SNATH
Boeing 777-200LR Completes Taxi Test
Sun Mar 06, 2005 5:17 am
OK, I find it hard to believe this hasn't been posted yet, but I couldn't find it with the search facility. So, here it is. the B772LR has completed taxi tests and the first flight is near:
http://www.boeing.com/news/releases/...05/photorelease/q1/pr_050304g.html
Tony
PS If it has been posted before, just delete this thread...
Nikon: we don't want more pixels, we want better pixels.
stlgph
RE: Boeing 777-200LR Completes Taxi Test
Sun Mar 06, 2005 5:24 am
Quoting SNATH (reply 0):
Something about an airplane just casually rolling around on the concrete is just not as exciting as it is flying through the air.
if assumptions could fly, airliners.net would be the world's busiest airport
SNATH
Sun Mar 06, 2005 5:28 am
Quoting STLGph (reply 1):
Yeah, but I'm sure it's enough to give ConcordeBoy wet dreams.  laughing
Tony
brons2
Sun Mar 06, 2005 5:29 am
What does a taxi test involve? The thrust reversers are deployed in the pic.
Firings, if well done, are good for employee morale.
Yazoo
Sun Mar 06, 2005 5:40 am
I rather like it in the New Boeing paint scheme, looks slick.
Purple Pride!
sammyk
Sun Mar 06, 2005 5:42 am
Well it wasn't just "casually" rolling around, according to the release it was moving around at 80 mph.
NYCA330
Sun Mar 06, 2005 5:54 am
As sexist as this sounds, I find it amazing that a woman is one of the chief test pilots for this aircraft.
SNATH
Sun Mar 06, 2005 5:56 am
NYCA330,
Quoting NYCA330 (reply 6):
Having wet dreams too, are you?  cloudnine
BTW, welcome to the forum!!!
Tony
NYCA330
Sun Mar 06, 2005 6:04 am
Thanks! I mainly lurk, because compared to most people here my knowledge is lacking. I do love planes though.
SNATH
Sun Mar 06, 2005 6:08 am
Quoting NYCA330 (reply 8):
Let me tell you, there's a very small minority of people here who actually know what they are talking about. And I'm definitely not one of them!
That's the important thing!
Tony
skidmarks
Sun Mar 06, 2005 6:13 am
Did the taxi pass the test?
Seriously, the thrust reversers will have been used to prevent it falling off the end of the runway after scuttling down at nearly T/O speed
Andy
Growing old is compulsory, growing up is optional
SNATH
Sun Mar 06, 2005 6:19 am
Quoting Skidmarks (reply 10):
I now have a "lovely" image of the B772LR in the Dreamliner livery... but in yellow! YUK!  crazy
Tony
stlgph
Sun Mar 06, 2005 6:32 am
Quoting Sammyk (reply 5):
It's casual when it's a plane built to fly 37,000 feet at 550 miles per hour.
Besides, I do 80 on the freeway through downtown.
sammyk
Sun Mar 06, 2005 6:44 am
My point was it wasn't moving around slowly.
Good for you for going 80 through downtown. Want a cookie?
DfwRevolution
Sun Mar 06, 2005 7:01 am
Quoting STLGph (reply 12):
Your car doesn't weigh 320,000 lbs nor stretch 199 feet long by 212 feet wide, does it now?  Wink
B707Stu
Sun Mar 06, 2005 7:25 am
Does anyone have any A380 taxi pics yet? Seems strange timing. I mean it seems Boeing has this a/c out a lot faster than the A-380. Is that because it's a different version of same type aircraft? (PS. This is not a ploy to start a fight, just a question!)
N1120A
Sun Mar 06, 2005 7:30 am
Quoting B707Stu (reply 15):
Short answer, yes.
Udo
Sun Mar 06, 2005 7:32 am
Airbus is still fixing the tail...  Wink
Me & You & a Plane Named Blue...
SNATH
Sun Mar 06, 2005 7:57 am
This is most likely due to the fact that the B772LR is a derivative of a plane which is already flying, whereas the A380 is a totally new airframe. So, obvioously, Airbus has a lot more testing to do before it can allow it to fly.
Tony
as739x
Sun Mar 06, 2005 8:04 am
SNATH is 100% correct. With the A380 being brand new and having growing pains its no big deal it is taking a little longer. The big test fot the 777LR is when it starts using more systems that are new to the 777 family, which I don't know how many there are. Also, the biggest deal really with this plane is when they push the range on test flights. Can't wait!
