ktachiya
What Is The Standard Configuration For A 777?
Sat Jan 22, 2005 5:32 am
I've read in previous threads that the T7 operates with a 3-3-3 configuration but I was looking at the cabin of the NH 777-300ER the other day. I think the configuration on that was 3-4-3 instead, the same as a 747. Do certain careers operate with a different configuration? I know that they fly a 500+ people configuration on Japanese routes which is reasonable with the 747, etc. but I am always suprised at the fact that a twin can fly THIS many people.
Can anyone confirm me on the 3-4-3 configuration?
Flown on: DC-10-30, B747-200B, B747-300, B747-300SR, B747-400, B747-400D, B767-300, B777-200, B777-200ER, B777-300
gkirk
RE: What Is The Standard Configuration For A 777?
Sat Jan 22, 2005 5:40 am
I dont see whats wrong with operating th 777 using a 3-4-3 config.
All the rich moaners will disagree with me I suspect though  Big grin
airxliban
Sat Jan 22, 2005 5:43 am
EK is the airline famous for 3-4-3 config across a 777.
The standard is 9 across (3-3-3 or 2-5-2) but the 777's fuselage is only 1 inch shorter than that of the 747, so its really not that big of a deal, esp. if you get more pitch.
Indy
Sat Jan 22, 2005 5:50 am
Check out www.seatguru.com . Great for checking configurations and seat dimensions.
Indy = Indianapolis and not Independence Air
ConcordeBoy
Sat Jan 22, 2005 5:55 am
The 777 can go either way... it's most typical to see 3x3x3/2x5x2, but 3x4x3 isn't uncommon at all.
The Japanese use it, Emirates, Thai, et al. Even Bri'ish Airways used it on some 777s at one point.
Boeing Nut
Sat Jan 22, 2005 10:48 am
http://www.boeing.com/commercial/777family/777technical.html
Click on interiors - then arrangements. You'll get all versions of Boeing's basic arrnagements.
There's this link as well. Pan down to page 20 and you'll get your answer.
http://www.boeing.com/assocproducts/aircompat/acaps/777rsec2.pdf
[Edited 2005-01-22 02:53:49]
gkirk
Sat Jan 22, 2005 7:22 pm
I think BA used the 3-4-3 on their 777s that done the leisure routes, in co-operation with JMC Holidays?
DeltaWings
Sat Jan 22, 2005 10:23 pm
The 777 and the 747 can both take a maximum of 10 abreast.
~DeltaWings
Homer: Marge, it takes two to lie. One to lie and one to listen.
TW741
Sat Jan 22, 2005 10:39 pm
NG/OS operates the 772 in eco as follows:
row 11-31 as 3-3-3
row 32-40 as 3-4-3
row 41-44 as 2-4-2
row 45-47 only the 4 middle seats
I never understood why they have from row 32 onwards a 3-4-3 seating since the cabin has the same width and from row 11 backwards it is economy anyway.....
=TW741=
TWA - we showed you how good we have been!
