DutchFlyer
Airbus Withheld Information AA587
Fri Oct 08, 2004 3:23 pm
According to "de Telegraaf", a dutch newspaper, proof is found that Airbus technicians withheld information about their concerns regarding the tail. The documents found prove that Airbus technicians knew about the possibility that the tail could break off during flight, but did not air their concerns explicitly enough.
Unforntunatly no online information just the paper of this morning.
AirframeAS
RE: Airbus Withheld Information AA587
Fri Oct 08, 2004 3:42 pm
From what I have heard on a documentary, which I think is pure speculation, is that Airbus and AA are sworn enemies now since that A300 crash. Both companies have been finger pointing each other blaming each other for endless things. I think the documentary was on Dateline NBC.
777ER
Head Moderator
Fri Oct 08, 2004 5:59 pm
How many other A300s have lost their tails inflight? If this is true then there is a cause to concern for the other A300 flying the skys.
Head Forum Moderator
moderators@airliners.net
Flown: 1900D,S340,Q300,AT72-5/6,DC3,CR2/7,E145,E70/75/90,A319/20/21,A332/3,A380,F100,B717,B733/4/8/9,B742/4,B752/3,B763,B772/W,B789
With: NZ,SJ,QF,JQ,EK,VA,AA,UA,DL,FL,AC,FJ
N79969
Fri Oct 08, 2004 10:49 pm
The Wall Street Journal apparently is running a similar article although I have not read it. I cannot link it either. If it turns out that Airbus did know of a potential problem and supressed those concerns, that would be an appalling example of corporate irresponsibility. If they are smart, they will pass any other information along right away to JAA, FAA, and so on so that they can decide whether to issue an airworthiness directive or something similar.
It is strange how businesses do not learn from the Ford Pinto example of the 1970s. It must be one of the most cited business school case studies. In Japan, Mitsubishi motors may fold soon because of punishment for covering up a defect in their trucks which ended up killing a woman.
777ER, AA587 is the only accident of its kind of the A300 or perhaps any airliner.
aa61hvy
Fri Oct 08, 2004 10:53 pm
Perhaps it was just a faulty part on that particular plane. A300s take off daily behind 747s like 587 did. Perhaps its mutual in terms of who's at fault.
Go big or go home
mirrodie
Fri Oct 08, 2004 11:17 pm
You know, it coudl also have been just that particular defective aircraft, but then again, in the realm of investigation, such a notion would not be considered.
Forum moderator 2001-2010; He's a pedantic, pontificating, pretentious bastard, a belligerent old fart, a worthless st
aa61hvy
Fri Oct 08, 2004 11:26 pm
Defective aircraft just sounds wrong. Like a 'defective condom' in both situations, you're gonna be in some trouble.
Go big or go home
N79969
Fri Oct 08, 2004 11:27 pm
It may well have been just one airplane but that is not the issue. The issue is whether Airbus had knowledge of a potential saftey problem which it concealed from operators and regulators.
If there were concerns within Airbus, then that indicates to me that the potential problem would have been a design problem affecting the airplane type. If it were just one airplane off the line that worried them, then they could have worked with American with probably no PR issue whatsoever.
AA587 was under 10,000MSL so they were traveling under 250kts --well below Velocity-never exceed. Control inputs made that far inside the airplane's performance envelope should not cause catastrophic structural failure as it apparently did. I think American has a very strong argument that their pilot was not at fault.
Like I said, I have not read the article. My own theory prior to today was that a confluence of extremely unlikely events that Airbus, JAA, or FAA could not imagine or test for occurred simulataneously to cause the tail to snap off.
NYC777
Fri Oct 08, 2004 11:31 pm
If Airbus knew of a defect and did not put out a warning to regualtors (FAA and JAA) as well as airlines that use their products then they're going to be in a world of hurt. BTW, no way can the JAL 747 which took off before 587 can be held responsible. You will always have wake turbulence from any airplane. The 300s tail should have been able to withstand the turbulence as well as the pilots inputs in fighting the turbulence.
Airbus needs to own up to the omissions that they did not reveal.
That which does not kill me makes me stronger.
SXMbyKLM747
Sat Oct 09, 2004 1:35 am
there had been a similar incident in 1997 above Florida, although then the plane did not crash down. An internal report at Airbus was made about this, as was found out that quick movements of the rear rudder could cause such high pressures on the constructions that these could not cope with it. This document was recently found.
