AC_B777
Delta 763 Emergency Landing @ YYT Last Night
Wed Feb 16, 2005 7:18 am
DL flight 59, a 767-332ER from LGW-ATL made a full emergency landing last night in YYT due to smoke in the cockpit. The registration was N187DN.
From what I was told, the crew declared a mayday and not a Pan Pan.
I'm not sure of how many pax were on board.
A replacement a/c was sent up with maintenance personnel to check 187 and to pick up the passengers to continue the flight to ATL, however, due to fog in ATL, the flight was diverted to JFK.
AC serviced the a/c and we dispatched 187 around 1250 local time today with just flight crew and maintenance personnel on board.
In life, some days you are the bug..... some days you are the windshield!
roseflyer
RE: Delta 763 Emergency Landing @ YYT Last Night
Wed Feb 16, 2005 7:55 am
Wow that is so absolutely horrible. Having your flight divert due to smoke in the cockpit. That would unnerve you, and then to have a new plane take off, but have to divert again this time due to weather. I bet there will be some people on that plane not wanting to fly again after that ordeal because they would feel that they are cursed.
767-332ER
Wed Feb 16, 2005 9:53 am
Sorry to hear that as I've flown on N187DN many times...I will be flying a DL 767-300ER in about two weeks, so hopefully no trends are begining here... Big grin
Regards and glad everyone's ok
Twinjets...if one fails, work the other one twice as hard!!!
skibum9
Wed Feb 16, 2005 9:56 am
Looks like the original plane is scheduled back in ATL today.....
FlightID: DAL9905
Status: FILED
Filed With: CCZX - GANDER
Equipment: /B763/W
Proposed Departure Time: 1600Z
Departing: CYYT ST JOHNS INTL
Destination: ATL HARTSFIELD - JACKSON ATLANTA INTL
Route of Flight: CYYT..YYT..ACK..HTO..RBV..GVE.J37.COLZI..ODF.MACEY2.KATL
ETA: 1733
Speed: 475
Altitude: 360
Tailwinds!!!
1MillionFlyer
Wed Feb 16, 2005 10:09 am
I had a smoke in the Cabin emergency landing on a DL MD11 from AMS-ATL in December 2002, let me tell you that was a very nerve wracking expereience.
I hope they didn't have to fly too long in that condition.
We diverted to IAD in my case but I was a little freaked out wondering if it had happened between Keflavik and Gander how those extra minutes would have been spent.
Golf Foxtrot you are cleared for departure
Bruce
Wed Feb 16, 2005 11:56 am
What in the world is a "pan-pan"????????
bruce
EnviroTO
Wed Feb 16, 2005 12:04 pm
Serious problems but not declaring an emergency. Mayday is the highest level.
airgeek12
Wed Feb 16, 2005 12:09 pm
Do we know what the cause of the "smoke in the cockpit" is?
geek
imatams
Wed Feb 16, 2005 1:52 pm
Quoting Airgeek12 (reply 7):
Well usually it means something's burning... Smokin cool
No, seriously....In the most (in)famous case of smoke in the cockpit - the Swissair MD-11 that crashed of Nova Scotia - The smoke was caused by flammable insulting materials that caught fire due to bad cockpit wiring I believe...Guess their could be lots of reasons, though i'd speculate that cockpit wiring would be a likely cause...
IM
4Left
Wed Feb 16, 2005 9:53 pm
Pan Pan is an urgent radio message regarding the safety of people and property. A Pan Pan message is not used when there is an immediate threat of life and property, instead a Mayday call is used. As with Mayday, Pan Pan messages have priority on the radio channels and are not interupted.
Source Everything Sailing Book pg. 303
Planes aren't busses, put service back into the air!
lawgman
Wed Feb 16, 2005 11:22 pm
Quoting IMatAMS (reply 8):
I thought it was bad wiring from the IFE system.
gearup
Wed Feb 16, 2005 11:34 pm
Correct, it was, but the wiring in question was near the cockpit.
GU
I have no memory of this place.
milan320
Thu Feb 17, 2005 1:11 am
Quoting Gearup (reply 11):
Not only that, but from a documentary I saw, the wiring initially passed the FAAs flammable tests years ago. However, those tests were flawed originally the way they were setup. In fact the wiring burned faster than it should have.
The documentary showed that had the wiring been tested today, with different procedures, it would never have passed the test.
I believe it was a Nova documentary.
Anyway, I might have gotten some facts off, but below is a link to the TSB report regarding that awful crash:
http://www.tsb.gc.ca/en/reports/air/1998/a98h0003/a98h0003.asp
/Milan320
I accept bribes ... :-)
JFKviaPHX
Thu Feb 17, 2005 1:25 am
DL just had a bad day yesterday. Especially at JFK.
L1011Lover
Thu Feb 17, 2005 2:06 am
Great job DL!!!
The only right thing to do with a smoke problem on an aircraft is to declare emergency and bring that ship down at the nearest suitable place, with the least possible delay!
