usair330
PHL Going Ahead With 17-35 Extension!
Sat Feb 05, 2005 5:32 am
http://www.phlrunway17-35eis.com/
Do you guys think this will make much of a diffrence with the delays that occur in PHL or no?
PHLBOS
RE: PHL Going Ahead With 17-35 Extension!
Sat Feb 05, 2005 6:05 am
The extension of R/W 17-35 will allow more mainline airliners to utilize it more often. Prior to the recent 12 foot shoulders that were added on both sides, very rarely did one see a mainline jet (like a 737) land on it. In the 14 1/2 years I've lived in the area, I've never seen nor heard of a mainline jet ever using the runway for take-offs. However, within the past year, many PHL spotters have seen 737s from both US and WN along with some US A319s occasionally use Runway 35 for landings. To my knowledge, even with the shoulder upgrades that were added 3 years ago, no mainline jet uses the runway for take-offs nor land in the Runway 17 direction.
The short answer to your question is, "Yes, the runway extension will help ease some of the congestion delays at PHL; but not all."
This runway extension is an interim solution. The ultimate solution will come later with a plan to re-align the main runways and add an additional parallel runway.
"TransEastern! You'll feel like you've never left the ground because we treat you like dirt!" SNL Parady ad circa 1981
7e72004
Sat Feb 05, 2005 6:11 am
this is a dumb question but is the runway everyone is talking about the one that runs "east-west?"
The next generation of aircraft is just around the corner!
N670UW
Sat Feb 05, 2005 6:13 am
No. A 17-35 (at any airport) would run generally north-south. PHL's 9-27's run east and west.
N670UW
7e72004
Sat Feb 05, 2005 6:14 am
i see...it has been a while (3 years) since i have been to PHL.  Big grin
ACAfan
Sat Feb 05, 2005 6:19 am
The small runway on the left.
Photo © Derek Hellmann
Freddie Laker ... May be at peace with his maker ... But he is a persona non grata ... with IATA
runway27right
Sat Feb 05, 2005 8:03 am
I believe the rolling hub plan, which goes into effect Feb. 8th will ease a lot more of the delays than the Runway 17-35 extension. On watching much of the goings on at PHL, it seems like taxiway clutter is another addition to the delay factor. There's still going to be cross traffic. There hasn't been a day I've been to PHL where a plane has to go around, mostly on 35, because of landing traffic on the 27's. So now some of this traffic will be using 17/35. So the big question is, will it cause more go arounds? I expect it to stay the same, but now instead of the smaller stuff going around, you'll have the big carriers going around. Which I don't think they will care for  Smile
BTW, you can figure out runway directions like this. 90 degs is East, take off the '0' and you'll have the runway, so Runway 17 is 170 degs., 35 is 350 degs. (360 degs is North).
Paul
Keeping PHL Spotting Alive Daily!
USAFHummer
Sat Feb 05, 2005 8:27 am
They also wanted to extend 8/26 another 2000 ft. or so to the east, but they can't do it because the Kvaerner shipyard crane is too tall and close to what would be the new glideslope for 26...I think you'll definitely see an increase in mainline traffic on 17/35 when this is done, particularly by airlines in Terms D and E (read: WN will love this!), since 17/35 runs close to Terms D and E and will significantly reduce taxi times...
Greg
UALPHLCS
Sat Feb 05, 2005 11:23 am
Yes, recently they have really stepped up use of 17/35.
In the first 5 years of my time at PHL I saw two A320's and 1 737 land on 17/35. However in my last six months, landings by larger jets was a daily occurance. Then, just days before my layoff they landed a US 757 on it.
Will it help? Sure.
Will it solve PHL's problem forever. Hell No.
Only a complete runway reconfiguration can do that.
A little less Hooah, and a little more Dooah.
ERJ170
Sat Feb 05, 2005 11:27 am
My last visit to PHL (about 2 weeks ago), I had an 1.5 hour layover and during that time, I saw about 15 737 (US/WN) aircraft land on 17/35 during that time.. but I saw not a single one take-off on that runway.. I was quite perplexed and ticked off cause when my flight pulled out from the gate, it was about 30 aircraft in que ahead of us..
Aiming High and going far..
MD11LuxuryLinr
Sat Feb 05, 2005 11:34 am
I didn't see it state the length of the extension anywhere.. Anyone see it?
Caution wake turbulence, you are following a heavy jet.
wagz
Sat Feb 05, 2005 12:58 pm
There were 2 plans for the extension. The longer of the two making it 7000 feet total I beleive, and eradicating Rt 291 in the process.
