avion
Delta 767 Incident In Zurich
Mon Mar 20, 2000 3:47 am
A Delta 767 narrowly escaped a catastrophe in Zurich last Friday. The Boeing 767 taxied for runway sixteen when someone in the control tower noticed that something was coming out of the right engine. The control tower then notified the pilot who found nothing uncommon. The aircraft was now on the runway when the tower ordered evacuation and the firefighters had foamed the runway. A big fuel leak in the engine was the cause. If the aircraft had taken off it would have exploded into a fireball.
This was a close call.
Avion
avion
RE: Delta 767 Incident In Zurich
Mon Mar 20, 2000 6:14 am
Comments anyone ?
Avion
kaitak
Mon Mar 20, 2000 6:26 am
Has the NTSB/Swiss Federal investigators made any comment about this? Strange that if the problem was visible from the tower as the 767 was taxiing out, it wasn't picked up by the crew during the walk around?
Is there any idea of how it was caused? FOD? Ground collision? Surely the 767 is much too new to fall victim to fatigue?
avion
Mon Mar 20, 2000 6:42 am
There has not been any information about the cause of the leak. Does anybody know if the aircraft is still in Zurich?
Avion
Mon Mar 20, 2000 7:36 am
Seems like you've already figured it out before any of the aviation experts have answered. Where did you get this info...from the news media.
>>it would have exploded into a fireball.<<
It would have, huh?
Do you even know if it was fuel? Maybe it was hydraulic fluid or oil. If it was a fuel leak it might have only show up under pressure while the engine is running. This might explain why it wasn't picked up during the preflight, as Kaitak asked.
It's unlikely that a catastrophic explosion would have taken place as it's the fuel vapor that's explosive, not the fuel itself. There's too much airflow to allow vapors to accumulate and create an explosive situation.
Chances are, the crew would eventually notice a higher fuel flow from the engine or be alerted to a unbalanced fuel condition from the wing tanks. Following prescribed procedures, they would have probably shut the engine down and returned for an uneventful single engine landing.
But that wouldn't make good for a good news story....
Panman
Mon Mar 20, 2000 7:56 am
I believe the most that would have happened in any case is that you would have had flames coming out of the jet pipe and not an explosion. For it to be an explosion there would need to be a path for the flame to reach to the fuel tank.
PanmaN
dnalor
Mon Mar 20, 2000 9:06 am
Not to mention a higher than normal EGT (exhaust gas temp)
avion
Mon Mar 20, 2000 3:15 pm
There was on official press release and the interview was printed in a newspaper. But there has not yet been a press release regarding the cause. The aircraft lost three tons of kerosene on its way the runway.
I hope this clears things up.
Avion
teahan
Tue Mar 21, 2000 4:55 am
Which newspaper, ThE BLICK a Swiss gossip newspaper or a reliable one like the TRIBUNE DE GENEVE. Do not believe what you read in the BLICK do not bother reading it.
Jeremiah Teahan
Goodbye SR-LX MD-11 / 6th of March 1991 to the 31st of October 2004
avion
Fri Mar 24, 2000 1:27 am
Some of you didnt believe me.Go to http://www.justplanes.com/AirlineNews233.html
and scroll down. Theres the proof that it really was a fuel leak.
Avion
