airevents
Cheap Flights From NYC To Chicago Area
Tue Jan 04, 2005 11:16 pm
Hi,
I might need to book a return flight from New York City area to Chicago area. Unfortunately, LCC such as Jetblue or Southwest seem not to fly there.
If you know how to get a cheap fare on that route, please be so kind reply here.
Thank you!
Sven
www.airevents.com
GMUAirbusA320
RE: Cheap Flights From NYC To Chicago Area
Tue Jan 04, 2005 11:26 pm
Try FlyI. I work there. They've got some pretty low fares from JFK-IAD-ORD.
Good luck!
GMUAirbusA320
AIR757200
Tue Jan 04, 2005 11:34 pm
Use the internet (Orbitz, etc.)..!
petazulu
Tue Jan 04, 2005 11:45 pm
ATA?
filler
filler
ludavid777
Tue Jan 04, 2005 11:46 pm
check out www.flyi.com
TWFirst
Tue Jan 04, 2005 11:54 pm
Flights from MDW are usually cheaper. Continental has decent fares from MDW-EWR if you book in advance.... if you want to connect, you can go through Cleveland or take NW through Detroit.
An unexamined life isn't worth living.
Sabena332
Tue Jan 04, 2005 11:55 pm
prosa
Tue Jan 04, 2005 11:59 pm
WN ISP-MDW is a reasonably priced alternative if you don't mind going a bit out of your way.
"Let me think about it" = the coward's way of saying "no"
EddieDude
Wed Jan 05, 2005 8:43 am
I recall I found return fares in the neighborhood of U.S.$180 with legacy carriers in January, 2003 and ended up flying ORD-JFK with DL because I had a reward ticket. My friends who had to make the same trip all went with TZ MDW-LGA since it was the cheapest. Hope this helps.
Upcoming AM MEX-LAX 73H, VA LAX-MEL 77W.
