fourstripe
Regional Airline Jetbridges
Sat Jan 29, 2005 4:30 pm
We just got jetbridges here in CLL and man are they different! We have the "radial" design I think, where you can't steer the wheels, just one way or the other, you move forward by extending the "tunnel". I'm sure that parking RJ's isn't that bad but has anyone ever parked a full sized jetbridge on a Saab? Exciting! Only had about 6in clearance from the spinner to the bridge. I would like to hear anyone else's thoughts/stories on the topic.
-fourstripe
“Aviation is proof that given, the will, we have the capacity to achieve the impossible.” - Edward Vernon Rickenbacker
fourstripe
RE: Regional Airline Jetbridges
Sat Jan 29, 2005 4:38 pm
One more thing I'd like to ask:
Is there any really good and quick way to transfer valet-checked bags up onto the bridge and vice versa?
-fourstripe
tungd
Sat Jan 29, 2005 4:46 pm
Great to hear it Fourstripe! You should post some pics if you can.
They're probably the same as ABI's FMC/Jetway Teleradials that we discussed in the "Colgan" topic. I'll post Sside's picture again, mated to an ERJ-145:
MyAviation.net photo:
Photo © Stephen W. Sides
You can see the non-steerable wheels...
What's the consequences of bumping the prop? I would assume it would cause a maintenance delay, at least a visual inspection....
fourstripe
Sat Jan 29, 2005 4:49 pm
Well the consequences would more than likely be horrible! Aside from losing my job (more than likely), there would be a huge maintainence delay. CLL has NO contract MX and so we would have to wait and fly a mechanic down on the next flight for him to sign the logbook saying everything is OK.
-fourstripe
dsuairptman
Sat Jan 29, 2005 5:00 pm
Theres a couple of picks on the site of XJ SF3 parked at jet bridges in MSP.
My only experience boarding a prop by jetbridge was at GLH. Its very cool and
"Big" airport like. Intrestingly, when i arrived back in GLH deplaning was open ramp, this was due to mx delays and the need to turn the aircraft faster.
Regional jetbridges were actually intended for small local service airports, but most of these facilities are not presently jetbridge accomadating, and the remodeling cost would be too much for small airports to bear, considering the handle 2 or 3 flts a day.
Larger regional fields can sustian the bridges, but if they are a continuely picking up new air service, then it could leave airlines without gates or open ramping, which cosmetically wouldn't blend in, and the airline probably wouldn't be enthusied with compliants when pax see other carrier docking at JBs.
Another downside is that briding the prop or rj is not always in the best interest of maintaing quick turn times. With oversized carryons, Ground staff must move these bags out of the jet way, to the cart, and off to the hold, which adds a step, considering w/ open ramp, pax put bags on the cart.
Then the bridged has to be pulled out/to the plane, and as you mentioned, with SF3 that can be a methodical, slower procedure.
Its a novel idea, but props and RJs may not all be suited for big jet treatment, the best way to incorporate jetway use is to roll airstairs to the bridge, let pax walk down and then hop on the plane, still get big plane treatment, albit modified for the regional field.
GEAUX SAINTS!
dtremit
Sat Jan 29, 2005 5:06 pm
In DTW, NW has multi-tiered carts set up just past the boarding door for gate-checked bags. Passengers leave gate checked items on the carts, which are then wheeled out to the plane. The jetway is constructed so they can just slide the carts in and out. I've actually only flown out of DTW on an RJ, so I don't know how they do arrivals, but it definitely speeds up boarding.
dsuairptman
Sat Jan 29, 2005 5:14 pm
Dtremit:
Pretty cool inovation. That would diffently work well for ground level boarding,
of course DTW is a hub w/ a new terminal for its favorite airline, so it might be a while before we see downstations retrofitting bridges for that.
GEAUX SAINTS!
HNL
Sun Jan 30, 2005 1:17 am
I'd love to see some pics of teh DTW cart/jetway innovation. Are there any posted on this site?
HNL - There's no place like it!
KaiGywer
Crew
Sun Jan 30, 2005 11:20 am
I believe MSP has the same system as DTW. There is a little elevator in the jetway, the pax will put their bags on the cart, then the gate agent closes the door after the last pax, so ramp can lower the cart and push it over to the plane. The cart then stays outside until the next flight arrives, put the incoming bags on it, put it back in the elevator and raise it. The door is now opened by the gate agent.
I tried to find a pic, but can't find any.
N405MX
Sun Jan 30, 2005 1:53 pm
Here in Mexico we have some airports that have the jetway for those planes, like TAM (first to operate one) and CUL, there are plans about putting one here in MTY due to the load of regional jets here (lot of embraers 5D, AA, CO, DL), and speaking of close to the jetway, the MX A318 had to be pulled to the jetway, because a small mistake will lead into a aircraft crash against the jetway (the engine gets about 1m from the jetway, pretty close).
Life is what happens when you have other plans.....
kaputt
Sun Jan 30, 2005 2:10 pm
Hmm I never heard of boarding props with a jetway. But still, pretty sweet.
Carpe the Diem...Seize The Carp
lincoln
Sun Jan 30, 2005 4:06 pm
PLN (Pellston/Emmet County Michigan), this tiny little airport served only by NW--actually XJ/9E--and only service to DTW just doubled their gates (to TWO! -- Gate number "Duck" on the left and "Turkey" on the right, IIRC) and got jetways about a year or two ago.
