restrict the JFK-HKG flights).
It would surprise me greatly to hear that SQ would have problems with the 345, given the fact that it only has about 180 seats. Standard configuration is about 240.
Second, the 777-200LR will probably be rated for 240min ETOPS. If that is true, then there should be no trouble flying the westbound polar route from EWR to HKG. If it is limited to 180, then it will have to fly further west to keep ANC within the three hour limit. Eastbound, there would be no ETOPS limitation, because the current route flies closer to the eastern coast of China, then up over Siberia before transiting the pole just north of Barrow. All of this fits within the 180min ETOPS currently in place and if Boeing gets the 240 min with the 772LR, then it won't be a problem at all. In fact, that aircraft will be at least a 10,000nm aircraft, which should make it between any two commercially viable points in the world... If the 777LR even comes close to what Boeing says it will do (and usually Boeing understates the performance), then watch a number of carriers (not just SQ) line up to order them, since it will be able to do both LHR-SYD and JFK/EWR-SYD nonstop without blinking.
Let's wait and see. Oh, and if someone has factual info re: SQ and the A345, please pass it along.
David L. Lamb, fmr Area Mgr Alitalia SFO 1998-2002, fmr Regional Analyst SFO-UAL 1992-1998
aerosol
RE: SQ's A340-500.
Wed Oct 06, 2004 2:35 pm
I guess it is the same guy who knew Virgin was definitely going for the 777.
brons2
RE: SQ's A340-500.
Wed Oct 06, 2004 2:39 pm
Baw716,
The current stated range of the 777LR is 9420 nm, not 10000 nm as you say.
Firings, if well done, are good for employee morale.
ktachiya
RE: SQ's A340-500.
Wed Oct 06, 2004 2:41 pm
Yet Brons2
Look at what happened to the 777-300ER? It flew more than they stated, so an additon of 580 nm is possible on the 777-200ER. Again, we have to see their test flight.
airxliban
RE: SQ's A340-500.
Wed Oct 06, 2004 3:20 pm
I doubt Airbus is this inane. High tech twins are a la mode and the chance of both engines going down on a twin are virtually nil.
We've had multiple discussions on 2 v 4 in the past and I've started a few threads on it myself.
changyou
RE: SQ's A340-500.
Wed Oct 06, 2004 6:01 pm
I don't mean this to turn out as a A vs B or 2 vs 4. That was what I was told by my colleagues. Doesn't matter if you buy this news or not. Still have a couple of years till the 1st 772LR roll out. There's no point for SQ to shout it out to the world about this rite now anyway. Aerosol...No I'm not that guy. I have no interest in VS. Cheers!
N1120A
RE: SQ's A340-500.
Wed Oct 06, 2004 6:15 pm
Um, the 772LR should roll out in 2005 and will go into service with PIA in early2006
Udo
RE: SQ's A340-500.
Wed Oct 06, 2004 6:46 pm
I have always been sure SIA would go for the B772LR once it is available. They have become the largest B777 operator recently, with many more aircraft on order over the next years. Therefore it wouldn't make economic sense to keep a fleet of only 5 A340-500s. Switching to the B772LR means they can eliminate one type and simplify their fleet.
Udo
Me & You & a Plane Named Blue...
dutchjet
RE: SQ's A340-500.
Wed Oct 06, 2004 7:02 pm
Will SQ swap its A345s for 777LRs? We simply dont know yet, it will depend on price, terms, and whether SQ places a large followup order for more 777s of various types (along with 7e7s) or goes with Airbus on its next order with a mix of A345/A346s (and maybe the A350).....many (including myself) thought that SQ was about to place a large order with Boeing this past summer, but so far no news, so anything can happen. If SQ places a large Boeing order, the future of the A345 does not look good......nothing to do with the aircraft itself, but from a financial point of view, it is unlikely that SQ would maintain a fleet of just 5 A345s with a unique engine variant.
Why are the Leadership titles gone from the A345? This has been discussed, no definite conclusion, but it seems that certain newer members of SQ's management team simply did not like the name and the name was not catching on anyway, so it was dropped......new SQ marketing material simply refer to the aircraft as the A340-500. I dont think that dropping the Leadership name is an indication that the A345s will leave the SQ fleet, there are also rumors that SQ will drop the Jublilee tag from the 777 fleet and the Megatop name for the 744 fleet. Times change.
anxebla
RE: SQ's A340-500.
Wed Oct 06, 2004 10:47 pm
By the way.... Anyone can say how is the ratio of passengers in the North American routes with A340-500? Are they full? Cos I understand It's more expensive to do it non-stop.
AIRBUS 320 The world's most advanced single-aisle aircraft
f4f3a
RE: SQ's A340-500.
