Deltacvg
Worst Airport Security Lines.
Mon Oct 18, 2004 11:59 pm
I've flown quite often in my day, more especially since 9/11. However, I have not experienced a worse airport for security lines than BWI. I don't understand the reasoning for this. Maybe it's because SW is there with a "lax" atmosphere? I don't know? I do know that some other major airports have great leadership and are designed better and flow smoothly. Maybe it's just the military in me and I'm inpatient, but I see a poor setup and lot of lazyness!
-Beat Army
ntspelich
RE: Worst Airport Security Lines.
Tue Oct 19, 2004 12:14 am
Everyday as I walk past the security lines, I too can't help but think that the lines at BWI seem pretty bad. I think it's because of two reasons though. 1.) they typically only have two metal detectors/x-rays going at anytime, at least on the B and C piers, although there's seven on the C pier that they could be using (I can't recall how many on B off the top of my head.) 2.) The way that the line zig-zags back and forth so tightly seems to be horribly ineffective. However, like most airports, the airport/security point was designed pre-9/11 and had to be modified to fit today's world. They just weren't able to come up with a good system for it. Maybe they need a Brit to come in and teach us how to queue properly.  Smile/happy/getting dizzy
BTW, I was at MDW yesterday and glad to see that they got rid of the moving sidewalks going towards the checkpoint. Did that eever make getting through security much easier.
United 717 heavy, you're facing the wrong way. Any chance you can powerback to get off of my deice pad?
7e72004
Tue Oct 19, 2004 12:22 am
when did they get rid of the moving sidwalks at MDW? Are they planning any modifications in terms of easing the security line dliemna?
The next generation of aircraft is just around the corner!
trickijedi
Tue Oct 19, 2004 12:49 am
In case you're curious, here's a topic somewhat similar to yours that was started in the Polls and Prefs Forum:
http://www.airliners.net/discussions/aviation_polls/read.main/21278/4/
Anyway, LGA and ORD seem to have the worse security lines IMO. Security seems to be a bit more vigilant at LGA (I can only imagine what JFK would be like nowadays, haven't flown out of there in a while) as they tend to open up almost everyone who goes through the lines. ORD's security lines seem to run much smoother... primarily due to multiple lines being open at the same time almost all the time in the daytime hours.
Its better to be on the ground wishing you were in the air than be in the air wishing you were on the ground. Fly safe!
ssides
Tue Oct 19, 2004 12:53 am
I'd have to say that BWI and ATL take the cake. Their chief problem is that there is only one central set of security lines for a large part of the airport. This is a problem in many older airports; the design just wasn't made for the post-9/11 world.
IAH is also pretty bad as well. For a smaller airport, AUS can have horrendous lines too.
DFW is generally pretty good. Even when the lines are long, they do a great job of getting people through quickly. I think that is the key.
"Lose" is not spelled with two o's!!!!
BCAInfoSys
Tue Oct 19, 2004 12:54 am
Don't forget SEA guys. SEA has just about anybody beat, I'd be willing to bet on that. Evn at average traffic times, not especially busy times, I am pretty sure to wait at least 30 minutes, if not 45 or so.
In contrast, SLC has the BEST security of any major airport I've been through. While the lines occassionally get long, they seem to handle them with ease and just breeze right through it. I mean, in Terminal 2 (DL), the line went past the escalators, across the little elevated walkway and all the way to the skybridge to the parking garage, but it still took less then 15 minutes to get then cleared. Bravo to SLC!  Smile
Steve
Militant Agnostic - I don't know and you don't either.
ssides
Tue Oct 19, 2004 12:56 am
I have also heard that the lines at LAS can be very bad. However, I've been there twice in the past year and haven't had any major problems.
US AIRWAYS
Tue Oct 19, 2004 12:58 am
The at B & C at PHL can be pretty long, especially at rush hour. I've seen the line extend all the way back to the entrance to the parking garage.
Jonathan
Go Eagles!
JAXpax
Tue Oct 19, 2004 1:45 am
Worst I've ever seen was this Saturday at Washington/National. The line for the center pier extended on either side 2/3 of the way to the next pier. Thankfully they were pulling people out of line to take to the front, however, they were doing so 25 minutes before scheduled departure time. I was in line for an hour, and made it onto my flight 3 minutes before scheduled departure time. No premium/elite line or anything, either.
geoffm
Tue Oct 19, 2004 1:59 am
I thought DFW was actually pretty bad. They had shoehorned security equipment into wherever it would fit (this was on an AA flight to LAS, don't know which terminal). Air conditioning didn't seem to work either. The net result was an overcrowded, squashed, stuffy screening area.
LHR T4 can be bad. I almost missed a plane due to public transport disasters, and had to jump half the queue - but even then it took 20 minutes.
Geoff M.
bsu747
Tue Oct 19, 2004 2:32 am
Can't vouch for other airports but on a recent trip stateside I would say that Terminal 1 at LAX was pretty bad at 5am in the morning and 4pm in the evening when I had flights to PHX last month it was 50-100 meters outside the door. (not so bad considering the weather was decent but if it were wet and cold!!!) Also PHX terminal 2 at 7-8am in the morning was pretty bad as well.
OK I know these might have been peak times for travel but it took the best part of an hour to get through the security checkpoint.
The airlines are going to have to clamp down on the carry on luggage that people take on as one of my flights LAX-PHX was not even half full with passengers when all the overhead bins were full, and one woman on a PHX-LAX flight had 2 suitcases, a laptop bag, a handbag and 2 plants as carry on. Can you imagine her at the checkpoint and then having to take her shoes, overcoat and belt off as well.
I tell you some people don't half complain about the security checkpoints and then go well overboard with the carry on items.
If everybody was forced to carry one small bag and one small bag only the security checkpoints would be so much easier to get through.
Flying may not be all plain sailing, but the fun of it is worth the price.
NW747-400
Tue Oct 19, 2004 2:39 am
During the late afternoon/evening at MCO, there is a huge line to get to the Southwest/AirTran/Delta terminals (gates 60-12*). At this time, Delta has half a dozen Song flights outbound, as well as a few 763/764 flights outbound to ATL and DFW. Virgin is also in Delta's concourse with 3 747 flights outbound. Not to mention the dozen's of WN and FL flights outbound and DL and DL Connection's other numerous flights. Took me 2 hours this weekend to get through security.
Cory6188
Tue Oct 19, 2004 5:08 am
LAX can be very bad, especially in T6. When I took CO from LAX-EWR in January, we waited at least 20 minutes just to get to the initial ID check before they would let us up the escalator, and then another 45 once we got upstairs.
fbgdavidson
Tue Oct 19, 2004 5:13 am
Usually flying out of IAD I get the later BA flight (9.35pm) and security is a breeze. One of my flights in the summer I took UA920, left IAD at 6.30pm and the line was the worst I have ever seen! It was filled all the queueing area and then went straight to the door of the terminal then looped the whole length of the departure hall!!!! I was in the line for about half an hour continuously walking at regular walking pace only stopping perhaps for 20% of the time, by my calculations that line was over a mile long!!!
ATLhomeCMH
Tue Oct 19, 2004 5:22 am
I agree w/ Ssides: ATL is definitely one of the worst. My average wait time in ATL always seems to range from 40-75 mins.
"The most terrifying words in the Engligh language are, 'I'm from the government and I'm here to help.'"-Ronald Reagan
iowaman
Tue Oct 19, 2004 5:58 am
LAS was really bad until the opened up more screening lines.