They have the same system as DTW has for dumping bags plainside - there's a cart (same as what you'd have without a jetway) to the right as you leave the terminal that you can throw bags on before boarding. The CSR then pulls it out down a short ramp, throws the bags in the hold, pulls the jetway and ...
Keep in mind thoough that RJ jetways start off much closer to ground level than big jet jetways which makes this concept much more doable.
Works quite well, especially when it's FREEZING out and you have a southern Californian like me  Smile
I've done both CRJs and SF3s using this process -- have pictures somewhere -- and it never really seemed that the jetway was especially close to the props (then again, I think every time I've done it, the jetway has been parked so that its right edge is aligned with the right edge of the L1 door meaning a GREAT view of the flight deck.)
Highly recommend PLN -- beautiful and very unique little airport (with an enclosed observation deck) in a beautiful part of the counrty.
Lincoln
[The last time I flew out of PLN I was inline for security and the TSA screener yells over to the Mesaba counter "Hey , call 911"...a beat passes..."The Sheriff owes me $20 and I haven't seen him yet today"]
VgnAtl747
Sun Jan 30, 2005 11:18 pm
We have DEW bridges at my airport with the same design as yours. Parking the CRJ is really easy, however NW uses the bridge with their Saab's at my airport... its pretty amazing to see that. With the layout of the bridges and gates, they actually have to pull the "tunnel" all the way in, then swing the bridge from the nose, along the fusalage to the prop to dock the bridge. They can't just drive it left and extend the tunnel to the boarding door.
With regards to your valtet, gate-checked bags... we have a door at the bottom of the bridge, just where the bridge runs into the gate area. We put our valet bags on a cart and drive them up to that door, then the pax simply pulls them off of the cart as they walk by. It's a nice design actually... there is a little garage style door, and the area where the cart goes it all enclosed. You push the cart up, close the door on the ramp side, and open the door terminal side to prevent access to the ramp.
Work Hard. Fly Right. Continental Airlines
Boeing Nut
Mon Jan 31, 2005 3:42 am
http://www.dewbridge.com/products/index.html
Dew Bridge has jetways that will fit everything from a Saab 340 to an A340. Pretty cool product line.
fourstripe
Mon Jan 31, 2005 3:45 pm
It looks like Dew has a great product line. I wonder if the airport authority here (Texas A&M University) will ever consider purchasing a valet bag system for us. Hustling bags up and down the jetbridge stairs is only fun for so long! Especially on quick turns!
-fourstripe
drewwright
Tue Feb 01, 2005 2:28 am
US Airways has the F Terminal at PHL, which is one of the best I've seen. They pull everything from the Dash to the 170 up to those jetways. Granted, there are an unfortunate few like the Dork that don't use the jetways. I really think jetways play an important role in altering the public perception of regional jet/prop service...as long as pax don't have to climb stairs or see a prop, they seem less inclined to comment on "how small/tiny this puddlejumper is" as they board!
ssides
Tue Feb 01, 2005 2:33 am
At ABI, there are no pushback tugs, so aircraft must complete a wide circle to turn around. For this reason, the jetbridges make a very, very wide swing to get up to the plane. It can be annoying, because a bell goes off while the bridge is moving, and it can take about 30 seconds just to move it up to the fuselage!
Fourstripe, load some pics to myaviation.net when you get a chance!
"Lose" is not spelled with two o's!!!!
pilottim747
Tue Feb 01, 2005 3:17 am
Here's MSP's regional jetbridges. Great Lakes Av (when it operated into MSP) didn't use a jetbridge, however, you can see the 9E/XJ jetways behind the aircraft.
Photo © Timothy Hannan
pilottim747
www.mspupdate.com
Aviation Photographers & Enthusiasts--Coordinate your life.
Codasco
Tue Feb 01, 2005 8:46 am
Well, I've been surprised be some airports/airlines that do/do not use jetways for regional service. On a recent trip with AA (Chautauqua) STL-CMH, jetways were used at both airports (the C1 jetway at STL seemed awfully long for ERJ service). This didn't surprise me. On another trip, STL-CVG-CMH-IAD-ROA (can you come up with a more convoluted route) with DL (Comair/Chautauqua) and UA (Atlantic Coast/Shuttle America) not a single flight used a jetway. I figured that DL's operations at STL, let alone CVG were large enough to justify jetways. UA at CMH, and IAD didn't surprise me though, as UA at CMH is small, and UA has a separate regional terminal at IAD (and I was on a Saab). ROA had a rather strange setup. THe saab parked on the apron and the passengers were deplaned via air stairs, but they had a jetway that came all the way down to the ground level for the passengers to hike up into the terminal.
On the other hand, on COexpress STL-EWR, CO used jetways at its very small STL operation.
usdcaguy
Tue Feb 01, 2005 10:00 am
They have jetbridges on the US Airways Express gates in Columbia, SC (CAE). They aren't pulled up to the aircraft, however; I suppose it has something to do with the design of the jetbridges, one of which is broken. I have always thought that it was better to board passengers through the jetbridges without giving them access to the ramp, if only for safety and security reasons, not to mention that it is much more pleasant to board this way in inclement weather.
NW7E7
Tue Feb 01, 2005 1:52 pm
Here are some regional jetbridges in DTW. If you look closely in the 2nd pic you can see the jetbridges going to the SAABs.
Photo © Matt Masterson
See if you can find something fishy in the background of this picture...
dsuairptman
Tue Feb 01, 2005 1:58 pm
Ahh, yes! I do see an odd pairing, it appears a CRJ has come to visit his big brother on the DTW A concourse.
GEAUX SAINTS!