However, Airbus failed to correctly inform airlines and such. So in the end the pilots can not be blamed for this fault as they simply didnt know about the design flaw
/Robbert
(also read the article in Walstreet journal Europe)
MST/EHBK
flyabr
Sat Oct 09, 2004 1:46 am
what i find a little disconcerting is that all airbus planes have composite tails...not just the a300s!! let's just hope that when any of those planes go through a high g force situation that they are thoroughly checked afterward. something that wasn't apparently done with the a300 that crashed...
Ken777
Sat Oct 09, 2004 2:02 am
It would seem to my limiteds mind that Airbus faces one of two basic issues. Either the single plane was defective or there is a problem with the 300's design.
I remember reading after the crash that one or more parts that secure the tail were "defective" when they were delivered to the factory and Airbus "repaired" them and put them in the plane. This may well be the situation, which avoids the entire 300 fleet being considered unsafe. It does, however, put Airbus in a difficult position.
The one thing that Airbus does not seem to understand is the legal environment in the US - especially with trial lawyers. If there IS a problem with the series or individual plane then trial lawyers throughout the country will be drooling over the potential jury award. In many states (Texas especially) the juries are well known to express their feelings with a lot of zeros when establishing an award and Airbus is very much at risk, simply because they may not have rejected a defective part. If it is a series wide issue then you can add another zero or two.
jumbojet
Sat Oct 09, 2004 2:27 am
Aren't these planes tested in a million different ways by the manufacturer before even flying a single flight? I have seen pictures where wing structures are bent up at these unseemingly upsurd angles before they break. Surely, these or similar tests are done with the Horizontal stabilizer?
cedarjet
Sat Oct 09, 2004 2:29 am
AA587 is the new TW800 on this forum! I don't mean to be rude by shouting but there is a very important point that is never referred to in the myriad AA587 discussions that take place here:
THE RECOMMENDATIONS MADE BY THE NTSB ABOUT EXCESSIVE CONTROL INPUTS DURING WAKE TURBULENCE ENCOUNTERS AS A RESULT OF THE AA587 TRAGECY WERE ISSUED TO ALL BOEING OPERATORS AS WELL AS ALL AIRBUS OPERATORS.
Therefore in their opinion it could have happened to a 767. Those of you who think Airbus tails aren't as strong as Boeing tails should take great comfort in this. N79969: "AA587 was under 10,000MSL so they were traveling under 250kts - well below Vne. Control inputs made that far inside the airplane's performance envelope should not cause catastrophic structural failure as it apparently did. I think American has a very strong argument that their pilot was not at fault." I don't know if this is strictly true. No aircraft will tolerate infinite mismangement of the controls. I presume you have watched the CGI reconstructions which actually shows the control inputs as they were made - full deflection of the rudder back and forth, with at times full deflection of the ailerons, sometimes opposing the rudder movement.
Finally: the forces on the tail far exceeded the manufacturer's limits, in fact by more than double. There may be additional documentation coming to light about Airbus concerns about the tail, but in fact it failed at a point far beyond the published tolerances. If the tail had come off at a point below the published tolerance, Airbus would indeed be in a "world of hurt" right now, faced either with the grounding of all their planes in the US, or faced with having to replace a lot of tail fins. I doubt that this has been avoided because of commercial pressure (it's not as though Airbus are a US company), more likely cos there isn't a case for it. The pilots were irresponsible in their handling of an everyday situation, and paid a terrible price. Airbus should not have to.
gigneil
Sat Oct 09, 2004 2:30 am
That A300 had been in situations that stressed it beyond design maximums before... there's a good chance that just that airframe was damaged.
Concealing problems is common. Boeing held back on the 737 rudder for a long time... and nobody sued them for it. I think this will also pass.
N
NYC777
Sat Oct 09, 2004 2:51 am
If Airbus withheld valuable information relevant to the crash of 587 then they must be made to pay a high price to the victims. They should not be allowed to go scott free.
bennett123
Sat Oct 09, 2004 4:45 am
At the moment, we do not know who had concerns at Airbus and the nature of those concerns. I suppose that we have to assume that it concerns the A300 tail. We do not even know the extent of those concerns.
It is also a fact that any machine will break at some point, this is why design limits are set. If the A300 was unsafe, how is it that no other similar crashes have occured.
I am sure that the trial lawyers are drooling, did'nt MacDonalds lose a case recently because the Coffee was too hot and the customer burnt themselves.
I also remember a case some years ago, when a businessman went overseas on business, met a woman and died of "overexertion". His wife then successfully sued his employer for not supervising him 24/7.
It seems that proving fault is not required, you simply need a "good" lawyer
I think that we, (and the lawyers) need some facts. Once we know what if anything was concealed and the impact of it, then some rational debate is possible.
