MDW22L31C
SNA Or DCA
Wed Feb 02, 2005 9:19 am
CAN A 757-300 GET AT Macedonian Airlines (Greece)">IN AND OUT OF SNA OR DCA SAFELY? IT SEAMS THAT 757-200 AND OLD: Guangzhou - Baiyun (CAN / ZGGG) (closed), China">CAN GET THE BACK WHEELS OFF THE GROUND WITH ABOUT 2000 FEET OF RUNWAY LEFT AT SNA . I THINK SNA'S RUNWAY 19R IS ABOUT 6000' LONG.
N1120A
RE: SNA Or DCA
Wed Feb 02, 2005 9:29 am
>AND OLD: Guangzhou - Baiyun (CAN / ZGGG) (closed), China">CAN A 757-300 GET AT Macedonian Airlines (Greece)">IN AND OUT OF SNA OR DCA SAFELY? IT SEAMS THAT 757-200 AND OLD: Guangzhou - Baiyun (CAN / ZGGG) (closed), China">CAN GET THE BACK WHEELS OFF THE GROUND WITH ABOUT 2000 FEET OF RUNWAY LEFT AT SNA . I THINK SNA'S RUNWAY 19R IS ABOUT 6000' LONG.<
Please turn your caps off. The main at SNA is 5700', 1/19 at DCA is 6870 feet. Both can launch a 753, which has about the same run as a 737. Also, considering that DL will be flying 767s from BUR, a 753 out of a runway about the same length at DCA is no problem.
aerobalance
RE: SNA Or DCA
SNA 19R/1L is 5700 ft. in length.
Don't know if a 753 can get in or out of there.
"Sing a song, play guitar, make it snappy..."
DeltaMIA
RE: SNA Or DCA
Wed Feb 02, 2005 9:43 am
When will this be? If any equipment change this route will become a 738 by June.
It's a big building with patients, but that's not important right now.
LMP737
RE: SNA Or DCA
Wed Feb 02, 2005 9:53 am
Fed Ex flies A310's into John Wayne all the time. In fact one time I saw them fly in an A300. Granted it probably wasn't flying in, or out, with a full load. So I would imagine that a 757-300 could get in as well.
AirWillie6475
RE: SNA Or DCA
Wed Feb 02, 2005 10:26 am
According to their website delta will fly a 767 out of burbank.
AADC10
RE: SNA Or DCA
Wed Feb 02, 2005 10:43 am
The Delta press release says it will be a 757 out of BUR.
http://news.delta.com/article_display.cfm?article_id=9390
I doubt that Delta would allocate a 767 to BUR because it does not really have the facilities (not enough passenger screening facilities, waiting room areas, airline lounges or cargo facilities) or demand. Considering that some Southwest 737s required a fuel stop after departing BUR when taking off to the north, a 767 would have to be mostly empty to get out of there.
aaflt1871
RE: SNA Or DCA
Wed Feb 02, 2005 11:33 am
Also, DCA can handle aircraft up to the 762, though no airline has flown one in yet. So the 753 would be no problem. I have heard on here that ATA has flown the 753 in to DCA, though I have not seen it for myself yet.
Where did everybody go?
September11
RE: SNA Or DCA
Wed Feb 02, 2005 11:44 am
My thoughts: a 762 at DCA? I'll say nope - never will. Not even 753 - maybe, who knows.
Airliners.net of the Future
iowaman
RE: SNA Or DCA
Wed Feb 02, 2005 12:24 pm
Full of pax and fuel I would say no.
753's already fly there I believe.
AsstChiefMark
RE: SNA Or DCA
Wed Feb 02, 2005 12:43 pm
Would someone please translate the original question? I'm getting a headache trying to read it. Thanks.
Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Red tail...Damned MSP...Red tail...Red tail
aaflt1871
RE: SNA Or DCA
Wed Feb 02, 2005 12:53 pm
It can be done and approved, but once again as I stated no airline has opted a 762 on that route. I always thought DL would be the best option of seeing that happen. The biggest plane DCA has seen was the UA DC-10 back in 98 or so.
Basically what he is asking is can DCA or SNA handle a 753 aircraft. Due to their somewhat short runways is their enough room for them to reach V 1 and rotate safely. The answer to both is yes.
Take note, do not type in all caps locks.
AirWillie6475
RE: SNA Or DCA
Wed Feb 02, 2005 1:58 pm
If delta is going to bring in a 757 witch gate are they going to use? Are the gates big enough?
DeltaMIA
RE: SNA Or DCA
Wed Feb 02, 2005 3:43 pm
Delta along with Skywest will be utilizing B4.
Airlinerfreak
RE: SNA Or DCA
Wed Feb 02, 2005 3:46 pm
Anywho getting back on topic, I think it would be a tight fit but the 757 could make it out of both airports.
DeltaMIA
RE: SNA Or DCA
Wed Feb 02, 2005 4:14 pm
The 757 does fly out of both airports several times a day.
ANCFlyer
RE: SNA Or DCA
Wed Feb 02, 2005 4:18 pm
Yup, I was there . . . . tstrms everywhere. Pilot made some bad calls as it turned out and had no place he could go but DCA. There was another thread here a few months ago about that. IAD, BWI, ADW all down for wx, and this DC-10 was way low on gas . . . so DCA it was . . .
futureatp
RE: SNA Or DCA
Wed Feb 02, 2005 4:41 pm
The quick answer to the posted question is; easily.
It is not the size of the aircraft. It is the power to wheight ratio and the airspeed required to generate enough lift over the airfoil. So the question would be how much a 753 out of SNA (or DCA) would be wheight restricted. Meaning a cap on fuel and or pax. Limiting one in range and or payload. Unfortanately I can't answer that because I dont have access to 753 performance data.
I can remember watching in 1989/1990 a HP 747 departing out of PHX. I would have been only 9 years old at the time but I still remember vividly. Anyway HP was still operating out of terminal 3 in PHX. I was watching aircraft departing to the west on runway 26L (or was it rnwy 25 at the time?). HP 737-300s (at the time I also knew the difference between a 200/300) were not airborne until passing west of the terminal. But a HP 747 was wheels up before being abeam the terminal 3's main south concourse. Could not have been more than 4000ft of rnwy used. So the 74 was obviously headed to vegas. Very light fuel load. And more recently the same could have been said about the perfomance of the BA 747s doing the PHX-SAN hops(before anybody calls me a lair on that, BA discountinued that route in 2001.). Put any 757 takeoff I've ever seen to shame.
John
flynavy
RE: SNA Or DCA
Wed Feb 02, 2005 6:37 pm
DCA can handle up to a 767-300 if need be. There are only a few gates with enough wing width to accomodate them. In other words, if AA scheduled a 767-300 into DCA, there wouldn't be much opposition from MWA, however, it would hinder the efficiency of ground operations there. Refer to my post on a previous thread regarding heavies at DCA: http://www.airliners.net/discussions/general_aviation/read.main/1892697/6/.
Change is: one airline, six continents!
flynavy
RE: SNA Or DCA
Wed Feb 02, 2005 6:38 pm
Also, I forgot to mention that at one point, for about a month or so, Eastern used an A300 into/out of DCA on their shuttle services, albiet a trial run.
Kohflot
RE: SNA Or DCA
Thu Feb 03, 2005 2:53 am
The problem with a 753 at SNA would likely be parking. At a gate, it'll probably stick out too far into the taxiway.
Ask why..
LMP737
RE: SNA Or DCA
Thu Feb 03, 2005 10:00 am
Kohflot:
Parking would be a problem. The only gate you could park it would be gate14 which is at the end of the terminal.
