sspontak
Victorville, CA
Wed Jan 05, 2005 4:13 am
I will be in Southern California from Jan 7 thru Jan 15. Is there a possiblity to take a drive through/tour through Victorville to see some old planes. I particularly would like to see the Delta Tristars.
Go Delta!
mdsh00
RE: Victorville, CA
Wed Jan 05, 2005 4:17 am
of course. The city of Victorville can be accessed by the Interstate 15. It will be a bit of a drive though, depending on where you will be staying in SoCal.
"Look Lois, the two symbols of the Republican Party: an elephant, and a big fat white guy who is threatened by change."
sspontak
RE: Victorville, CA
Wed Jan 05, 2005 4:25 am
I will be spending time between LA, San Diego, Palm Desert, and Palm Springs so it shouldn't be too far.
Thanks.
Go Delta!
Tod
RE: Victorville, CA
Wed Jan 05, 2005 5:40 am
It's about an hour drive from ONT.
airxliban
RE: Victorville, CA
its not too bad of a drive...you should check out HDPP (High Desert Power Project) at the same time, they're right next to each other.
sspontak
RE: Victorville, CA
Wed Jan 05, 2005 6:05 am
Is Victorville considered an airport or a storage facility? How can I get access into the property?
Go Delta!
EMBQA
RE: Victorville, CA
Wed Jan 05, 2005 6:45 am
Most all aircraft storage facilities are Restriced Access. Some, but very very few offer guided tours, but even then in most cases you are not allowed off the van.
Try a search for more information. There have been several threads on this subject with some good information.