RIX
Sat Oct 09, 2004 4:49 am
”THE RECOMMENDATIONS MADE BY THE NTSB ABOUT EXCESSIVE CONTROL INPUTS DURING WAKE TURBULENCE ENCOUNTERS AS A RESULT OF THE AA587 TRAGECY WERE ISSUED TO ALL BOEING OPERATORS AS WELL AS ALL AIRBUS OPERATORS” - yes, as “confluence of extremely unlikely events”, as N79969 said, was considered to be the cause. What else could they do (like to remind once again, “try not to do sharp turns”)? But if Airbus had real concerns… that changes everything (like then it comes out that there were concerns about particular steering wheel design… and, indeed, no need to shout  Smile). Remember the Comet 1 crash before G-ALYP and G-ALYY (I think, it was YV)? Storm, turbulence, so on… but after the following crashes that one, too, was believed to have metal fatigue as a main cause. Disregard whatever measures/recommendations were taken before.
” That A300 had been in situations that stressed it beyond design maximums before...” - might very well (hope so) be that particular airframe problem. Which doesn’t change anything about possible “manufacturer concern” issue.
”Boeing held back on the 737 rudder for a long time” - did Boeing “withheld information“ similar way before doing something? Then I’d be surprised why nobody sued them…
knoxibus
Sat Oct 09, 2004 5:00 am
Well we have a whole department called "liability" here in Airbus, and everyday they warn us about the importance of what we write in e-mails and stuff.
We are now fully aware of what we call the "You did not write down in the manual that it was forbidden to do a full loop with the aircraft" type of suing...
It's like that woman that put her cat in a microwave and sued the manufacturer because it was not written anywhere that it wasn't made fro drying cats.....
Anyway, if you do a little research, you could find a post from Starlionblue I believe (sorry if I'm wrong) in which he linked the report from NTSB or something similar, that proved that the aircraft suffered from severe actions on the rudder through pilots' commands, and that it failed at a far greater safety coefficient that it was supposed to fail normally, so............
And surely the NTSB would have issued some warnings or stuff when doing the investigations, and supposedly discovered some wrongdoings by A.
No matter what anybody tells you, words and ideas can change the world.
spacecadet
Sat Oct 09, 2004 5:02 am
Because there's no such thing as a "defective aircraft", at least not in the implied terms here. There could be a particular part that's defective, but something, somewhere, caused that defect. It is not acceptable to say "in our manufacturing process, there is the possibility that 1% of all parts we make will be defective during manufacture, will not be caught in the QC and testing process and could cause a crash." Such a manufacturer would not be certified to build airplane parts.
All parts are tested and inspected prior to being installed. If the manufacturer made a mistake, they will be held accountable. If the inspection team made a mistake, they will be held accountable. If the design team made a mistake, they will be held accountable.
There is no situation in which you can just say "oh well, defective airplane, these things happen". There is a reason why defects are introduced into the process, whether it be because of poor design, poor manufacturing processes, poor inspection, or poor maintenance.
Anyway, if you've been following the NTSB's investigation (which has been a very public investigation), I see no chance that any part on this plane was defective. The NTSB has clearly been looking at both AA pilot training, the actions of these particular pilots, and the design and certification process of the A300. My guess is still that some combination of these factors will be blamed in the final report, which is due (I think?) at the end of this month.
And yes, the NTSB does check for defects, and many crashes have been caused by and blamed on defective parts (check the Sioux City DC-10 crash for one example). The NTSB did check the bolts, the mounts, and the composite material itself on this particular tail for defects. But there are supposed to be procedures in place for keeping defective parts out of airplanes anyway so if a defect causes a crash, it means there was a systemic breakdown somewhere in the process; the part itself is not the root cause of the accident, the breakdown in the system is the root cause of the accident.
ltbewr
Sat Oct 09, 2004 5:22 am
I think part of the problem as to AA587 is that the tail here had an extensive amount of composites and investigative agencies have little experience with composite material structural failures. The NTSB had to send out samples of the tail structures to specialized labs for testing in this investigation. There is also the developing issue of how to inspect composite materials for fatague, damage vs. those for traditional metal materials where inspection techniques are well established. One question I have is how are the tails on A300 series a/c intergrated into the rest of the fusulage vs. how other airlines (ie: Boeing) do it, especially when composities involved?
magyar
Sat Oct 09, 2004 5:59 am
Dear Knoxibus,
These type of allegations are not the only ones
that AI may have to face (beyond of course the
real issues concerning airbus planes). If the
transatlantic trade spats go dirty, the AA587 accident
could be very handy for some to hurt airbus, regardless
whether they were responsible for it or not.
