7e72004
When Were Jetways First Introduced?
Tue Nov 23, 2004 2:13 am
Looking at some of the older pics in the database it looks like jetways made their first appearance in the 60s--although they looked kind of short and "boxy," does anyone know when they first came into existence?  Big grin
The next generation of aircraft is just around the corner!
727LOVER
RE: When Were Jetways First Introduced?
Tue Nov 23, 2004 2:18 am
Actually, it was the late 50s. I know DL had 2 at the old old terminal in ATL.
Is JETWAYS what these are officially called,..or is that a brand name? Is there only one company that makes these?
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
Type-Rated
I think that they came as a product of the "Jet Age", hence the name "Jetway" (Which is also a brand name). I believe they started being used around 1960 or so. It seems that propliners always used stairs.
Fly North Central Airlines..The route of the Northliners!
7e72004
Tue Nov 23, 2004 2:25 am
Doesn't NW Airlink use jetways on some of their Saabs at DTW?
ANCFlyer
Tue Nov 23, 2004 3:51 am
I believe I read somewhere that UA "had them invented" and first installed them at LAX. They used two on each aircraft. A DC8 or 707 would park with the portside facing the terminal - this is way back when Terminal 7 (and others at LAX) were true satellites. A 'jetway' would be connected to the forward (1L) entry door for 1st class, and in the rear (2/3L) for economy class. My source: Book "United, THe Mainline Airway", by George W. Cleary, Page 78, also see page 87 for a shot of SFO.
phollingsworth
Tue Nov 23, 2004 3:55 am
DL claims the original Jetway (TM) idea. They expanded their concourse at ATL to accommodate the new DC-8s using second floor lounges. One of their GSE engineers supposedly came up with the idea so that passengers would not have to go down and then up a flight of stairs to get from the lounge onto the a/c. DL the contracted with FMC corporation to construct them. FMC later named this division Jetway Inc. which is where the name comes from. The official non trademark name is loading-bridge.
bullpitt
Tue Nov 23, 2004 6:20 am
Here in Spain they are called fingers, And I know there is a Spanish company that builds them, so I imagine 727LOVER that there are several manufacturers.
These are my principles but if you don't like them I have others
N1120A
Tue Nov 23, 2004 6:30 am
There are several companies who build them, though Jetway is the largest company. Also, Jetway was the original coloquialism, and the one most often used in the US (for whatever that means). LAX is probably the most jetway heavy airport, as even the bus gates have jetways