Wed Oct 06, 2004 10:48 pm
I doubt that SQ will get rid of there A345 so soon. Yes they are a large 777 operator but they also seem to like to have both boeings and airbus. The a345 does a specific job for them and does it very well. I also think that 180mins etops is enough and even if the FAA certify it im not sure that the rest of the world will. The JAA are moving back towards four engines so they might not approve 240mins. Im pretty sure that SQ is run in accordance with the JAA not the FAA.
Also SQ is getting a380 and even possibly some a350s (since they havent placed an order for the 7e7 and the a350 is meant to be bigger)
I think people are rather quick to follow rumours. These rumours can be pretty convincing. For example a friend of mine who is a virgin flight attendant was convinced that virgin was getting 777 until i showed her the news that branson had ordered a346. So unless theres something more concrete lets just wait and see
nethkt
RE: SQ's A340-500.
Wed Oct 06, 2004 11:06 pm
Hope Thai airways will buy all of EX-SQ A345s!
TG really needs new aircraft with the best IFE onboard!!
N79969
RE: SQ's A340-500.
Wed Oct 06, 2004 11:11 pm
F4f3a,
You made quite a few statements on what various civil aviation authorities would or would not do. What are you basing your opinions on? Why is 180 minutes "enough" and why are you pretty sure that Singapore follows the JAA?
MD-11 forever
RE: SQ's A340-500.
Wed Oct 06, 2004 11:24 pm
Just to add some facts regarding the mentioned ETOPS approvals.
First of all, the fact that the FAA or JAA/EASA certifies an aircraft for a certain ETOPS limit does not mean that every operator is automatically allowed to take advantage of the limits. It lieas within the local authority to grant the operator the ETOPS time. Therefore if the FAA certifies 240 ETOPS, does not mean that for example SQ can start with this ETOPS time from day 1 of operating the aircraft. The authority will grant the limit based on review of all necessary reliability and maintenance data available for this operator. Of course, in SQ's case, there is already a large database available, since they operate a 777 fleet under ETOPS already. But I would assume that an airline who has no history in operating under ETOPS rules has to start with a lower limit and get it increased as long as the reliability trends show that their system is capable to operate and maintain the fleet to the required standards.
Cheers, Thomas
zvezda
RE: SQ's A340-500.
Wed Oct 06, 2004 11:27 pm
Baw716 writes:
"In fact, [B777-200LR] will be at least a 10,000nm aircraft, which should make it between any two commercially viable points in the world."
Actually, the B777-200LR should be able to operate with viable loads between any two commercially viable points in the world except LHR-AKL."
iowa744fan
RE: SQ's A340-500.
Thu Oct 07, 2004 12:44 am
Baw716,
You sure about this routing? I thought in the Airways magazine they showed on a map that they follow a more southerly route across Japan and then just south of Alaska to take advantage of having the jetstream. It is longer in total distance, but the increased speed with respect to the ground due to the jetstream makes up for it.
Dutchjet,
I hope that your rumours about the dropping of the Jubilee name are true. I have never liked that title at all! I am not too fond of the Leadership title either, but I much prefer that one to Jubilee. Personally, I liked the Big Top and Megatop titles. With the upper deck of the 747, those ones really hit off with me.
Finally, I doubt that SQ will be getting rid of the A345s in the immediate future. Perhaps wait a bit and see how they perform when PIA begins service, see that they are all they are cracked up to be, and then maybe make a purchase. If the performances are similar, I imagine that they would replace them to reduce # of aircraft types in their fleet. Of course, they also could use them as a bargaining tool to A and B. Tell A that they want to get rid of the fleet of 345s unless A offers them a really good deal on some 345s/346s. Or tell Boeing that they like the 345s and that they should offer them a good deal (maybe a trade in) on some 772LRs (or 7E7-8 or 7E7-9s) to get rid of the 345s. I think that these 5 aircraft can be used well as a negotiating tool...and something tells me SQ knows this and will take advantage of it!  Smile
Mr.BA
RE: SQ's A340-500.
Thu Oct 07, 2004 1:09 am
I'm not sure but the way I see it SQ doesn't put prices of aircraft as its first priority... if they don't like a certain type of aircraft or if it doesn't suit them they'll just get rid of it and they do it fast. I guess we've seen how capable they are of doing that?
[Edited 2004-10-06 18:15:41]
Boeing747 万岁!
Rj111
RE: SQ's A340-500.
Thu Oct 07, 2004 1:58 am
Yet Brons2
Look at what happened to the 777-300ER? It flew more than they stated, so an additon of 580 nm is possible on the 777-200LR. Again, we have to see their test flight
Because the 772LR and the 773ER are virtually identical in key specifications AFAIK the performance improvements from the 773ER have already been calculated into the 772LR's range, so it is unlikely we will see any ~significant~ performance boosts.
Add GRU-NRT/HKG to that as well, and the jury's still out on SYD-LHR.
Now that SQ have the 773ER, it makes complete sense to purchase the 772LR. However, SQ will want to be close with Airbus considering they're the launch customer for the A380, and scrapping the A345 will undoubtably piss them off..........Then again, it never stopped them in the past.