Chris, I was working the 104 bus one day a few weeks ago when the 9s/17 were in use. It was the day a large hole was found on 9L and it was closed for 4 hours. I saw at least 3 WN 737s, 1 or 2 US 737s and a US A320 all on final for 17. For the record, 17 arrivals actually pass about 1200 to 1500 feet or so above the 69th St Terminal Area. There are some pretty good views from there.
Joe
I think Big Foot is blurry... It's not the photographers fault. There's a large out of focus monster roaming the countryside.
Theiler
Sat Feb 05, 2005 3:08 pm
Lengthening 17/35 ought to be interesting - I'm thinking that it will actually be more valuable for non-commercial aircraft. Philly has a good amount of non-commercial traffic (Business jets,etc). But many probably can't accept a 5000' runway for takeoffs?
Atlantic is located very close to 17/35. As I recall, we had a rather annoying taxi (at Philly?! haha) when we were down there last year, as we had to hold short a cross at least one other active runway, prior to reaching the departure runway.
wagz
Sat Feb 05, 2005 3:34 pm
Yep. You have to cross 27R to get to 27L for departures. It's really not that bad though. The worst part is the huge bottleneck when 30 aircraft get to the runway simaltaneously.
Now, when the 9s are in use, arrivals on 9R must then cross the departures on 9L. For some reason that always takes much longer.
By the way, call me an idiot, but where does it actually say on the site linked in the original post that the plan is actually going through? In fact it says on the main page that "This site will provide you current information about the Environmental Impact Statement (EIS) for the proposed Runway Extension Project (Runway 17-35 Project)".
Also, the residents of Southwest Philly are still in a shit storm about how the increased traffic will be ruining their lives.
Joe
swadispatcher
Sat Feb 05, 2005 3:54 pm
I'm very glad to hear this.. I almost always plan departures off of 35 because it cuts down on taxi time.
I'm also glad to hear that US is making PHL a rolling hub. Maybe that will ease the holding experienced going into there. The weather was severe clear there today and we still had a stupid ground delay program.. absolutely amazing!
Maintain 2300 until Boiler, cleared for the VOR-A approach, report BATLE inbound..
concord977
Sat Feb 05, 2005 4:03 pm
" ... didn't see it state the length of the extension anywhere.. Anyone see it? ... "
It was buried in there somehwere:
Alternative 1 - Standard Runway Safety Areas
Alternative 1 would extend Runway 17-35 to the north by 640 feet and to the south by 400 feet from its existing length of 5,460 feet to a proposed total length of 6,500 feet. A new Runway Safety Area, a flat unpaved surface at the end of the runway that allows airplanes that overshoot or undershoot the runway to stop safely, would extend 1,000 feet beyond the new extensions on both ends. Alternative 1 would potentially require the relocation of a portion of State Route 291. Tall shipping vessel obstructions on the Delaware River would be avoided by discontinuing the use of Runway 35 (south end) for landings when ships are present. This would occur on average four times per day for 15 minutes.
Alternative 2 - Engineered Material Arresting System (EMAS) and Displaced Threshold
Alternative 2 would extend Runway 17-35 to the north by 1,140 feet and to the south by 400 feet from its existing length of 5,460 feet to a proposed total length of 7,000 feet. A new Runway Safety Area would extend 500 feet beyond the extension to the north. An Engineered Material Arresting System (EMAS), collapsible concrete blocks that stop an overrunning aircraft in a shorter distance than a standard unpaved safety area, would be placed in this Runway Safety Area. A new Runway Safety Area would extend 1,000 feet beyond the new extension to the south. Alternative 2 would accommodate tall shipping vessel obstructions on the Delaware River by displacing landings from the south by 1,444 feet to the north of the unpaved runway end and would accommodate I-95 by displacing landings from the north by 500 feet to the south of the unpaved runway end. The use of a displaced threshold means that planes land at a certain point, or threshold, on the runway that is different, or displaced, from the physical runway end.
No info
crownvic
Sat Feb 05, 2005 4:27 pm
It would be silly, not to extend Philly!
Go Eagles!
usair330
Sat Feb 05, 2005 8:06 pm
Thanx for responding guys!!!
"where does it actually say on the site linked in the original post that the plan is actually going through?"
I'm just assuming they are simply because it's on PHL's homepage. Obviously I was wrong for saying they are going ahead with the extension, sorry.  Nuts
