southpaw8669
Frontier Charter Flight Into JFK Today
Thu Nov 04, 2004 2:30 am
Does anybody know when this aircraft will be departing JFK?
thanks
@southpawcapture
mikephotos
RE: Frontier Charter Flight Into JFK Today
Thu Nov 04, 2004 3:17 am
Should be departing at 330pm to IAD.
Michael
WesternA318
Thu Nov 04, 2004 3:19 am
an F9 charter from JFK to IAD? A319 or A318?
Check out my blog at fl310travel.blogspot.com!
southpaw8669
Thu Nov 04, 2004 3:40 am
its a A319 arriving at 2:16, and it will depart 3:30.
Thanks for the info.
Eric.
@southpawcapture
MSYtristar
Thu Nov 04, 2004 3:42 am
It was a charter MSY-JFK bringing a group of Irish people back to Kennedy to connect to Aer Lingus. I worked the flight. The aircraft operated DEN-MSY early this morning, then MSY-JFK, then a ferry flight JFK-IAD, and then the plane will operate this evening's scheduled flight from IAD to DEN. Aircraft was N910FR, "Sal the Cougar".
southpaw8669
Thu Nov 04, 2004 3:47 am
thanks for the info MSYtristar, I will try to get out there for the departure.
@southpawcapture
N1120A
Thu Nov 04, 2004 12:07 pm
Gee Stephen, another reason MSY should have a trans-atlantic? F9 must have done well on that flight. Considering their lack of aircraft, how were they able to cycle the plane out?
MSYtristar
Fri Nov 05, 2004 1:48 pm
F9 cancelled a couple of flights across the system so that they could use the plane for the charter. Midweek is typically slow system wide, so having a flight cancelled that had low loads to begin with did not really adversly affect the operation. Charter flights are guaranteed $$$.
As for transatlantic from MSY, it'll happen sooner or later, i've been hearing some interesting things lately but I can't say much more than that for now.