CPH-R
RE: SQ's A340-500.
Thu Oct 07, 2004 3:04 am
This is one thread I'd like to rank upthere with the "IB is going to dump their A340-600's" thread that made its rounds a while ago.
solnabo
RE: SQ's A340-500.
Thu Oct 07, 2004 3:25 am
Why bother???
Let SQ sell of the 5 A345 and buy the -LR, the got an all Boeing fleet anyway! Qantas can buy those 345 beautys...thank U mam  Big grin
Like LH, they are almost an all-Airbus fleet, exept some rusty 747/737OG* and in time they will be phased out.....thank U mam  Big thumbs up
Old Generation*
Micke/SE
Airbus SAS - Love them both
ConcordeBoy
RE: SQ's A340-500.
They just bought a dozen and a half of Boeing's most expensive model; on top of the 55 they have in service and the 4 additionals still on order...... um, how much larger did you want?!  Laugh out loud
...and we should care-- why?
...and your corroboration for this [rather ridiculous] claim is __________?
Leskova
RE: SQ's A340-500.
Thu Oct 07, 2004 3:27 am
CPH-R, combine that with the "VS will buy B777s and drop the A346" and "SAA is sooooo unhappy with their A346s that they'll replace them with 777s very soon" threads, and I'll agree with you... Big grin
Anyhow - one thing might be interesting to consider: does anyone think that Boeing will, again, offer SQ a trade-in-deal like they did with the A343 for the earlier B777 order? Considering the size of the market for the A345/B772LR, I somehow doubt that a similar offer is on the horizon...
Then again - let's wait and see.
Frank
Smile - it confuses people!
dutchjet
RE: SQ's A340-500.
Thu Oct 07, 2004 3:30 am
Point well taken ConcordeBoy.......however, there was speculation that aside from the 773ERs, SQ would also commit to versions of the 7e7 and maybe add the 772LR to the fleet. SQ certainly placed a big order, many were thinking that SQ was going to place a mega-order, which they have done from time to time in the past.
On the other hand, we dont know everything, SQ could have committed to the 7e7 and we simply dont know it yet?............
ConcordeBoy
RE: SQ's A340-500.
"they" will also be the launch customer for Airbus' crown jewel as well...
thank U mam
...perhaps you mean't ma'am?  Big grin
solnabo
RE: SQ's A340-500.
Thu Oct 07, 2004 3:34 am
Sorry C-Boy, its mam in swedish  Laugh out loud
solnabo
RE: SQ's A340-500.
Thu Oct 07, 2004 3:36 am
Fan åxå, I forgot the SQ A388.......Oopsie Daisy *LOL*
Micke/SE
ConcordeBoy
RE: SQ's A340-500.
Thu Oct 07, 2004 3:38 am
*tisk* Violation of Rule #2, shameful  Laugh out loud
solnabo
RE: SQ's A340-500.
Thu Oct 07, 2004 3:41 am
*coff....look whos talking...coff*
THE un-hypocritical Micke/SE  Big thumbs up
antares
RE: SQ's A340-500.
Thu Oct 07, 2004 4:28 am
In analyst briefings as recent as those post the full year financial results for Qantas we were told categorically that there is no possibility that the 777-200LR or any other jet currently proposed or under development is capable of performing SYD-LHR and vice versa with an acceptable commercial load.
Boeing has placed media stories that the jet would be able to do these missions from Perth or Darwin, but since it would still be a one-stop from the east coast Australia hubs it seems pointless. We think Qantas has also carefully assessed the A345 in its improved versions and at this stage been unable to come up with a compelling business case for the use of the jet on those routes.
I think such capability will be developed, obviously...., but when may depend on generating more than the handful of orders that would initially come from ultra long range routes targeting city pairs that are essentially on opposite sides of the globe.
SQ does indeed like the A345 from all indications and it has apparently been extremely useful in stripping high yield customers off one-stop competitors on the US-Singapore routes. But time moves on and the 777-200LR could not fail to be more advanced than the A345 bearing in mind it may not be able to operate across the southern polar routes, or fly the south pacific by the shortest possible distance or other special cases where single engine diversions are not an option.
CPH-R
RE: SQ's A340-500.
Thu Oct 07, 2004 4:33 am
Leskova,
I KNEW I had forgotten something - the VS 777 order had turned into a cliche, I wouldn't touch with a nuclear fuel rod, but the SAA A340-600 woes should have left in  Big thumbs up
warren747sp
RE: SQ's A340-500.
Thu Oct 07, 2004 5:02 am
It makes a lot of sense for SQ since they only need to maintain 2 types. The T7s and the A380s.
To my Swedish friend, maybe DREAMS DO COME TRUE!
W
747SP
solnabo
RE: SQ's A340-500.
Thu Oct 07, 2004 5:21 am
W747sp:
Whatever makes you happy  Innocent
Micke
