ramerinianair
Alaska Airlines, How Much For De-icing?
Mon Feb 28, 2005 2:37 pm
I just read a thread that had de-icing as $8.50 and $12.50 per gallon for types I and IV respectively. http://www.airliners.net/discussions...general_aviation/read.main/1977823
For a carrier like Alaskan and even other carriers who operate a large amount flights to cities which freeze over during the winter this must get expensive.
I wanted to know:
How much does it cost to de-ice a 737? (How many gallons on average)
What is the difference between type I and IV?
How much does a carriers like Alaskan pay a year for this service?
Steven
W N = my Worst Nightmare!!!!!
flyingnanook
RE: Alaska Airlines, How Much For De-icing?
Mon Feb 28, 2005 8:13 pm
I don't know the answers to your questions, but I do have a point to make. Just because a city freezes for the winter, doesn't mean that the planes have to be deiced. For example, FAI is below freezing for half the year. But Fairbanks has a very dry and cold climate, which is not conducive to icing. So deicing usually only occurs at the beginning and end of winter. I'm pretty sure that the same occurs in northern places like Barrow, Nome, and Kotzebue. The south, which includes places like Anchorage, Bethel, Juneau, and the panhandle, has a much moister climate so deicing probably occurs more often there than the northern half of the state.
Bear in mind, out of all the times I've stopped in ANC in winter, my plane has only been deiced once and that was in March. I've never been deiced in FAI.
Semper ubi sub ubi.
EA CO AS
Mon Feb 28, 2005 11:19 pm
I wanted to know:
Who is Alaskan Airlines, anyway....?  Big grin
Cactus739
Mon Feb 28, 2005 11:25 pm
EA CO AS
Its the new northwestern us division of American West.  Laugh out loud
You can't fix stupid.... - Ron White
ramerinianair
Tue Mar 01, 2005 1:51 am
Sorry about the typo Alaska. Does anybody know how much it costs to deice a 737 or similar?
SR
ntspelich
Tue Mar 01, 2005 2:35 am
Quoting RamerinianAir (reply 0):
Cost depends on how much glycol costs at the moment. Right now, as you said, it'd pretty high so de-icing a plane costs more. On average, a 737 I would guess uses a little over 50 gallons for a basic de-icing (no heavy snow, ice or other build up).
The difference between type I and IV is what it's used for. Type I is typically mixed with water aroung 50/50 and used for de-icing. It's orange in color.
Type IV is green in color and typically used 100% uncut and is used for anti-icing.
How much do they pay/year? Like I said that's up to the market price of glycol, number of de-icing events that year, amount of overtime needed to de-ice, etc.
NTS
United 717 heavy, you're facing the wrong way. Any chance you can powerback to get off of my deice pad?
as739x
Tue Mar 01, 2005 3:55 am
RamerinianAir: I think I'd actually ask in general what it cost to deice a 737. As stated above there are a number of places in Alaska that don't require deiceing. You go to SE Alaska and its not much colder then Seattle or San Francisco even. So this is to just let you know maybe you want to ask in general and not so much Alaska Airlines. Though are name sounds like we'd be pro's!
Now to answer your question is almost impossible. It all depends on current weather, temp.,wait times for departure, and current prices. There are a few types of fluid like NTS said. On top of the types of fluid, there are different mixes. Here at SFO we use a 50/50 mix but only have to deice the upper wings of MD80's and CR7's,so not much fluid is used. Now on the flip side I was on a HP A320 at CLE in Dec. that required Type I then type IV on the wings. So as you can see its very hard to even come up with a general number.
ASSFO
as739x
Tue Mar 01, 2005 3:56 am
Sorry, and to continue the flame it ALASKA.....
just kidding!
ASSFO
airbazar
Tue Mar 01, 2005 4:45 am
I am quite sure their bean counters know exactly how much they're spending on deicing, per year. However, I'm not sure you will find one of them on this forum  Smile Another place where you may find that sort of information may be their annual report.
ramerinianair
Tue Mar 01, 2005 11:56 am
I was e-mailed by a fellow a.netter. He told me that the contract his company has is for 1,700 USD per 73G. A little more for a 739 and a little less for a 732. Depending on the conditions, He said that they could use anywhere from 50 to 200 gallons so, they charge for 200 gallons always.
SR
L-188
Tue Mar 01, 2005 12:02 pm
A lot of companies are starting to get hot air blowers for the de-ice operations. The Air Force has them, doesn't screw up the water as much and you aren't buying fluid constantly.
spirtofalaska
Tue Mar 01, 2005 6:50 pm
Quoting FlyingNanook (reply 1):
I was taking a guest to the airport yesterday afternoon, and It was the first time i saw it, But they were de-icing a 737-700 Right next to the fence by the old delta gate ( the number escapes me at the moment, d1 i think )
Any, That was the first time i've ever seen it as well.
you fo'Coffee?