ASSFO
SNATH
Sun Mar 06, 2005 8:09 am
Quoting AS739X (reply 19):
And I'm sure it will be the same with the B787!
Tony
co7772wuh
Sun Mar 06, 2005 9:08 am
I know Boeings 777-200LR use the most powerful jet engines .
However , I'm curious if the 777-200LR's engines have a larger diameter than other 777s ?
Still waiting for some orders for the Worldliner ?  confused
DfwRevolution
Sun Mar 06, 2005 9:11 am
Quoting Co7772wuh (reply 21):
No, the GE90-115 and GE90-94 have the same fan diameter. The -115 has a reshaped fan, reinforced/improved core.
The PW4000 has a 112 inch fan, the Trent 800 has a 110 inch fan
BG777300ER
Sun Mar 06, 2005 9:19 am
This is sort of out of place in this topic but I remember reading on airliners.net somewhere that all the people in the A380 during its test flight will be wearing parachutes. Also, the cargo door will be rigged with explosives in case of an emergency. I was just wondering if this is normal for every test flight or it's just for the A380. It just seems kind of extreme to have explosives on board.
Koi mi sra v gashtite?
SNATH
Sun Mar 06, 2005 9:20 am
In fact, this is not quite correct, as the GE90-110 is actually a derrated GE90-115, used on the B773ER (110K vs. 115K lb of thurst).
Apologies for being really pedantic!  sorry
Tony
No, the thrust reversers were used in order to test the thrust reversers. The aircraft is quite capable of stopping with brakes only, as required by FAA regulations. If you stop to think about it, a rejected takeoff scenario which absolutely required the use of thrust reversers would not be logical, since many of these are engine out scenarios, where you wouldn't have both reversers!
DfwRevolution
Sun Mar 06, 2005 9:57 am
Quoting BG777300ER (reply 23):
How would they ever possibly hope to evacuate an airplane in such a manner? It's almost impossible to "bail-out" of a commercial airliner
raggi
Sun Mar 06, 2005 9:58 am
Quoting DfwRevolution (reply 22):
Actually, according to GEAE.com, the 115B has a maximum diameter of 135 inches, whereas the earlier 90s have a max diameter of 134.
The fan diameter has grown from 123 to 128 inches.
http://www.geae.com/aboutgeae/presscenter/ge90/ge90_20011120.html
raggi
Stick & Rudder
DfwRevolution
Sun Mar 06, 2005 10:01 am
Quoting Raggi (reply 27):
My bad! Have some fact checkin` to do  Wink
glideslope
Sun Mar 06, 2005 7:24 pm
Quoting Udo (reply 17):
There is more to fix than the tail......  Cool
Sun Mar 06, 2005 10:28 pm
Well they don't do it just for show. There was a long thread about this. Boeing does the same kind of thing.
Udo
Mon Mar 07, 2005 5:28 am
Quoting Glideslope (reply 29):
Oh, wait - you must be the "insider" who told "Der Spiegel" about " tail problems"?  laughing
Udo
SonicKidatBWI
Mon Mar 07, 2005 5:36 am
Quoting DfwRevolution (reply 14):
Strange ... I was always under the impression that the 777-200 was 209 feet long ... hummmm
DfwRevolution
Mon Mar 07, 2005 5:39 am
Quoting SonicKidatBWI (reply 32):
199 feet was the wingspan of the 772ER, not it's length... my bad, lord of aviation statistics  whistleblower
SonicKidatBWI
Mon Mar 07, 2005 5:52 am
Quoting DfwRevolution (reply 33):
So I'm confused ... who were trying to prove wrong? Me or yourself. Because you make this statement as if I said 199ft was the length which we all know you did. At any rate while trying to make another A.net member look stupid, you were the one who ended up with egg all over your face because however miniscule the wrongness of your technicality might have been ... you were still wrong yourself. Case and point, I digress.
mham001
Mon Mar 07, 2005 6:02 am
Nice edit, but "...my bad" means he admitted his mistake. You could have saved yourself all those words unless you just wanted to flame somebody.
sammyk
Mon Mar 07, 2005 6:07 am
Haha and the context in which the planes dimensions were given it didn't even matter if it was off by 10 feet.
DfwRevolution
Mon Mar 07, 2005 7:06 am
Quoting Sammyk (reply 36):
Bingo
SnowJ
Mon Mar 07, 2005 7:13 am
Quoting SNATH (reply 7):
Heh heh... ziplip
Jaysen F. Snow - Midwest Tail Chasers
