mozart
Marseille Airport
Tue Mar 01, 2005 7:36 pm
Hi all, I've asked this question in a French forum some days ago but for some reason did not get any answer: I would like to know which airlines use which gates at Marseille airport. The website only has "Hall x" and "Hall y", but I would like to know whether there are patterns, for instance for the ORY shuttle always using the same gates, or a non-Schengen designated area, or whether Easy always goes to the same, etc.
gonzot
RE: Marseille Airport
Tue Mar 01, 2005 8:39 pm
I've been to Marseille about 10 times during the last few months and I always saw that :
- Air France domestic flights are located around the Hall 4 area (southernmost part of the terminal apron A5-A6 gate 1A to 3C)
and sometime I boarded on gate 6C or 6B (Fokker 70)
- Hall 1 (Apron A3-A4) is for international flights (saw Alitalia and northern african aircrafts) as indicated at the entrance of the terminal
- A CCM A319 is often parked at gate 4B
- EasyJet aircrafts are located around gates 5x to 7x, but I can't remember exactly
You will find .pdf maps of MRS airport (and the gates) at http://www.sia.aviation-civile.gouv....POLE/AIP/IAC/IAC%20AD%202.LFML.pdf
I didn't find any relevant picture of terminals on A.net
Hope it'll help you
Before dreams come true, one must first dream...
mozart
Tue Mar 01, 2005 10:43 pm
Gonzot, merci beaucoup! That is exactly what I was looking for!
kl911
Wed Mar 02, 2005 4:48 am
Every month I fly to Holland, first with Basiqair to AMS, but since they dropped the route I take HLX to CGN and then the ICE train.
I've always had a different gate number, although always the same Hall (1)
KL911