N79969
Sat Oct 09, 2004 11:34 am
"Boeing held back on the 737 rudder for a long time... and nobody sued them for it. I think this will also pass."
Gigneil,
Boeing did not hold back about a known problem on the 737 and they did get sued after the 1994 USAir crash. Check your information.
Cedarjet,
If there was a problem with a rudder use at low speed, then Airbus had a duty to placard that information in the cockpit and/or amend the Airplane Flight Manual. I have not seen the reconstruction in a long time. If I recall correctly, I do not know if the pilot could tell how much rudder deflection was actually being applied through his own input. In other words, what may have been light rudder use in the cockpit may have been full deflection.
The A300 was subjected to extreme forces somewhere well within its normal performance envelope in a pretty normal flight profile. How did that come to be?
Bennett123,
You seem to trivialize the gravity of the situation. If Airbus did not disclose information regarding a potentially serious problem with one of its airplane to operators and the authorities, then it failed in its legal (and moral) obligations.
To compare this situation with some frivolous bs lawsuit is simply absurd and shows a certain amount of conceit on your part.
Gregg
Sat Oct 09, 2004 12:32 pm
Boeing did not hold back known problems with the 737 rudder. The analyzed the data for a long time, and didn't find any issues. So they started running actual senarious on the valve that positions the rudder (not sure on the proper name of the valve.) They found once instance where freezing the valve at temperatures below that normaly seen in flight, for times not seen in flight, caused a problem that could in rare cases cause a rudder over.
Within a few hours of finding this out, they contacted the FAA, and scheduled a meeting for the next day. It still isn't clear if this valve could have caused the accidents.
bennett123
Sat Oct 09, 2004 11:24 pm
N79969
I am not trivialising anything.
If you read reply 11, KEN777 referred to the interest of trial lawyers, I was merely making the point that they can "find" blame even in the most implausible situations.
You might also re-read reply 18.
If Airbus knew that there was a problem, then they should have told the Airlines/Regulators. We have yet to see evidence of this this.
The A300 Tail has design limits, (like anything else) these are not intended as guidelines. I assume that you have read reply 14.
N79969
Sun Oct 10, 2004 3:27 am
Bennett123,
You compare the issue here to several asinine lawsuits. What trial lawyers will or will not pursue is not the issue here. But you brought it up as if it were relevant to whether Airbus may have hid information.
Reply 14 is false in its entirety. It is made up or completely uninformed or both. I agree with you-- if Airbus knew there was a problem then they should have told have airlines/regulators. That is subject of this thread and there seems to be some indication that they did not disclose a concern they had.
Have you ever piloted an airplane of any kind? If you are not supposed to use the rudder in certain conditions, it must be on a cockpit placard or in the AFM or in both. In any case, the airplane was in a normal flight profile and well within in its performance envelope when a major structural failure occurred. As I pointed out, there is some evidence that the pilot could not have known how much rudder deflection was being created based on his control inputs.
Rj111
Sun Oct 10, 2004 3:59 am
Just to clear a few things up.
The A300 which crashed on that day experienced pressures on the tail that exceeded the "ultimate load" (the maximum load experienced by a part of an aircraft under normal operating conditions + 50%, a design requirement on all modern airliners). This suggest that the plane was not "faulty". However IIRC a SV A310 (which uses the same tail as the A300) at SVO experienced similar pressures to the AA587 on its tail but didnt disintigrate and landed safely.
AFAIK, the argument Airbus held was that it was riduclous of AA to suggest using those inputs considering the circumstances and that any aircraft would suffer the same fate. AA on the other hand argue that they were never informed otherwise, thus they effectively trained there pilots "incorrectly".
A difficult one to call.
BR715-A1-30
Sun Oct 10, 2004 4:41 am
Not exactly, They had 2 crashes, but could not prove it was the rudder, because everytime they tested it, it was functional... Then the Eastwind Airlines 737-200 incident happened and the plane actually landed and they pulled that unit only to find that it could indeed fail. They then issued an A/D
Puhdiddle
KLMyank
Sun Oct 10, 2004 5:37 am
Fact: AA587 was below Va (Maneuvering speed to the non-pilots) a speed where you are supposed to be able to make a FULL control input without structural damage.
However, airbus seems to be suggesting that while this is correct, the pilot flying made 2 (or was it 3?) full inputs on the rudder to correct for the wake upset.
This is the kicker...is a Va control input one input or more? Nobody seems to be able to answer this.
Tragic, but seems to be one of those things in aviation that we learn from and move on.