Who knows if SR111 might have had a better ending if they would have had declared mayday instead of the pan pan...
curlyheadboy
Thu Feb 17, 2005 4:50 am
They might have had a better ending if the crew had decided to land overweight instead of circling for dumping fuel, that's the way they lost precious minutes. This is the fact i can't give an answer to when i think about the SR111 tragedy, if only they had landed immediately... How could they underestimate a smoke source that forced them to wear oxygen masks? We'll never know, and it's so sad  Sad
If God had wanted men to fly he would have given them more money...
B707Stu
Thu Feb 17, 2005 4:52 am
I'm sure the IFE wiring will be the first source lead in the investigation. Does anyone know if passengers made emergency exit through the shoots? I'm assuming if they called a Mayday they did but it would be interesting to know. I wonder how much time it took to evacuate. Where do we go to find the report on this incident?
SATL382G
Thu Feb 17, 2005 5:37 am
insulting materials
Quoting B707Stu (reply 16):
That's it!! Insult the materials then get shot as you exit thru the shoots!!
That's why the pilot declared mayday!!
mconway
Thu Feb 17, 2005 5:58 am
IIRC, the TSB determined that had SWR111 made an immediate diversion to YHZ when they first became aware of the seriousness of the problem with the intent to make an overweight landing, they still would not have made the airport in time to save the plane. I guess there's no way to say with absolute certainty if this would have been the case though.
Regards.
SATL382G
Thu Feb 17, 2005 6:21 am
Still it's not lost on many crews flying today that SR111 lost time that might have made the difference. Remember the SR111 crew did not have the benefit of 20/20 hindsight, had they known what we know today I bet they'd have made straight for Halifax and dumped what fuel they could on the way.
777STL
Thu Feb 17, 2005 6:57 am
Don't forget Valujet 592. There is a precedent for smoke in the cockpit situations to not have happy endings.
-77
PHX based
imatams
Thu Feb 17, 2005 6:58 am
Quoting SATL382G (reply 19):
Considering that, as far as I know, it took them a while to figure out how serious it was, and considering how close the crashsite is to Halifax, i'm sure just minutes would have made LOTS of difference....I was at the crashsite memorial some years ago...sad story indeed...
777STL
Thu Feb 17, 2005 7:18 am
"Considering that, as far as I know, it took them a while to figure out how serious it was, and considering how close the crashsite is to Halifax, i'm sure just minutes would have made LOTS of difference....I was at the crashsite memorial some years ago...sad story indeed..."
I believe that's because after they initially fired off the "Pan, Pan, Pan" they wanted to divert to Boston. Only when they realized the gravity of the situation was when they decided to attempt Halifax.
-77
PHX based
curlyheadboy
Thu Feb 17, 2005 8:45 am
They asked a diversion to Boston but the ATC immediately suggested Halifax as the nearest airfield available. Shortly after, the Swissair crew agreed YHZ was better. The thing i don't understand is why they decided to turn south for dumping fuel... i mean they had to wear oxygen masks well before their ability to control the aircraft started deteriorating quickly, when the fatal decision to go for the fuel dump was taken they already had a lot of smoke in the cockpit. My guess is that they could have thought that smoke was coming along the bleed air from engine 3 (that was infact shut down moments before impact), when instead there was a fire from burning insulation in the cabin. An engine fire would have been a serious problem but not as deadly as a cabin fire. Maybe they were misled by this wrong interpretation of the smoke source...
Hardkor
Thu Feb 17, 2005 10:41 am
SR111 simply had too much fuel to land safely, they were going to dump fuel over land I believe, but ATC stated they had to go over the ocean. Plenty of whatifs with this tragedy, it just would have been impossible for the pilots to realize how serious things really were. I've been to the crash site twice, may they all RIP
Hardkor
SATL382G
Thu Feb 17, 2005 11:00 am
If you land overweight, you do a overweight landing inspection & maybe some paperwork. Dump as much gas as you can on the way in. Beats diving it into the ocean.
In an emergency the Capt can do pretty much what he needs to do, screw ATC.
[Edited 2005-02-17 03:04:11]
skateruk
Thu Feb 17, 2005 7:02 pm
I suspect most flight crew would now get their aircraft on the ground asap now!
I know at BA that's what they're instructed to do... you've got a much better chance of surviving once the aircraft is on the ground, even if it is overweight. BA had a Miami bound aircraft in November last year that had smoke in the cabin/cockpit.. they immediately turned back to heathrow and prepared for an overweight landing.. however, smoke cleared as they were heading back, so they decided to monitor the situation and dump fuel to a safer weight...
That's when the guys up front earn their money!!
B707Stu
Fri Feb 18, 2005 4:08 am
SATL382G
I didn't follow your criticism about the shoots. Can you explain why my asking the question is irrelevant. I'm open to be educated. Is it mandatory once you declare a mayday, if you make it on the run, you must use shoots? Perhaps I'm naive here.
