PyroGX41487
777NG Range/payload Specs (a Clarification)
Sun Oct 31, 2004 3:29 am
I can't seem to find accurate information about this anywhere online, so I guess I'll ask it here.
The 777-300ER recently had a range boost to somewhere around 8,500nm, is that correct? If so, that would put it neck-and-neck with the range of the A340-500 (not SIA's 9000nm version that carries less pax)? If there was a topic on the forums about that, I missed it.
Anyway, if the 773ER has a range of 8,500nm, would that make it be able to fly A345 routes? Or is it only in competition with the A346?
Thanks!  Smile
ConcordeBoy
RE: 777NG Range/payload Specs (a Clarification)
Sun Oct 31, 2004 7:32 am
Nope
SQ has no such model
..which it doesn't
apparently not
PyroGX41487
Sun Oct 31, 2004 7:56 am
Isn't SIN-EWR in the 9000nm range? I wasn't saying their A345 wasn't a special version, it was heavily payload restricted and carried less pax, which it does.
Thanks, btw.
ConcordeBoy
Sun Oct 31, 2004 9:17 am
Not quite.
8285nm, with a bit more given the still air... and it has to be restricted just to make that.
widebodyphotog
Sun Oct 31, 2004 10:25 am
OK,
Maximum range for 777-300ER with a full passenger payload weight of 77,600lbs (361 pax), or ZFW of 447,600lbs. is 7,720nm or (8,878sm).
That range plan assumes standard day temp, zero wind, standard reserves plus allowance. Takeoff weight of 759,600lbs.
Boeing website quotes 7,880nm or (9,062sm), with slightly different assumptions on passenger payload weight.
Now of course this plan has nothing to do with how airlines actually operate the aircraft. In the real world there is wind, weather, route modifications, different seating arrangements, and cargo on board the aircraft. Operators optimize their aircraft to extract the best payload/range/revenue solution possible. In practice it seems that segments of 5,900-6,300nm are at the peak of the curve balancing all three of those factors. This comes out to a nominal payload capability of 115,000-135,000lbs, giving operators great flexibility on what they can put on the plane to make money.
SIA's A345's carry 170pax and are getting around 40,000-50,000lb payloads on the, nominally, 8,300nm (9,545sm) SIN-EWR-SIN route.
-widebodyphotog
If you know what's really going on then you'll know what to do
widebodyphotog
Sun Oct 31, 2004 10:30 am
OOPS, made a mistake.
TOW for max range for 777-300ER is 775,000lbs
-widebodyphotog
PyroGX41487
Mon Nov 01, 2004 1:46 am
Thanks, I really appreciate the info! Now I won't sound like a moron when I talk on these forums... Big grin
Vimanav
Mon Nov 01, 2004 1:51 am
A minor correction. The config is 64J/117Y which makes it 181.
rgds//Vimanav
Sarfaroshi kii tamannaa ab hamaare dil mein hai, Dekhnaa hai zor kitnaa baazu-e-qaatil mein hai
widebodyphotog
Mon Nov 01, 2004 3:49 am
Vimanav,
OOPS again, thanks for the correction I should never post stuff when I'm in a hurry.
-widebodyphotog
