Avianca
LongHoul Flights From MUC In The Past...
Tue Mar 01, 2005 1:31 am
Dear all,
what longhoul flights did operate in the past from MUC?
I know some...
Garuda - DPS
BWIA - ?
JAL - NRT
SAA - JNB
Air Namibia - WDH
Continental - EWR
American - ORD
Delta - CVG, JFK
Trek Airlines - JNB
PanAm - JFK
TWA - BOS
British - HKG
Malaysia - KUL
Air Madagascar - ANT
Canadian - YYZ
what flights are missing on this list?
regards
Avianca
hardiwv
RE: LongHoul Flights From MUC In The Past...
Tue Mar 01, 2005 1:39 am
Varig - GRU (2001)
Avianca
Tue Mar 01, 2005 1:41 am
Quoting Hardiwv (reply 1):
oh yes, but yeah MUC will get back this service!!! great
DAL767400ER
Tue Mar 01, 2005 1:49 am
Quoting Avianca (reply 0):
Delta - CVG, JFK
AFAIK, CVG was only served via JFK, so it was only a one-stop service.
Avianca
Tue Mar 01, 2005 1:51 am
Quoting DAL767400ER (reply 3):
no it was nonstop, MUC had in the year 1993 3 Delta nonstops each day.
ATL, CVG, JFK
DAL767400ER
Tue Mar 01, 2005 2:28 am
Quoting Avianca (reply 4):
Yeah, you were right, flight 131, operated 12456, lasted from summer 1993 until summer 1994. Other than that it was mostly flt 77 via JFK.
bwione
Tue Mar 01, 2005 2:40 am
Delta did indeed serve CVG from Munich. However, I do not recall TWA ever serving Boston from Munich. Service was to JFK when direct with same equipment. When they used the 727s to feed Paris flights, its possible that the flight number continued to BOS, but I don't think that counts  Smile
Anyhow, I remember Canada 3000 operating Halifax and Calgary from Munich before they went out of business. Also, Lauda operated a Miami service for years codesharing with Lufthansa before stopping it in 2002 (?). Lufthansa now operates to Miami with its own aircraft (seasonally). I believe that Air Seychelles operated briefly into Munich, I recall seeing Air Lanka (although that may have been charter) and Air Mauritius had operated into Munich for more than a decade before stopping last year (although they do still code share on a Condor operated flight). If you throw in cargo, they had Singapore Cargo 747-400F service to Singapore via Dubai and to JFK, service since moved to Brussels.
Tony
Tony
Avianca
Tue Mar 01, 2005 2:46 am
Quoting Bwione (reply 6):
oh yes TWA operated the B762 into the new MUC airport to JFK.
TWA operated BOS via GVA with a Tristar in the 80s.
And of course the Lauda flight to MIA coming from VIE, they used in the last year of the operating of the flight sometimes a A330 of Austrian Airlines and also machines from Lauda Italy.
I think the Air Seychelles service was just for one season, flight was moved from FRA and moved back after axing the flight to MUC.
Thank you for your comments.
regards
Avianca
Avianca
Tue Mar 01, 2005 2:51 am
I have forgotten the flights to the domenation Republic and Cuba operated by Britannia Germany. They offered you a very cheap vacation to Puerto Plata and Punta Cana... they offered sometimes for 900 german marks a 2 week all including vacation.
regards
Avianca
Jeremy
Tue Mar 01, 2005 3:42 am
I flew Lufthansa MUC-SFO on a 744 back in 2000.
You are now free to be sexually harassed and then terminated for filing a complaint--Southwest Airlines to me.
mozart
Tue Mar 01, 2005 3:51 am
Lufthansa had A340 service to Johannesburg, Singapore and Osaka.
Lauda also flew to Los Angeles, coming in from Vienna, but that stopped a long time before the MIA flight.
Those are all I can think of in addition to the above-mentioned.
However, I never knew about that GA flight. When was that? Which equipment, which routing?
