cx750
Delta B772 Range
Thu Jan 13, 2005 4:49 am
Could anyone shed some light on the range capabilities of DL's B772s? Specifically, can it fly either ATL-PEK or PVG if they get the final China slot?
In addition, what engines do they have on their B772s? Thanks.
drerx7
RE: Delta B772 Range
Thu Jan 13, 2005 4:50 am
Yes--they have comparable range to Continental's 777s which as you know fly EWR-HKG routinely.
Third Coast born, means I'm Texas raised
Delta07
Thu Jan 13, 2005 4:55 am
I believe the B777-232ER is powered by two RR-Trent 892.
NO URLS in signature
DeltaMIA
Thu Jan 13, 2005 6:01 am
DL claims they can fly 8150 miles. If true it would be right around 900 miles more than the distance from ATL-PEK. I think that is around 7200 miles.
It's a big building with patients, but that's not important right now.
cx750
Fri Jan 14, 2005 12:55 am
Is it safe to assume that the RR-Trent 892 provides the B772 with the longest range? What engines do other major B777 carriers have? SQ,BA,JL etc..
Thanks.
ConcordeBoy
Fri Jan 14, 2005 5:56 am
Yes
No, it isn't.
Basic choices are:
GE90-115B and its deration (GE90-110B1)
GE90-94B and its derations (GE90-90B) and progenitors (GE90-92B, -85B, etc)
Trent895
Trent892 and its derations (most carriers op it at 90K lb/ft, not 92K... also 884B) and progenitors (Trent875, 877, 884)
PW4098 (sh!tty engine that PW basically had to give away to the only airline who ops it)
PW4090
PW4084 and its progenitors (PW4074, 4077)
SQ,BA,JL etc..
SQ: Trent884B, Trent892, and soon the GE90-115B
BA: GE90-76B, GE90-85B, GE90-90B, Trent895-17
JL: PW4077, PW4090, GE90-115B
Newark777
Fri Jan 14, 2005 5:59 am
Isn't the GE90-115B only available on the 777-300, or is it the other way around?
Harry
ConcordeBoy
Fri Jan 14, 2005 6:01 am
...interesting thing worth noting about the PW4098 though:
KE's 773As actually have a power-to-weight ratio that is GREATER than the most powerful 773ERs that are set to arrive in a few months... who knew?  Wow!
ConcordeBoy
Fri Jan 14, 2005 6:03 am
All 777s which exceed 700,000lb in MTOW, must use some variation of the GE90-115B (be it that model, a future up-rate thereof, or its -110B1 deration)
RyanL1011
Fri Jan 14, 2005 12:15 pm
PW4090
PW4084 and its progenitors (PW4074, 4077)>>>
Sorry pal but I have to strongly disagree on this one
Not only is the PW the most powerful engines on the 777, they are very reliable and have few issues, if any. The GEs and Trents are also great engines, and there have been very few problems reported with them. Before you bash something get the facts straight and have some PROOF.
Newark777
Fri Jan 14, 2005 12:21 pm
It's not proof, but here's another thread talking about the failures of the P&W 777 engines. It appears it's about fuel burn, not power. (It's near the bottom).
http://www.airliners.net/discussions/tech_ops/read.main/106251/4/
BTW Speaking of proof, I'd like to see some proof of your own to prove the P&W's being the better engines.
Harry
jpetekyxmd80
Fri Jan 14, 2005 12:25 pm
Basic choices are:
Too bad deration isnt a word  Laugh out loud
The Best Care in the Air, 1984-2009
gigneil
Fri Jan 14, 2005 12:33 pm
You're wrong. Perhaps you should get the facts? I didn't see any proof in your post.
Firstly, the GE90-115B is the most powerful engine available for the 777.
The PW4098, while powerful, consumes so much fuel that hanging it on the plane actually decreases its range compared to the weaker engines from the competitor. There is only a single customer for it, and PW basically gave them the engine, and even further only for their 773s. Every other customer for it bailed out and some even gave up on the 777 as a result of their displeasure.
The PW4090 is fine, but same problem. The higher MTOWs are not available with this engine, so 772ERs fitted with it are cripples compared to the planes powered by offerings from the other two manufacturers.
The PW4077 was great for the A market. Super light, and not too bad on the fuel.
There's a reason why the PW engines are the least sold in this market market.
N
BOEING747400
Fri Jan 14, 2005 1:49 pm
Does anybody know the fuel burn rate of the PW 4098? I'd like to compare figures of the fuel burn rate of GE 90 series vs PW 4000 series vs RR Trent 800 series on B777 models. Can anybody please provide me with the numbers? Thanks.
ConcordeBoy
Sat Jan 15, 2005 8:47 am
not exactly sure from whence you derive that amusing tidbit, as the GE90-115B is certified to produce about 17,000 more lb/ft of thrust than the best from PW
I guess that's why they're both far better sellers for the 777 family than PW, right?  Nuts
Too bad 31,900 Google hits and a simple dictionary definition completely beg to differ:
de·ra·tion [dee rásh’n] (past de·ra·tioned, past participle de·ra·tioned, present participle de·ra·tion·ing, 3rd person present singular de·ra·tions)
transitive verb
1. stop rationing: to stop rationing a commodity, usually because the supply has become adequate
2. reduction in ability or capability, usually in reference to mechanical performance or output of energy.
*cough* United and Lan Chile *cough cough*  Laugh out loud
I have the specs on my home computer... but wont have access to that for a few hours. What I can tell you is that the engine missed its projected specs by nearly 3%; which may not sound like much, but is actually a complete and total disaster for the product.
jpetekyxmd80
Sat Jan 15, 2005 9:46 am
Damn, dictionary.com didnt have any entry. Oh well, just had to take a shot to correct you for once!
*insert piazza*
 Sad
RyanL1011
Sun Jan 16, 2005 11:06 am
Here is where I got the info from, have a problem with it, talk to boeing  Smile
http://www.boeing.com/commercial/777family/777technical.html
RyanL1011
Sun Jan 16, 2005 11:08 am
When I was refering to the PWs not having any problems with it I was refering to mechanical problems. I could care less about fuel consumption, and yes I know the airlines do care about fuel consumption, I care about power and reliability, something that the PWs HAVE.
gigneil
Sun Jan 16, 2005 11:43 am
The point is that the PW4098 doesn't exist, for all intents and purposes. Only a few were built, and none will ever be built again.
N
RyanL1011
Sun Jan 16, 2005 11:34 pm
Hmm lets see, doing some past history checks, ANA has 34+ aircraft with the PW engines... you got United... as well as 5 or 6 other carriers that come to mind... It most certainly does exist. Nice try though... :-Þ
ConcordeBoy
Mon Jan 17, 2005 8:54 am
Um Ryan... you do realize that absolutely none of the airlines you mentioned operate the PW4098.
In fact, UA was one of the three airlines pushing PW hardest to create it; yet UA later threw up its hands and ran away from that engine, once its horrific specs were made apparent.
