captjetblast
Pilot Broadcasts Hijacking Signal By Mistake
Mon Nov 01, 2004 11:00 pm
A few days ago, a commercial flight bound to Buenos Aires emitting the hijacking signal (7700 ?) caused panic, and Argentina Air Force jets were ready to scramble. Once the pilot regained communications, he explained it was a mistake, he wanted to emit the no radios signal (7777 ?), but mistook it.
Sorry I don't remember the flight number and operator.
Of course, the plane was escorted till the end of the runway, where all the formal procedures took place.
HOW CAN THIS HAPPEN? Must he be sanctioned?
pilotaydin
RE: Pilot Broadcasts Hijacking Signal By Mistake
Mon Nov 01, 2004 11:16 pm
hey there jet blast. The hijack signal is alpha code 7500. 7700 is for emergency. I was told in college to always squawk down from 7 and not up as 7777 is a military code used on some training missions and unmanned shoot downs...can anyone confirm this?
it's quite a story, who knows what was going on in the cockpit? Good thing no one was shot down...you never know!
take care
a
The only time there is too much fuel onboard, is when you're on fire!
IDAWA
Mon Nov 01, 2004 11:18 pm
The transponder code for hijacked aircraft should be 7600, while 7700 is the one for aircraft in trouble. If you don't want to transmit anything, then it should be 1200.
May someone see if this is correct?
I-DAWA.
Flown on: 319, 320, 321, 340, 727, 737, 747, 757, 767, 777, DC9, D10, M11, M80, 146, EM2, BEH, CRJ, DH8, L4T.
PNEPilot
Mon Nov 01, 2004 11:25 pm
Not quite: 1200 is for VFR flights
7500 is hijack
7600 is lost comms
7700 is emergency
7777 is for military use
KYIPpilot
7500 is Hijack
7600 is lost communications
7700 is emergency
"It starts when you're always afraid; You step out of line, the man come and take you away" -Buffalo Springfield
geoffm
Tue Nov 02, 2004 3:15 am
- Code 1200 VFR Flight
- Code 7700 Emergency
- Code 7600 Radio Failure
- Code 7500 Hijack
- Code 7777 Military Interceptor Operations
-from http://www.gg-pilot.com/ggweeklyarticle.asp?id=10
Geoff M.
airsicknessbag
Tue Nov 02, 2004 9:39 am
I heard about a little rhyme student pilots are taught to remember that 7500 thingy: "Seventy five - man with a knife."
Daniel Smile
ua777222
Tue Nov 02, 2004 10:50 am
Seventy Five- Taken A Nose Dive
Seventy Six- Radio Needs A Fix
Seventy Seven- Need Some Help From Heaven........
Just made them up but then again if you need a rhyme to remember proper transponder codes than you might be, as they say, SOL..
Glad all is good and everyone is ok.
Thanks again.
UA777222
"It wasn't raining when Noah built the ark."
DeltaMD-88
Tue Nov 02, 2004 10:58 am
UA I like that Rhyme thats a good one to remember them by
Buck Fush Buck Fush Buck Fush Buck Fush Buck Fush Buck Fush
CX Flyboy
We usually dial up 2000 if we don't want to have anything there.
ua777222
Tue Nov 02, 2004 11:30 am
Ah what the hell,
As long as it works and doesn't get you killed.
Sry if I stepped on your toes DL!
Thanks again.
UA777222
