manu
FedEx Tail Discolouration?
Sat Dec 11, 2004 2:08 am
I've seen some great answers to interesting questions, so I thought I'd join and ask one myself.
I am curious why the A300 aircraft pictured in the centre (N660FE) has very unique weathering on the tail, especially compared to the tail in the left and right of the plane in question? It is more obvious with the late-day sun, hence the yellow glow/hue to the picture. Usually FedEx machines are pretty well kept, from what I have seen.
Is it purely weathering? None of the other photos of "N660FE" on a.net have a good view of the left side tail, so I can't get an idea of how long this discolouring has been there.
Photo © Shawn Morgan
Cheers, and keep up the great posts!
[Edited 2004-12-10 18:11:42]
[Edited 2004-12-10 18:12:41]
jetblast
RE: FedEx Tail Discolouration?
Sat Dec 11, 2004 2:17 am
Are you sure it's not the sun reflecting off of the other a/c's fuselage? When the sun hits N660FE the reflection would bounce off of it and hit the other a/c, then that reflection would go back to N660FE, maybe hitting the tail. Just a thought!
JetBlast @ BWI  Smile/happy/getting dizzy
Speedbird Concorde One
European
Sat Dec 11, 2004 2:19 am
I think you ment about N660FE, If so, probably some kind of water, or just the sun if the other aircraft you are on about.
European
Jimmi
Come on Ryanair! Come on BOH! BASE BASE BASE! Flying high in the skies...........
n685fe
Wed Dec 22, 2004 5:03 am
More then likely it was a leaking actuator. Skydrol is nasty, it will eventually cause the paint to discolor, bubble and peal off. Skydrol leaks are common, you will see them from control surfaces and running down the belly towards the tail on most any type of a/c.
Photo © TriplET
Photo © Søren Geertsen
psp. lead by example
