Businessboy
Why Do Planes Get Dirty?
Fri Oct 22, 2004 3:26 am
Hey guys!
There has always been a certain something on my mind, i have tried to figure out why though only some few things pop into my mind.
Why do plnaes get dirty? The "blackiness" drainage effect under the windows really make the aircrafts look ugly..
Just look at this plane:
Photo © TTT
Can someone please explain why....
Thanks, BB
LOVE CONTINENTAL AIRLINES & LOVE BRITISH AIRWAYS
Iberia340600
RE: Why Do Planes Get Dirty?
Fri Oct 22, 2004 3:32 am
I am not sure but I believe the de-icing solution applied in the winter has a lot to do with it.
Visca Barça!!
Jkw777
Fri Oct 22, 2004 3:35 am
Weather might have something to do with it?
Think of it as your car.
Justin Big grin
jkw6210@btopenworld.com or +447751242989
Aviastar
Reversers thrust can be the reason:
Photo © Florian Trojer - TCAS
See also this interesting shot and the remark of the photographer:
Photo © Bernd Sturm
Aviastar
miamiair
Fri Oct 22, 2004 3:54 am
Grease and oil will happen into the slip stream, and they will trap and keep dirt. Also, dirt will stick to moisture...
European
Fri Oct 22, 2004 3:58 am
I don't really know, but maybe to do with the rain? Maybe there is something in the rain sometimes like a weak acid? Don't really know????
A example of a dirty planes is;
Photo © Anthony Cheng
Photo © Sebastian Vermehren
Ryanair i know is proberly caused by the engines!
Euro
Come on Ryanair! Come on BOH! BASE BASE BASE! Flying high in the skies...........
fbgdavidson
Fri Oct 22, 2004 4:37 am
Ask Air France, they must know  Big grin
That MK Airlines 747 is seriously mucky. From the thumbnail I thought it was a paint scheme!
air2gxs
Fri Oct 22, 2004 4:39 am
Why does your car get dirty? The same reason airplanes get dirty. Because they are exposed to the elements.
Smalbany
Fri Oct 22, 2004 4:44 am
Air is dirtier than you realize. Particles are in the air from both pollution and from dirt picked up by the wind. It collects on aircraft (and everything else for that matter). It concetrates under the windows due to water runoff patterns.
FJWH
Fri Oct 22, 2004 5:05 am
How often do planes get cleaned (the outside, on avarage)?
FlightS in the next 3 months: MSP, PHX, MEM, NCE, TFS, BCN. All round trips from AMS
bongo
Fri Oct 22, 2004 5:21 am
Dust, rain water, ocean salty mist, pollution
MDE: First airport in the Americas visited by the A380!
flybyguy
Fri Oct 22, 2004 5:34 am
I notice that Air Force One and other head-of-State planes are un-naturally clean. Do they have a hand scrubbing crew?
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
bongo
Fri Oct 22, 2004 5:37 am
Less use, permanent hangars and of course more frequently washed
OnlyWay2Fly
Fri Oct 22, 2004 10:51 am
I have a magazine from the early/mid 1970's. Has a great article about the TWA MX base at LAX and has photos and description of how aircraft on overnight layover always get washed before their morning flights. Times sure have changed.
Alas poor Western, I knew them well!
Silver1SWA
Crew
Fri Oct 22, 2004 4:36 pm
If you stand close to an aircraft, you will see the outside "skin" of the aircraft is not smooth over the entire surface. Especially around the windows, there are panels that appear to be layered. Sorry for lacking the technical terminology. Anyway, the point is, there are many surfaces, or areas that could easily trap dirt.
This pic somewhat captures what I am talking about. Look closely around the windows and you will see what I am talking about. I would think that would be a prime reason you see streaks unders and around windows of aircraft. Easy places for dirt to collect.
Photo © 737doctor
Where does this dirt come from? Well, engine exhaust, APU exhaust, natural crap in the air that is also responsible for making your car dirty, etc...
Pronto
Fri Oct 22, 2004 10:05 pm
Obvious reasons comparable to what gets your car dirty. Plus, there is exhaust, toilets, jetways - the list goes on. Also, just a note about aircraft like the VC-25s - Yes, they are probably cleaned immaculately on a regular basis - when I was driving a general, I was cleaning that vehicle every day!!
TW741
Fri Oct 22, 2004 11:14 pm
Dirt is in the air, dirt is everywhere. Especially in humid environment like clouds.
