flyinTLow
US 193 FRA-CLT - Emergency Landing?
Sat Nov 06, 2004 6:55 am
Hey!
Today (11/5) at work I saw that US 193, FRA-CLT, came back to FRA around 1ish after having departed (computer log said Inbound from FRA) from there. The airplane was then towed to V168 (that's apron, way out there, not anywhere where the plane is usually parked) and it also had an N proceeding the flight, which normally indicates an emergency landing.
Does anyone know anything about this flight?
- When dreams take flight, follow them -
N670UW
RE: US 193 FRA-CLT - Emergency Landing?
Sat Nov 06, 2004 2:08 pm
usairways.com says the flight was cancelled, but they don't give a reason.
Though the second leg of US193 (CLT-LAX) operated normally.
N670UW
PNEPilot
Sun Nov 07, 2004 2:38 am
Can't draw any useful conclusions from that: most of US's transAtlantic flight numbers have onward domestic legs with the same number, but they are all actually different aircraft.
N670UW
Sun Nov 07, 2004 2:47 am
I'm aware it's the same flight number and a different aircraft. FRA-CLT operates with an A330-300, and CLT-LAX is an A321. I was just noting that CLT-LAX operated normally.
N670UW
flyinTLow
Mon Nov 08, 2004 8:55 am
Got the details to the incident at work today:
Upon takeoff, a tire exploded, and, similar to the Concorde tragedy, parts of the tire hit the wing. It supposedly ripped a pretty huge junk out of the flaps. Don't know if the aircraft dumped fuel (I would assume, since most transatlantic flights leave with a TOW higher than maximum landing weight). They replaced the tire and then flew the aircraft to CLT with the hole in the flaps! Appearently they made it without problems. Didn't hear anything different. And no news normally means good news in aviation.  Smile
supa7E7
Mon Nov 08, 2004 12:50 pm
Yes there was a special ferry flight US 9217 which landed around 11pm Friday night. Not sure how the pax were reaccomodated.
"Who's to say spaceships aren't fine art?" - Phil Lesh
GZIP: Off
