Sjoerd
Pics Of Both B744 And A380?
Sun Jan 09, 2005 11:26 pm
Are their (computer generated) pics that compare the A380 and B744 ?
Thx, Sjoerd
Flanders + Wallonnia + Brussels = the UNITED STATES of BELGIUM
Scorpio
RE: Pics Of Both B744 And A380?
Mon Jan 10, 2005 12:17 am
Here you go:
United_fan
Mon Jan 10, 2005 12:41 am
Love that Tropical Megatop ! Too bad it's gone  Sad Nice comparo,though.
Champagne For My Real Friends,and Real Pain For My Sham Friends
ba97
Mon Jan 10, 2005 12:46 am
Wow. this is the first time I have seen a comparison. If even close to scale, I now understand all the modifications places will require to handle this little plane.
there is economy class, business class, first class...then Concorde..pure class
Xkorpyoh
Mon Jan 10, 2005 12:52 am
I actually own a 1:200 747 and A380 and I have them next to each other just to compare the sizes and they dont look that much different. The picture makes the A380 look a lot bigger, but by looking at the scale models, the A380 is bigger but the 747 still has a presence...doesnt look that small as compared to this pic.
TW741
Mon Jan 10, 2005 1:49 am
In Size the difference is not so big:
Length: A380: 73 m B744: 70,7 m
Wingspan: A380: 79,8 m B744: 64,4 m
Height (rudder): A380: 24,1 m B744: 19,3 m
Width of Body: A380: 7,1 m B744: 6,5 m
Max Range: A380: 11.500 km B744:10.750 km
Nbr of Pax (3-Class/LH) A380: 555 B744: 390
The major difference is the wingspan (plus 15 meters) and the doubledeck of the A380 over the B747.
TWA - we showed you how good we have been!
AlitaliaMD11
Mon Jan 10, 2005 3:26 am
I own a SQ 1:200 A380 and I put it next to my
VS A346
KL 744
QF 744
Fed Ex MD-11
and BA concorde
beluga
(all in 1:200 scale)
and the A380 does not look much bigger. Well, comapred to the concorde, beluga, and the MD-11 it looks huge!
No Vueling No Party
Lemmy
Mon Jan 10, 2005 10:17 am
It's the huge square-footage of the 380 wing that amazes me. Makes you realize how much weight this plane will be lugging around.
I am a patient boy ...
N766UA
Mon Jan 10, 2005 10:35 am
Remember, although bigger than the 747, the A380 is nothing new as far as size. The C-5, AN-124, and AN-225 have been flying for a long time. The A380 will only look much larger from above, when the full wingspan can be viewed. Apart from that (although the upper deck will obviously make her look bigger), the A380 vs. 747 will not be as dramatic as in that picture, I don't think.
This Website Censors Me
tungd
Mon Jan 10, 2005 10:40 am
While the 380 is certainly larger than the 747 in most every aspect, any generated image cannot possibly present a true and fair comparison of how the two aircraft will actually appear next to each other in real life. In a year or two we may have a "real" photograph, but until then everything else is speculation and must never be construed as fact. (Posted by a photojournalist)
[Edited 2005-01-10 02:44:37]
cedarjet
Mon Jan 10, 2005 10:49 am
It is really incredible to see the 747 and the A380 next to each other. If Airbus have done that shot, I don't think they will have deliberatedly exaggerated the size of the A380 cos their whole line is that the plane will fit into a certain box (no-one told LAX this "box" needs more than a few inches clearance on either side - oh well). The 747s, the tropical Megatop especially, look like 767s parked either side of a 747. Can't believe this plane! The new shots have really stopped me in my tracks.
mav75
Mon Jan 10, 2005 12:01 pm
it's not the size of your equipment that matters, it's how proficient you are at operating it...
kalakaua
Mon Jan 10, 2005 2:25 pm
Isn't the 747 longer?
Gravity explains the motions of the planets, but it cannot explain who set the planets in motion.
a380900
Mon Jan 10, 2005 2:33 pm
No, the 747 is shorter. A340-600 and 777-300 ER are longer than the A380.
kalakaua
Mon Jan 10, 2005 2:37 pm
Oh yeah... That's right. Giving height to that beast makes it look stubby, meaning the A380 doesn't look "proportional".
flybyguy
Mon Jan 10, 2005 10:01 pm
Lemmy,
The wing is large (fat) rather than long (large span) for the precise reason of carrying the weight of the Goliath beast without too many space restrictions at current airports. The fatness of the wing is unfortunately necessary to reduce wingspan but still retain the same general wing area.
"Are you a pretender... or a thoroughbred?!" - Professor Matt Miller
VSCaptain
Mon Jan 10, 2005 10:19 pm
Wouldn't the air bridges be one one each deck rather than both on the main deck?
AP321 - Oxford Aviation Academy
Boeing Nut
Mon Jan 10, 2005 11:34 pm
Some of you folks should post picks of your models for another side by side comparison.
Areopagus
Tue Jan 11, 2005 6:39 am
Compare wing areas.
747-100 511 m^2
747-400 541 m^2
380-800 830 m^2
transswede
Tue Jan 11, 2005 7:22 am
"Wouldn't the air bridges be one one each deck rather than both on the main deck?
Not needed, the A380 is designed to be boarded quickly from the two air bridges. The upper deck passengers will use the front door (and then head up the "grand starcase"), and the lower deck passengers will use door #2.
Dual level airbridges will speed things up, but only a few A380 hub airports will be making that investment.
A350
Tue Jan 11, 2005 7:35 am
Does this mean that handicapped persons will be unable to enter the upper deck? Or will there be a lift?
In the Airbus' proposal for cabin layout
http://www.airbus.com/product/a380_cabin_layouts.asp
the business class will be completely in the upper deck. So no wheelchairs at business class  Confused
A350
transswede
Tue Jan 11, 2005 8:15 am
I believe there will be at least one lift on board, at the rear. But I guess that handicapped passengers will be strongly persuaded to just use the main deck.
A350
Tue Jan 11, 2005 8:44 am
But what happens if the handicapped passenger wants to fly business class and the A380 has the Airbus standard cabin layout?
A350
B727-200
Tue Jan 11, 2005 8:58 am
I am spewing this thing will not be ready to fly by the time Airshow Australia comes around at Avalon near Melbourne in March  Crying
The only true way of comparing size would be to see it with our own eyes up against a B747.
