redtailmsp
Nwa 747 Freighters
Thu Feb 03, 2005 2:25 pm
Aircraft 6632, a passenger 747-200 is to position out of storage at Marana to MSP in a few days. It will then position on to Tel Aviv to be converted into a freighter aircraft - this will be in about a week or so. After this aircraft is converted, aircraft 6631 will then also be converted. (6631 is currently in passenger service). These aircraft will just have side cargo doors. Don't know how long the conversion process will be, or if 6631 will go to TLV when 6632 comes back. Incidentally, in the NWA fleet numbering system 6632 is now referred to as 6732 - all the passnger 747-200s were in the 66xx series and the 747-200 freighters are in the 67xx series. This will make 12 freighters in all. I presume that when 6632....or should I say 6732, comes back from TLV, it will be in some form of new paint scheme incorporating the new tail design.
LAXintl
RE: Nwa 747 Freighters
Thu Feb 03, 2005 3:01 pm
N643NW however will be leaving this year once its lease term is up.
FlyGuyClt
Thu Feb 03, 2005 8:39 pm
Won't this make 14 freighters?
Safe Flying  Smile
Fleet
The airline operates a fleet of more than 400 aircraft including Boeing 747s, and 757s, McDonnell-Douglas DC-9s and DC-10s and Airbus A330s, A320s and A319s. Northwest also is one of the world's largest cargo airlines, operating a dedicated fleet of 12 B747 freighters.
From www.nwa.com
[Edited 2005-02-03 12:41:13]
Florida Express, Braniff II and ......
PhilSquares
Thu Feb 03, 2005 11:59 pm
Just to let you know, the only mod for the SF is the main deck floor, cargo handling system and side door. There is no way to install a door. Holds true for the 744 SF mod.
Fly fast, live slow
jetjack74
Fri Feb 04, 2005 12:41 am
They will be the same as the 2 UA 747conversions we picked up 3 years ago. Ships 6743, 44.
Made from jets!
SATL382G
Fri Feb 04, 2005 12:43 am
Phil,
Leave out a word? Don't you mean "no way to install a nose door" ?
regards
PhilSquares
Fri Feb 04, 2005 4:56 am
SATL382G,
You're right. It's been a long day. Went JFK-AMS and was typing that when I should have been sleeping!
Fly fast, live slow
Boeing757/767
Fri Feb 04, 2005 5:01 am
In the NW Q4 analyst/media call, CEO Steenland said the freighter fleet will grow to 14 with the addition of two aircraft being configured.
Free-thinking, left-leaning secularist
Tod
Fri Feb 04, 2005 5:18 am
Don't forget that the air dist get completely replaced from back of the u/d all the way back. Lower lobe cargo heat must also be added to compensate for the loss of pax related e/e bay heat dumped into that area. Underdashboard style air inlets get added to the cockpit for positive pressure in a smoke event. Venturi hole popped into the right side of the upper deck for lav ventilation. U/D stairs replaced. The story goes on for pages . . . . . .
But you are quite correct, no nose door. That would cost more than the plane is worth. Especially if anyone but Boeing tried to get it certified by the FAA.
PhilSquares
Fri Feb 04, 2005 5:43 am
Tod,
You're absolutely correct. The list could go on for ages. However, as you pointed out, the purpose was to make sure everyone knows the nose door is not an option. Even on the 744SF conversion.
Fly fast, live slow
