markk
Continental 735 1st Class Reconfiguration
Sun Feb 13, 2005 3:02 am
So I have read rumors on here for a while that CO was going to yank a row out of 1st on their 735's. During booking of a trip from SFO-IAH I ran across a 735 and the seat map shows this new 2 row F class configuration but still 5-21 in coach. If you book on row 5 hoping for a bulkhead in coach is it possible that your row 5 might just be the second row in coach now?
Falcon84
RE: Continental 735 1st Class Reconfiguration
Sun Feb 13, 2005 3:04 am
CO is going from 10/94 config to a 6/108 config on the 735's. As far as the row numbers, I haven't seen what the layout is. Maybe I'll look at work monday and see if I can find out.
Work Right, Fly Hard
markk
Sun Feb 13, 2005 3:08 am
Wow. They are adding 14 seats? That is more than two rows of coach. Where are they other 2 seats coming from? Are they changing the current seat pitch (31 in I believe)
DeltaMIA
Sun Feb 13, 2005 3:10 am
What is the configuration of F class. One row on left side, 2 rows on right side?
It's a big building with patients, but that's not important right now.
N1120A
Sun Feb 13, 2005 3:47 am
>What is the configuration of F class. One row on left side, 2 rows on right side?<
It is 2x2, hence the drop from 10 to 6
AeroWesty
Sun Feb 13, 2005 3:52 am
:: chuckle :: I think that's obvious. He was asking which side of the plane will have 1 row of 2 and which will have 2 rows of 2. Hence 2 + 4 = 6.
International Homo of Mystery
markk
Sun Feb 13, 2005 4:01 am
looking from back to front. The right side has one row and a closet. The left side has two rows then the bulkhead between the main cabin door and 1st
toltommy
Sun Feb 13, 2005 11:57 am
It's CO's version of MRTC. Sadly, it only means "More Rows Thoughout Coach"...
6 FC seats and a 31 inch pitch? If the long haul ERJ flying from CLE hadn't chased this former Plat Elite away, these kind of changes on the mainline fleet sure would! I moved over to NW, and have been quite happy. I'll take a DC9 over an ERJ any day.
CAL
Sun Feb 13, 2005 12:49 pm
The correct configuration is 6/106 not 6/108
also row 5 will be behind first class row 2
They are removing the bulkhead wall and the seat pocket on the first class seat will be the seat pocket for coach row 5 which will now be closer to the front. Instead of an actuall bulkhead wall there will be what they are calling a "european style class divider".(whatever that means)
Continental always starts coach with row five except when first class has 5 or more rows (example: 737-900 in that case coach starts at row 6)
On the 737-500 reconfigured it will be rows 1-2 first and rows 5-24 coach, All the rows will get re-numbered.
Continental should have the updated seat map for the 737-500 sometime at the end of this month.
Remember that both versions will be flying for some time.
Ships - 616, 630, 642, 644, 645, 650-652, change to (73K) in feb
Thats what they are calling it, the 73K
Photo © Bruce Leibowitz
Photo © Stuart Prince
CAL........Continental Airlines....... Work Hard, Fly Right
bnatraveler
Sun Feb 13, 2005 12:56 pm
hmm.... 73KL
737-KRAPPY
737-KILL FREQUENT FLIERS
737-KOACH
737-KOCKROACH (as they call the low fare upgraders)
John
Sun Feb 13, 2005 3:16 pm
I can't believe their configuration on the 757-300, F12Y210. Only 12 f/c seats on a 753? Seems odd. Honestly, why bother with a first class section at all on the 737-500?
CB777
Sun Feb 13, 2005 9:19 pm
Maybe CO should look at replacing their B737-500's with the Embraer 190's.
Probably a cheaper airplane to operate.
nucsh
Sun Feb 13, 2005 9:37 pm
Older planes are always cheaper to operate than newer ones... (well, almost always, but in this case the 735 would definately be cheeper)
If landing is about "kissing" the ground, you just about raped it.
CAL
Mon Feb 14, 2005 7:42 am
Not really the 737-500's have very high lease payments from what i understand, Larry and Gordon both have said that its the first aircraft that needs to go.
ANNOYEDFA
Mon Feb 14, 2005 9:18 am
BNATRAVLER: Here's a better one 73K A S H....... If the coach seats are making money why not put more in?
John: The 75-300 is for high density LOW Y I E L D flying pack them in. If the other 12 first class seats were going out empty or with free upgrades why not put in more coach and make money? Hmmmmm, makes sence right?
The 73-500's have very high lease rates and they are far from old. Too bad they can't renegotiate the leasing terms. They are excellent jets!
"TWA... One Mission, Yours."
NLINK
Mon Feb 14, 2005 9:59 am
Doesn't seem worth it a couple extra seats since you have to have a 3rd FA onboard since it will be over 100 seats total now.
CO2BGR
Mon Feb 14, 2005 10:18 am
Nlink- try adding 10 and 94 thats 104 it always had 3 FAs
There are too many self indulgent weiners in this town with too much bloody money" Randal Raines- Gone in 60 Seconds
