AIR MALTA
Air FRance 5th Daily Flight To Tunis!
Mon Feb 21, 2005 6:18 pm
Air France is addding a fifth daily flight to Tunis for the summer season. This flight will depart Tunis at 02h30 in the morning. This is may be a response to Lufthansa flights which will also depart Tunis at around 02h30 AM. But in LH case, they are not adding new flights, just retiming the existing ones. I talked with a lot of LH frequent travellers : they are not happy about the schedules switch. Good move from AF though.
Next flights : BRU-ZRH-CAI (LX)/ BRU-FCO-TLV (AZ)
FlySSC
RE: Air FRance 5th Daily Flight To Tunis!
Mon Feb 21, 2005 7:04 pm
The problem was that the first AF flight leaves now TUN at 8:55 to arrive at CDG at 11:30, which is too late for a connection to a certain number of AF's Long-haul flights, leaving earlier.
This new frequency will land very early at CDG and will offer ALL the connections to the PAX from TUN.
AIR MALTA
Mon Feb 21, 2005 7:21 pm
Yes this is a goog move from AF as it is adding more choice. LH is not! It is forcing traveller to travel at impossible hours. As I know Tunisians, they will rush to Tunisair flights which will be more convenient. As for the connections offered by LH, they are also offred by AF at more convenient timings also. Shame not to see BA join the battle there as there is big market for passengers connecting to Montreal. A lot of them used to use BA as they offered cheaper flights versus AF or LH. But BAs timings are also BA now as flights depart LGW at 07h30 and arrive LGW at 14h00. LGW is not anymore as it used to BA. With such a service BA will get only point to point passengers, not even passengers transferring to other UK airports.
Pe@rson
Mon Feb 21, 2005 7:43 pm
So it'll arrive into CDG at about 0450 then. How many AF long-haul flights depart CDG up to and including 0800?
TS-IOR
Mon Feb 21, 2005 8:27 pm
TUN is very calm at night and these AF and LH flights will create a certain activity there...
Pe@rson, the flight may arrive CDG at 0600, because the flight time is 02:30 and do not forget that France is UTC+2 from April to October.
Pe@rson
Mon Feb 21, 2005 9:23 pm
According to Amadeus, this service will operate thrice-weekly (M, S, S), departing TUN at 0230 and arriving into CDG at 0605 using the 735.
FlySSC
Mon Feb 21, 2005 10:04 pm
Pe@rson,
The eraliest AF's long-haul flights are AF022 CDG-JFK at 08:25, AF566 CDG-BEY at 08:35
Several flights to Africa leave also around 10:XX (CKY, NIM, NKC, OUA), as well as flights to BOG, CCS, DEL, NRT, MIA, BOM ...
Add to this the connections to ALL AF'S European network.
