CRJ900
A300NG - Possible?
Mon Feb 14, 2005 9:27 pm
"Everyone" is wondering why Airbus hasn't come up with an A300 replacement.
And I wonder (as always): as Airbus is becoming notorious for shortening, stretching and enhancing their products already flying, why do they not develop a Next Generation A300, so that they can offer something competitive in the 200-seat category without too much "fuss"?
How about an A300-600 design featuring the "Enhancements" from the A345 and A346: FBW, fly-by-wire rudder, new Thales active matrix LCD-screens, revised pax cabin and RR Trent 556-560 engines? Such an aircraft would be beneficial to LH and Thai, giving them a modern short-medium haul 200-225-seat aircraft to complement their larger medium-longer range siblings (333 + 345 + 346) while having an identical cockpit and engines (RR Trent 500 + 700).
Obviously, it would require some work to do this, but wouldn't it be a good idea? The A300 has a proven track record of reliability and efficiency, so why change the aircraft like they wanted to by offering a A330-100 with a heavy wing? Surely it would be cheaper to make an A300NG than an all-new design?
Am I on to something or just talking bollocks?
Comments appreciated...
[Edited 2005-02-14 13:41:41]
Come, fly the prevailing winds with me
b752fanatic
RE: A300NG - Possible?
Mon Feb 14, 2005 9:32 pm
I thought that the A330 was the replacement.
"Truth is more of a stranger than fiction." Mark Twain
bill142
Mon Feb 14, 2005 9:37 pm
The line will probably close within the next few years. No one is buying A300's anymore only cargo variants. UPS just cancelled a whole heap of A300's in favour of the A380.
Rj111
Mon Feb 14, 2005 9:38 pm
Well it's not reknown for reliability.
The A300's still quite a good plane, it only weighs about 90t (It will be interesting to see how much the 783 weighs), which is good for a aircraft of it's size with it's cargo capabilities. They'd have to make it FBW though in order to be compatible with the A330/A340/A350, which could be costly. It's certainly worth an investigation however.
The A332's too heavy (122t IIRC) to be an effective replacement.
curlyheadboy
Mon Feb 14, 2005 10:02 pm
I belive that for the upcoming future A. chose to go for the A350 in that category, an upgrade of the A300 doesn't fit into this plan.
If God had wanted men to fly he would have given them more money...
aerlingus330
Mon Feb 14, 2005 10:24 pm
If Airbus were going to make an A300NG, they wouldnt call it the A300NG. They would do what they always do and call it a different family like they did with the A318, A319, A320 and the A321 (they are in the same family, but with different names). So we will probley never see an A300NG, it will probley live on as an other name in the near future.
aerlingus330
Aer Lingus Airbus A330-300
DAYflyer
Mon Feb 14, 2005 10:59 pm
I think an A-321 is a replacement for the 300 with a little stretch.
One Nation Under God
A350
Mon Feb 14, 2005 11:16 pm
I think it will come, but it not be based on the technology of the current A330/340. It will have the lighter fuselage and the avionics of the A350 and Trent 1000 or GeNX engines in the 50000 lbs thrust class. It will either have the length of the A300 or that of the A332. The wings will probably revised A300 wings. A possible name is A330-800.
This is nothing than speculation, of course, but I think it's the best they can do with their possibilities and it would make sense.
A350
leelaw
Mon Feb 14, 2005 11:47 pm
Haven't AF, TG, and LH been replacing the A300 with the A332/A333? Why hasn't the weight differential been an issue for them? AA (34) and JL (22) are now the largest remaining pax operators of the A300. Neither seems a likely customer for an updated version of the A300.
Lex Ancilla Justitiae
Rj111
Tue Feb 15, 2005 12:01 am
LH thought the A332 was generally too heavy, let alone for short haul. The A332 was only leased in till the A333's arrived. AF replaced the A300 with A32X's and TG are still a large operator of young A300's and have no intent on replacing them.
KL808
Tue Feb 15, 2005 12:13 am
This might be a good idea, having a more composite body, FBW and new avionics and interior might give the aircraft new life.
But how much are we talking about here, this could be very expensive, and I believe for a little bit more money you can get a clean sheet design.
Drew
AMS-LAX-MNL
A350
In contrast to AF @ CDG, LH is slot restricted at FRA and cannot simply replace one A300 flight by two A319s. They are still operating about 12 of them and don't have plans to phase them out. They are a potential customer for an A300NG (whatever its name will be).
A350
keesje
Tue Feb 15, 2005 1:23 am
I think Boeing/Airbus will be going single aisle for a new 200-220 short/medium range aircraft.
Operating cost are so much lower then a twin aisle & nobody really needs a large cargo capasity on the short routes anymore (dedicated & cheaper operators / aircraft / roadtransports take over).
I still suspect Airbus to be looking at a heavy 32x, a A322 or something for this market.
gigneil
Tue Feb 15, 2005 1:27 am
This is a well discussed topic.
The A305 is what's been rumored, and it will come after the A350.
N
N1120A
Tue Feb 15, 2005 1:34 am
>I think an A-321 is a replacement for the 300 with a little stretch.<
The problem with this, as well as a heavier A32S is simple. The A300's strength is not actually its passenger capacity, rather its ability to carry cargo. This is because the A300 is a widebody, and especially wide for its size. An A320 based replacement would be a narrowbody and would not have the same capability. Additionally, the range would be pathetic.
The A305 is the best replacement that Airbus has mentioned, though the 787 is by far the best replacement actually offered.
su184
Tue Feb 15, 2005 1:37 am
Airbus had such a plan few years ago, combining the A330 fuselage including cockpit and systems with a revised, more efficient A300 wing and new engines, the A300 wing idea was to have a smaller span wing than the A330, to allow the aircraft to fit into A300's gates/stands, this held back some airlines from ordering A332's as A306 replacments. This was in response to reqiurements of Lufhansa to replace their A300-600's and Hapag Lloyd (A310) but the the plan never went further, I think tit would have appealed to other airlines too.
aerlingus330
Tue Feb 15, 2005 2:51 am
Since the A350 is only in the begining stages, and the only pictures we have of it are all A330-200/A330-300 with a computer generated liverys saying A350 on it.
Its possible that the A350 could be the long awaited new A300? Could this be Airbus` greatest weapon against the 787?
aerlingus330
gigneil
Tue Feb 15, 2005 2:57 am
Please.
The 7E7-3 is a 300 seat plane. That's hardly a good replacement for a 190-250 seat family.
N
DeltaWings
Tue Feb 15, 2005 3:07 am
Please.
The 7e7-3 has very similar size to the A300. You just compared a two class seating on the 7e3 with a three class layout on the A300, or so. The A300 can take 375 in all economy, the 7e3 will be similar.
~DeltaWings
Homer: Marge, it takes two to lie. One to lie and one to listen.
