BBJ & ACJ
Mon Nov 08, 2004 3:21 pm
What are the differences between BBJ & the ACJ in terms of cost,interiors & performance.If the BBJ is a B737-700/800.Is the ACJ a A320.
regds
HAWK
ConcordeBoy
RE: BBJ & ACJ
Mon Nov 08, 2004 4:13 pm
ACJ is A319
N1120A
RE: BBJ & ACJ
Mon Nov 08, 2004 4:22 pm
The BBJ and ACJ cost about the same. The ACJ has a very slightly wider fuselage, but most would probably not notice in the configuration as I cannot notice the difference when flying coach and I have a 44 inch chest. They fly about the same speed, with the BBJ having better runway performance and longer range.
FlySSC
RE: BBJ & ACJ
Mon Nov 08, 2004 6:12 pm
Check one of my previous post concerning the A319CJ :
http://www.airliners.net/discussions/general_aviation/read.main/1791426
ANA
RE: BBJ & ACJ
Mon Nov 08, 2004 7:16 pm
There are two 319 variants, the Airbus Corporate Jet (ACJ) and 319LR. They're pretty similar though the ACJ is more expensive.
There are two BBJs: BBJ1 and BBJ2 one is a 700 the other an 800 although the 700 is a hybrid, and has 800 wings.
Then there is the 737-700ERX and 737-800ERX. The 737-700ERX is most comparable to the 319LR, but it flies further.
The 319 is wider, but also heavier, so the range is often the winner for the 737 for private/ state aircraft.
Overall they are similar concepts: standard aircraft, structurally enhanced with added fuel tanks.