It is not like dust, actually it is rather greasy. Areas being very dirty: everything behind the engines (especially with the DC9's and 727's and all other acft with rear mounted engines) you could see the oily-greasy dirt very good, followed by the window areas, doors (pax+cargo). Most difficult cleaning is the nose/cockpit area plus the front sides of the wings, engine intakes - because of the insects sticking like hell to these parts.
The problem with cleaning aircraft is - it is mostly done manually. LH started in 1996 a fully automated "aircraft washing" but this was not succesful - even with the best programmed robots there where damages to antennas and so on. A pic of the "wash-robot Skywash" can be seen here: http://www.dynajet.de/showpage.php?akleft=1&subakleft=18&site=16&anident=49
Skywash covered almost 85% of the aircrafts surface, remaining 15% had still to be cleaned by hand.
Washing is an integral component for reducing fuel consumption. A "normal-dirty" 747 needs about 1% more fuel over a clean one. And this sums up.
Normally an aircraft should be washed after 45-60 days of operation. In case of areas closer to the sea or flying in dusty environments (volcanic areas) this can go down to 35-40 days. Usually washing is done with maintenance cycles.
Full wash of a 747 requires around 25.000 liters of water plus cleaning material and many many people....
Somewhere in Japan they are working now again with a "robotwash" since a couple of months. Robot-Washing takes about 2-3 hours for about 80% of the aircraft, remainder done again manually.
When you google a little bit with the words "aircraft cleaning" you do get some companies listed and some have pictures showing (small) aircraft cleaned manually.
=Tw741=
TWA - we showed you how good we have been!
ckfred
Sat Oct 23, 2004 2:46 am
I think planes that fly trans-oceanic routes are cleaned more often than planes that fly overland routes. Exposure to salt air will lead to corrosion.
As for why planes get dirty, think about sitting in a line of aircraft for departures, particulary behind planes with tail-mounted engines (DC-9, MD-80, DC-10, L-1011). Paticles from the exhaust will build up on the exterior skin of the aircraft.
DIJKKIJK
Sat Oct 23, 2004 2:50 am
Just imagine how much AF must be spending on extra fuel then....
Never argue with idiots. They will bring you down to their level, and beat you with experience.
zrs70
Sat Oct 23, 2004 2:53 am
The same reason that cars, dogs, cats, people, etc. get dirty. They are exposed to the elements.
18 year airliners.net vet! 2000-2017
AlitaliaMD11
Sat Oct 23, 2004 2:55 am
Hey
To me the Concorde always looked clean. When I got to tuch it, it was very smooth and no dust or dirt came on my hands.
Maybe when there is a lot of rain at an airport and mud flows over from the grass, and the engine blast picks it up and throughs it on the aircraft?
I have seen this happen.
I flew on a AF 744 from CDG-JFK, and we landed on a very unusal runway which was flooded do to the outside weather, I was so suprised that we landed becuase of the amount of rain! When we landed the engines and wheels picked up a lot of mud and through it on my window, as well as the rest of the fusalge.
No Vueling No Party
InnocuousFox
Sat Oct 23, 2004 3:14 am
"Why do planes get dirty?"
Where do you think all the little planes come from... a cabbage patch?
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
Paul777
Sat Oct 23, 2004 6:52 am
And I was thinking how nice no one had mentioned AF and their dirty planes, and someone did! At least some others were mentioned first. Like someone mentioned in previous threads, as long as they get me where I am going it really does not matter whether the exterior is clean or dirty!
MATTHEWKH
Sat Oct 23, 2004 7:22 am
Another thing to consider is the static charge the aircraft builds up while flying. As the aircraft speeds through the atmosphere, it builds up quite a static charge which actually attracts many of the pollutants and dust particles floating around.
As far as cleaning aircraft is concerned, different airlines have different cleaning schedules. Most airlines use a "wet-wash", which is basically a bunch of people pressure washing the aircraft with a light detergent, and agitating the dirt with mop heads placed on top of long poles. This method wastes a lot of water, and is not very environmentally friendly.
Some airlines are, however, switching to a method called "dry-washing". In this method, the aircraft is cleaned by using spray bottles and rags, and a lot of elbow grease. This alleviates all of the environmental concerns, quality of the clean is increased, and many overhead costs are eliminated.
God I love the smell of avgas in the morning!!!
greasespot
Sat Oct 23, 2004 7:48 am
When i school I worked for a company that flew a corporate 727-100. It flew Mon,Wed, and Fri. It got washed Tuesday and Thursday. Where I work now the 737 Halo's( The smudge of soot on the window belt caused by the thrust reversers) get washed 1 a week. The Whole A/c gets washed when it needs it.
GS
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