Oh, and then, there is at least this "longhaul equipment": at the end of the 90s Swissair operated its ZRH-MUC morning flight with an MD-11. That was cool...
Avianca
Tue Mar 01, 2005 4:22 am
the GA service was at the last days of Munich Riem airport. Equipment was I think on MD11 but I am not 100 percent sure about, the destination was DPS or Jakarta....
The LAX flight was not started simultan to the MIA service and given up 1 year later?
Avianca
Tue Mar 01, 2005 4:28 am
Quoting Mozart (reply 10):
thank you, and the service to GRU with the A340
flymunich
Tue Mar 01, 2005 4:42 am
JAL B743 1/7 NRT (day 7)
MD B742 1/7 ANT - CDG (day 4/6)
MK A343 1/7 MRU (day 5 or 6)
HM B763 1/7 SEY (day 6)
GA MD11 1/7 MED-DPS (day 5)
UL L1011 1/7 CMB (day 5)
KU A310 2/7 KWI-GVA (day 2/6)
CP B763 5/7 YYZ (day 1/3/5/6/7)
SQ B744F 2/7 SIN-DXB-MUC-JFK (day 3/6)
SQ B744F 2/7 JFK-MUC-MAA-SIN (day 4/7)
RG B763 3/7 GRU-GIG-MUC-GIG-GRU (day 3/5/7)
AA B763 7/7 ORD
TW B763 7/7 JFK-BOS
BW L1011 1/7 POS-SLU (day 3)
flymunich
Avianca
Tue Mar 01, 2005 4:49 am
Quoting Flymunich (reply 13):
service increased to MD11 before cutting.
thank you
flymunich
another highlight in the 80's + 90's:
Iraqi Airways every monday with B737-200 or B727-200 to Bagdad.
KLM with DC10-30 to Nairobi-Dar es Salam.
British with L1011-500 2/7 on route MAN-MUC-DXB-HKG
Lufthansa with DC10-30 2/7 to KHI-BKK-NRT
Lufthansa with A340-200 3/7 to KIX
Lufthansa with DC10-30 2/7 to DUS-YYZ
Lufthansa with DC10-30 2/7 to DUS-MIA
Lufthansa with DC10-30 1/7 to DKR-GIG-GRU-BUE
Lufthansa with B707 7/7 to THR
Lufthansa with B707 3/7 to SDA
Lufthansa with B707 1/7 to TIP
flymunich
EDDM
Tue Mar 01, 2005 4:55 am
Any chance of getting back at least some of those?
flymunich
Tue Mar 01, 2005 5:19 am
China Eastern A340-300 2/7 to PEK-SHA(PVG)
Lauda Air B767-300 3/7 to LAX
Lauda Air B763/B772 3/7 to MIA
Air Jamaica DC 8-63 1/7 to MBJ
Air Florida DC10 1/7 to HAM-MIA
Seaboard World Cargo B747-100 1/7 to FRA-JFK
World DC10/MD11 1/7 to LAX
World DC10/MD11 1/7 to ANC
Flymunich
DAL767400ER
Tue Mar 01, 2005 6:13 am
Quoting EDDM (reply 16):
For DL, CVG will not return, as CVG is only a third-rank European gateway for DL after ATL and JFK. DL back to JFK, who knows. Ever since DL cut the route there were rumors to bring it back, but seeing as DL couldn't fill a second daily flight to ATL last summer, it is doubtful.
As for LH, should FRA encounter more traffic problems ( like no new runway being built), LH might open up some of the dropped MUC routes again to relieve FRA.
Avianca
Tue Mar 01, 2005 6:17 am
LH is operating more from MUC than ever, most mentioned citys are operated with LH metal or code-share from MUC.
regards
Avianca
EKcrew
Tue Mar 01, 2005 6:47 am
There was a season or two when LTU used to fly direct from MUC to LAX using MD11 or A330 in addition to the twice weekly DUS-LAX.
