jfkaua
How To Find Runways Being Used
Wed Dec 15, 2004 12:36 pm
Hey I was just wondering say you plan on leaving or arriving at an airport, how do you find out what runway you'll be landing or departing at for example lga or jfk
MD11LuxuryLinr
RE: How To Find Runways Being Used
Wed Dec 15, 2004 12:38 pm
You find out what the winds are going to be (for most airports). Doesn't JFK and LGA use certain runways in the AM then switch them to the other in the PM?
Caution wake turbulence, you are following a heavy jet.
LX23
Wed Dec 15, 2004 12:40 pm
If you have an airband scanner, you can either listen to the Approach, Tower, or ATIS frequencies.
ordflyer
Wed Dec 15, 2004 12:43 pm
If you are interested for spotting purposes, you can also call up the ATIS from a phone and listen to the recorded message from home and see what runways are in use.
The Airnav directory has ATIS phone numbers listed next to the radio frequencies. http://www.airnav.com/airports/
BIGBlack
Wed Dec 15, 2004 2:40 pm
Is it only weather and traffic that determines runway useage? What about destination?
Someone special in the air
flygmolinafmly
Wed Dec 15, 2004 3:03 pm
Yes, destination may be a factor. When you radio into clearance delivery when you are ready to leave but before taxiing, you tell them your intentions such as destination. Then they will give you the details and assign you a runway.
Gabriel
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
BIGBlack
Wed Dec 15, 2004 3:04 pm
Gotcha! Thanks  Smile
Arrivals are different though yes?
Users browsing this forum: 747d10, 817Dreamliiner, arvo, Baidu [Spider], bendytendy, Bobloblaw, BREECH, CostaDelSol90, Google [Bot], JA, LA704, lb1848, Obzerva, Pe@rson, qf15, qf789, sf260, SGAviation, sk736, SpaceshipDC10, trees, Trololzilla, Wingtips56 and 10 guests
